Tengo estos fallos en Vag-Com
djthomas
Buenas a todos.
La otra tarde un amigo me paso el Vag-Com en mi Audi TT y me salieron todos estos fallos.
Alguien me puede decir que piezas necesito y si ya me da los codigos oem se sale.
aqui os dejo los fallos y de ante mano muchos gracias.
Saturday,21,January,2012,16:09:42:63170
VCDS Version: Release 908.0
Data version: 20090830
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 8N0 906 018 AB
Component: 1.8L R4/5VT 0002
Coding: 05500
Shop #: WSC 06435
5 Faults Found:
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-00 - -
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - - Intermittent
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 D
Component: ESP 20 CAN V006
Coding: 23049
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D01
Coding: 00040
Shop #: WSC 06435
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: None
Part No: 8N8 909 601
Component: Airbag Front+Seite 0004
Coding: 10102
Shop #: WSC 06435
Address 17: Instruments Labels: Redir Fail!
Part No: 8N1 919 880 E
Component: KOMBI+WEGFAHRS. M73 D26
Coding: 00044
Shop #: WSC 39942
Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0Y1222225
Ident.-Nr. Wegfahrs.:AUZ5Z0Y1222225
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N8 962 267
Component: Zentralverrieg. D04
Coding: 04672
Shop #: WSC 39942
End ---------------------------------------------------------------------
Enlace al comentario
Compartir en otros sitios web
A ver qué te cuentan los sabios de por aquí...
Es la primera vez que le pasas el Vagcom?
Probasteis a borrar los errores, dar una vuelta y volver a comprobar?
En principio, de lo poco que sé, parece que tienes algún fallo en la N75, así que yo empezaría por cambiarla y luego pasa otra vez el Vagcom.
Creo que es mejor ir paso a paso, corrigiendo errores poco a poco y no liarte a comprar todas las posibles piezas averiadas... pero, como ya te dije, a ver que te van respondiendo por aqui, que hay gente que sabe de verdad.
Suertey saludeTTes
