error 01044
hola . reparando el airbag del conductor , una vez lo repare me salio el error 01044 y e provado a codificar la unidad de airbag y nada , e provado con varios codigos y nada mi audi es el allroad con reductora , haber si alquien me ayuda si no no puedo pasar itv que me la echaron para atras con el airbag . otra cosa que e leido en el elsawin es que para hacerlo con el vag 1551 tiene que tener codigo de taller por favor ayudarme gracias de ante mano
01044 - Control Module Incorrectly Coded
Possible Symptoms
Reduced Functionality
Possible Causes
Control Module incorrectly coded
Possible Solutions
Check Gateway Installation List
Check/Fix Control Module Coding
See Vehicle Specific Diagnostic Procedures for Details
Special Notes
When found in CAN-Gateway, use the Gateway Installation List to check for unreachable or not registered control modules. Then update the Gateway Installation List by altering the Gateway Coding manually.
01044 - Control Module Incorrectly Coded: Implausible Signal
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Possible Solutions
Special Notes
Some Passat (3B/B5) around MY 2000 have a Firmware Bug which causes this DTC to be set in the CAN Gateway (19). Service Documents for of those Cars indicate that this DTC should be ignored in that Module as long as the Coding matches the Vehicle Equipment.
01044 - Control Module Incorrectly Coded: Mechanical Failure
Possible Causes
Coding Pin/Bridge does not match
Possible Solutions
Check/Fix Coding Pin/Bridge in Wiring
