fallos en centr locks
chemacdb
Hola a todos,
soy un asiduo lector de audi sport iberica y siempre que tengo algun problema con mi audi allroad me lo habéis solucionado.En esta ocasión, estoy interesado en un audi TT y cuando le pasé el VAG, me que de alucinado. primero me dio algún fallo la dirección 35 centr locks:
Address 35: Centr. Locks
Part No: 8N
Component: Zentralverrieg. D06
Coding: 00000
Shop #: WSC 00000
15 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01134 - Alarm Horn (H12)
49-00 - No Communications
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
01092 - Switch For Stowed Canopy (F171)
27-00 - Implausible Signal
01091 - Switch Front Canopy (F202)
01617 - Please Check DTC Memory of Interior Monitoring
35-00 - -
los borre y al pasarlo otra vez me salio esto:
Part No: 8N
Coding: 00000
Shop #: WSC 00000
72 Faults Found:
35-10 - - - Intermittent
01558 - Contact Switch in Locking Cyl; Driver Side; Close (F241)
29-10 - Short to Ground - Intermittent
01557 - Contact Switch in Locking Cyl; Driver Side; Open (F241)
01618 - Automatic Convertible Top Valve 2 (N272)
28-10 - Short to Plus - Intermittent
01563 - Interior Lock Switch; Driver Side (E150); Lock
01564 - Interior Lock Switch; Driver Side (E151); Unlock
00947 - Trunk Lid remote Control Switch (E188)
01565 - Luggage Compartment Light (W3)
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
00991 - Interior Lights
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
01568 - Signal for Convenience Opening
01569 - Signal for Convenience Closing
01357 - Tank Flap Locking Motor (V155)
01555 - Motors for Central Locking; Save [safe?]
01556 - Motors for Central Locking; Unlock
00955 - Key 1
00956 - Key 2
00957 - Key 3
00958 - Key 4
01570 - Turn-Off Delay; Terminal 15
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01560 - Passenger Door
00000 - End of Output
00-10 - - - Intermittent
59-10 - Can't Unlock - Intermittent
60-10 - Won't Safe - Intermittent
61-10 - Won't De-Safe - Intermittent
01141 - Luggage Compartment Unlocking Switch (E165)
01552 - Motor for Central Locking; Drivers Door (V56); Lock
01553 - Motor for Central Locking; Passenger Door (V57); Lock
01554 - Motors for Central Locking; Rear Doors; Lock
00949 - Central Locking Motor - tailgate (V53); LOCK
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
01581 - Incorrect Component Detected
01379 - Interior Monitor Switch (E183)
01109 - Hydraulic Pump Relay (J321)
30-10 - Open or Short to Plus - Intermittent
01482 - Motors for Central Locking
00951 - Tailgate Central Locking Motor Relay (J398)
01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
01615 - Tank Door Remote Unlocking Switch (E204)
49-10 - No Communications - Intermittent
76-10 - Terminal 30 missing - Intermittent
77-10 - Internal Supply Voltage - Intermittent
27-10 - Implausible Signal - Intermittent
Buenas Chema, central lock es central de bloqueo (Cierre centralizado como dice Korny1976) , lo que yo veo en principio es que todos los fallos son "intermitentes" en el primer vag que le pasas, quizás si lo ves en español sea mas claro de entender....
Dirección 35: Centr. cabellos
Número de parte: 8N
Componente: Zentralverrieg. D06
Codificación: 00000
Tienda #: WSC 00000
15 Fallos Encontrado:
01366 - Estudio abierto debido a la caída de la señal
35-00 - -
01371 - Puerta de alarma provocada por el interruptor de contacto; Lado del conductor
35-00 - -
01572 - Puerta de alarma provocada por el interruptor de contacto; lado del pasajero
35-00 - -
01374 - Terminal de alarma provocada por 15
35-00 - -
01370 - Alarma provocada por vigilancia del habitáculo
35-00 - -
01369 - Alarma provocada por conmutador de capó
35-00 - -
01368 - Interruptor de alarma provocada por el compartimiento de equipaje
35-00 - -
01373 - Planta de alarma provocada por Radio Contacto
35-00 - -
00955 - Clave 1
09-10 - Límite de Adaptación Superó - Intermitente
01134 - Bocina de alarma (H12)
49-00 - No hay Comunicaciones
76-00 - Terminal 30 desaparecidos
77-00 - Tensión de alimentación interna
01092 - switch En estibada Canopy (F171)
27-00 - Señal no plausible
01091 - interruptor frontal del pabellón (F202)
01617 - ver la memoria DTC de vigilancia del habitáculo
35-00 - -
Y en el segundo log te salen mas fallos aún... No es una averia importante y como dices es raro que coding y el shop sea 0000, yo creo que pueden ser varias opciones...
La centralita de "Confort" se ocupa de muchas cosas del coche, si falla, pues como es normal se estropean muchas cosas, se puede romper por algún defecto, un componente quemado o se puede romper por agua, cundo digo agua es porque si la goma que sella el maletero se estropea, entra agua al interior y puede provocar que se rompa la centralita que está detrás del asiento del conductormetida en el lateral.
Yo probaria varias cosas:
-Borra los fallos de central locks hasta que no salga ninguno. si siguen saliendo, tampoco pierdas mucho tiempo, haz 4 o 5 borrados.
-Desconecta las dos bornas de la bateria entre 30 y 60 minutos. Después vuelve a pasar el vag.
-Configura el coding de la centralita, entras en el central locks 35 y arriba a la izquierda pone coding, cuando entres te esperas unos segundos y saldrá un número, ponlo (creo que era así, pero sin estar delante es dificil).
-Comprueba fusibles.
Cuéntanos a ver que tal y seguro que hay gente que sabe mas del tema.
Bueno
Número de parte: 8N
Codificación: 00000
Tienda #: WSC 00000
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Clave 1
35-00 - -
Buenos días, esta parte me interesa. Podeis describir mejor lo que hay que hacer con el vagcom.
Gracias.
