Problema con la EGR.
DMoLiTi0n
Buenas. Desde el jueves, llevo con la luz amarilla que hay en el cuenta revoluciones del coche. Según el manual, significa "expulsion de gases del escape". La cuestión es que hoy, le he hecho un escaneo con el VAG-COM, y me da lo siguiente:
VAG-COM Version: Release 607.3-UD
Sunday,11,May,2008,19:49:04
Chassis Type: 8P - Audi A3
Scan: 01 02 03 08 09 0F 15 16 17 18 19 22 25 36 37 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
VIN Number: WAUZZZ8P********
Address 01: Engine
Part No SW: 06F 906 056 BT HW: Hardware No
Component: MED9.5.10 G00 5340
Coding: 0000072
Shop #: WSC 03463
Part No: 06F 907 807 A
Component: NOX 0309080072 004 3608
06F907807A NOX 0309080072 004 3608
4 Faults Found:
17439 - Manifold Change-Over Valve (N136): Setpoint Not Reached
P1031 - 001 - Upper Limit Exceeded - Intermittent
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 002 - Lower Limit Exceeded - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 008 - Implausible Signal - Intermittent
17811 - EGR System: Regulation Deviation
P1403 - 008 - Implausible Signal - MIL ON
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0053894
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
Address 09: Cent. Elect.
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Coding: 058C4F0080141000000000000000000000
Shop #: WSC 00247
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00064784
Shop #: WSC 00247
2 Faults Found:
00153 - Left Windshield Wiper Motor (V216)
004 - No Signal/Communication - Intermittent
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit - Intermittent
Address 15: Airbags
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
Shop #: WSC 06435
Address 16: Steering wheel
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H09 0020
Coding: 0000042
Shop #: WSC 03463
Address 17: Instruments
Part No SW: 8P0 920 930 G HW: 8P0 920 930 G
Component: KOMBIINSTR. VDO H25 0110
Coding: 0004103
Shop #: WSC 03463
Address 19: CAN Gateway
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Coding: 3D0F0300070100
Shop #: WSC 06435
Address 25: Immobilizer
Address 42: Door Elect, Driver
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000088
Shop #: WSC 06435
Address 44: Steering Assist
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.9 1202
Address 46: Central Conv.
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 188800186D288505484A016000
Shop #: WSC 06435
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass.
Part No: 8P0 959 802 A
Coding: 0000088
Shop #: WSC 06435
End --------------------------------------------------------------------------------------------------
La cuestión es, que después del primer scan copie e hice un Clear. Arrancó el coche y sigue saliendo. Le vuelvo a hacer otro SCAN y efectivamente todo =, mismo fallos. Me doy cuenta, que cuando conecto la llave, hace un ruido raro que sale del motor.....EGR?
Total que tiene toda la pinta de ser la EGR, no? Pero mi preguntas son las siguientes:
+ 1.- ¿tiene que ver los demás fallos que me dá debido a la EGR?
+ 2.- Si lo llevo a la casa oficial, creo que me van a ordeñar. ¿llevo razón? Si alguien lo ha llevado al taller y se lo han arreglado, cuanto aproximadamente sale??
+ 3.- He visto el post de limpiar EGR. En teoría, si la llevo a que me la limpie, se solucionará el problema,no?
+ 4.- El bricopost es sobre un A4, supongo que en el A3, será igual, más o menos, no? El A3 que tengo es de gasolina 2.0FSI....
+ 5.- ¿¿Me perjudica mucho coger el coche con el fallo este??
Espero vuestras respuestas. Un saludo
Editado por DMoLiTi0n
4 Faults Found:
2 Faults Found:
Ilde, sabes que siempre me gusta pensar, antes de nada, en fallos "chorra" que puedan provocar esta serie de errores. Fíjate que todos ellos pueden deberse a una flta de alimentación eléctrica por cualquier lado.
La EGR, sencillamente, no arroja lectura alguna. Lo mismo ocurre con la comlumna de dirección. La N136, puede ser que esté bloqueada y, luego, tienes los fallos en el elevalunas izquierdo y en la luz de freno izquierda (revísalas, por cierto).
Me inclino por alqo que está haciendo alguna mala conexión.
Pregunta tonta, ¿has tenido el coche aparacado en algún sitio que esté "frecuentado" por ratas siendo posible que haya entrado alguna y haya mordido algo? No serías el primero al que le pasa y, lo que es más desagradable, tampoco serías el primero que al desmonar el coche se encuentra a la rata frita por el calambrazo.
SALUDOS
Hay algo que me preocupa.
Dices que has borrado los errores y, posteriormente, te han vuelto a salir.
¿Te acuerdas de la útima vez que te hice yo el análisis? No quise borrarte nada para que fueras a la concesión con todos los errores. Fíjate que hay dos que se repiten :drooling::thumbsup: (este análisis es de tu coche el 14 de abril)
Monday,14,April,2008,15:54:29:50594
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 06F 906 056 BT
Component and/or Version: MED9.5.10 G00 5340
Software Coding: 0000072
Work Shop Code: WSC 03463
Additional Info: 06F907807A NOX 0309080072 004 3608
Additional Info: Geraet 81584
4 Faults Found:
Sobre la luz de freno izquierda, tuve que cambiarle la bombilla hace 1 semana, hace que miraré por si las moscas el conector, aunque la luz funciona correctamente.
Sobre los fallos que se repiten, es totalmente muy extraño, ya que según el concesionario oficial era problema del distribuidor de gasolina y los tubos, que cambien hace 2 semanitas y me soplaron 1063,57€, uf. ASI que por lo pronto voy a limpiar la EGR, y seguidamente si sigue dando problemas lo llevaré a la casa, porque esto es verdaderamente mosqueante.
Vaya martirio con el dichoso 2.0FSI, lo llego a saber mi pillo el TDI. :S
sALUDOS
