Pistas en mi log
Vrod
Hola ...
Soy novatillo en esto por lo que si alguien me puede ayudar con mi A4 1.8t le estaré agradecido ... :
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 T
Component: 1.8L R4/5VT MOTR HS D04
Coding: 04001
Shop #: WSC 00000
1 Fault Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 B
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0T9984050 D77
Coding: 00000
Shop #: WSC 21000
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
End -------------------------------------------------------
