PROBLEMA EN MI ALLROAD 2.7T AYUDA POR FAVOR.
Hola, como estan?? me presente hace tiempo ya, poseo un Audi S3 8P, y una Allroad C5 2.7T.
Tengo problema con mi Allroad. Les paso el scan de VCDS. desde ya muchas gracias por su ayuda.
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 P
Component: 2.7L V6/5VT G 0003
Coding: 05755
Shop #: WSC 00046
VCID: 50B361DB5AE3C3B2CF40A65-515E
WAUYD54B33N068393 AUZ7Z0B2274566
No fault code found.
Readiness: 0010 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 L
Component: AG5 01V 2.7l5VT RdW 2122
Coding: 00001
Shop #: WSC 00046
VCID: 4FB162A747DDDC4AD67ABD1-515E
2 Faults Found:
17114 - Gear Ratio Monitoring
P0730 - 35-00 - Incorrect Gear Ratio
17195 - Excessive Clutch Slippage
P0811 - 35-00 -
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06497
Shop #: WSC 00046
VCID: 4A8773B3BCBFF9628184E4D-515E
VCDS
Self-Diagnosis Log
Wednesday,02,September,2020,02:20:22:04550
Page 2
VIN: WAUYD54B33N068393 License Plate: ECQ287
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AL
Component: A6-Klimavollautomat 0105
Coding: 00000
Shop #: WSC 02325
VCID: 64DBBD0B3E5B4F129B889A5-2586
1 Fault Found:
01592 - Air Quality Sensor (G238)
37-00 - Faulty
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 H
Component: Airbag 8.4EP 2000
Coding: 0000706
Shop #: WSC 02325 785 00200
VCID: 54BB6DCB6EFBBA92EB284A5-515E
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 H
Component: Lenkradelektronik D01
Coding: 01012
Shop #: WSC 02325
VCID: 3175045F3129AABAA08ECB9-5140
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 933 P
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 04164
Shop #: WSC 05002
VCID: 3073015B3A23A3B2AF80C65-5140
VCDS
Self-Diagnosis Log
Page 3
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 05002
VCID: 47814A87AFAD040A9EAAC51-5140
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
hace 6 horas, Fede.S3.ARG dijo:
Coding: 00001
Shop #: WSC 00046
2 Faults Found:
http://wiki.ross-tech.com/wiki/index.php/17114/P0730/001840
El otro fallo puede estar derivado por el primero
Hace cuanto que no le cambias el liquido?
Pd.- cuando necesiteis ayuda con un problema cuantos mas datos faciliteis mas facil le resultara a la gente saber por donde tirar. porque con una lectura de obd sin saber que le ocurre al coche quizas sea lo que te digo yo o eso era un error almacenado.
un saludo!
Hola muchas gracias por la respuesta. Hace pocos meses tengo el auto, el dueño anterior le hizo el servicio de caja hace unos 20.000km. esas fallas las borro y vuelven a aparecer por lo que supongo es un problema actual. El auto vengo andando y hace unos rebajes la caja hasta que se pone en emergencia la caja. Lo que me llama la atención es que siempre tarda lo mismo en hacerlo, es decir arrancan en frío a los aprox 15 min. Empieza el problema. Veo también una falla de la suspension que hace mención a la temperatura de la misma, podrá ser que venga de ahí el problema una vez q calienta??
Desde ya muchas gracias a todos
