eryayi Publicado 17 de Febrero del 2013 Denunciar Compartir Publicado 17 de Febrero del 2013 Kreo que no se accede bien al enlace. Entra en www.ross-tech.com, en "wiki" y selecciona Audi y ya te aparece todo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
eryayi Publicado 17 de Febrero del 2013 Denunciar Compartir Publicado 17 de Febrero del 2013 Coding 0?xxxxx: Model 1 = Lamborghini 2 = Audi A3 (8P) 3 = Audi A4 (8E) 4 = Audi A4 Cabriolet (8H) 5 = Audi A6 (4B) 6 = Audi TT (8J) 7 = Audi R8 (42) 0x?xxxx: Treble Speaker Monitoring inactive 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet) 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet) 0xx?xxx: Sound Characteristic 0 = Sound Characteristic linear 1 = Audi A4 (8E) 2 = Audi A6 (4B) 3 = Audi A4 Cabriolet (8H) 4 = Audi TT (8J) 5 = Audi A3 (8P) 9 = Sound System 0xxx?xx: Telephone/Telematic 1 = Telephone not installed (Remote Feed Voltage for Microphone active) 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive) 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive) 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive) 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive) 6 = Telematic US (Remote Feed Voltage for Microphone inactive) 7 = Base Plate diagnostic capable with Comfort Control 0xxxx?x: Equipment I 1 = Tuner not installed 2 = Digital-Radio installed 3 = Satellite-Radio installed 4 = Satellite and Digital-Radio installed 5 = Analog Input (AUX) installed 7 = Satellite-Radio & Analog Input (AUX) installed 0xxxxx?: Equipment II 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed 2 = TV-Tuner installed 3 = CD-Changer installed 4 = TV-Tuner and CD-Changer installed 5 = Multi-Function Steering Wheel installed 6 = TV-Tuner and Multi-Function Steering Wheel installed 7 = CD-Changer and Multi-Function Steering Wheel installed 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed Adaptation Channel 001: Tire Circumference The tire circumference is being adapted in "mm". Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution. If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value. 43 = Audi A3 (8P) / Audi TT (8J) 45 = Audi A4 (8E) Channel 003: Language (Screen) 0 = German 1 = English (UK) 2 = French 3 = Italian 5 = Spanish 6 = Portuguese 7 = English (UK) Channel 004: Back-Up Camera 0 = Back-Up Camera not installed 2 = Back-Up Camera installed Channel 005: Speed Threshold (Video Input) 0 = max. 0 kph or 0 mph 1 = max 5 kph (Standard for Europe) Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region 0 = Europe/North America 1 = Australia/South America 2 = South Africa Channel 011: Language (Speech Recognition) 0 = German 1 = English 2 = French 3 = Italian 5 = Spanish Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding. 0 = Standard Start Screen 1 = Audi S3 Start Screen 2 = Audi S4 Start Screen 3 = Audi RS4 Start Screen 4 = Audi TT Start Screen 5 = Audi R8 Start Screen Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive 000 - Normal/Eject-Button enabled 001 = Eject CD/DVD (will not be saved) 255 = Eject-Button disabled/locked (Anti-Theft-Protection) Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture. 0 = No Test Picture 1 = Test Picture: Red 2 = Test Picture: Green 3 = Test Picture: Blue 4 = Test Picture: White 5 = Test Picture: Black 6 = Test Picture: Checkerboard 7 = Test Picture: Checkerboard (inverted) 8 = Test Picture: 64 Gray Scales (vertical Bars) 9 = Test Picture: Special Channel 069: Display Mechanism 000 = Display closed 001 = Display open 200 = Display half open (Obstacle) 255 = Position undefined Channel 070: Display Brightness 0 = 0% Brightness (Display OFF) 1 = 20% Brightness 2 = 40% Brightness 3 = 60% Brightness 4 = 80% Brightness 5 = 100% Brightness Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus. 0 = Transport Mode inactive 1 = Transport Mode active Channel 111: Reset To perform a system reset/restart save 1 as new value. Channel 114: FM Frequency Range: 875...1080 Channel 117: Signal Test (Output) 0 = Fader Center & Balance Center 1 = Fader Front & Balance Left 2 = Fader Front & Balance Right 3 = Fader Rear & Balance Left 4 = Fader Rear & Balance Right Channel 136: Driver Position RNS-E Basic 03226 = Left-Hand-Drive (LHD) 02632 = Right-Hand-Drive (RHD) RNS-E High/US 00005 = Left-Hand-Drive (LHD) 00013 = Right-Hand-Drive (RHD) Responder Enlace al comentario Compartir en otros sitios web More sharing options...
templario88 Publicado 17 de Febrero del 2013 Autor Denunciar Compartir Publicado 17 de Febrero del 2013 no hay manera de configurar el RNS-E me da fallos al hacer un scan y no me entra en adaptation instruments para configurar Responder Enlace al comentario Compartir en otros sitios web More sharing options...
eryayi Publicado 17 de Febrero del 2013 Denunciar Compartir Publicado 17 de Febrero del 2013 Puedes indicar que fallo te da? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
templario88 Publicado 19 de Febrero del 2013 Autor Denunciar Compartir Publicado 19 de Febrero del 2013 (editado) Me aparecen los siguientes errores a ver si alguien con eso sabe por donde puedo buscar.. Address 37: Navigation Labels: None Part No SW: 8P0 035 193 G HW: 8P0 035 193 G Component: RNS-E PU EU H06 0220 Revision: 0000012S Serial number: AUZBZ7LD220322 Coding: 0205755 Shop #: WSC 10935 000 10485 VCID: 346C1E8E686179BC 9 Faults Found 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 70 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 18:25:29 Freeze Frame: Mileage: 655350 km Count: 65535 Clock: 255:255 00856 - Radio Antenna 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 2 Reset counter: 70 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 18:44:10 Freeze Frame: Mileage: 75430 km Count: 1702 Clock: 00:00 00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 5 Fault Frequency: 3 Reset counter: 30 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 16:53:31 Freeze Frame: Mileage: 75430 km Count: 1702 Clock: 00:00 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 2 Reset counter: 70 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 18:44:10 Freeze Frame: Mileage: 75430 km Count: 1702 Clock: 00:00 00878 - Connection to Speaker Front Left 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 2 Reset counter: 72 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 20:13:54 00879 - Connection to Speaker Front Right 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 70 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 20:13:54 00466 - Control Module for Steering Column Electronics (J527) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 70 Time Indication: 0 Date: 2013.02.17 Time: 13:20:59 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 30 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 16:53:25 01317 - Control Module in Instrument Cluster (J285) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 70 Time Indication: 0 Date: 2013.02.17 Time: 13:21:15 Freeze Frame: Bin. Bits: 10111011 Bin. Bits: 10 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 S HW: 1K0 907 951 Component: J533__Gateway H16 0210 Revision: H16 Serial number: 3400K094160B4C Coding: E9801F06500202000100 Shop #: WSC 06314 000 00000 VCID: 37762982791792A4 4 Faults Found 00470 - Combination comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 154 Reset counter: 33 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 16:52:16 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 23 Reset counter: 72 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 17:00:06 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 31 Reset counter: 72 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 17:00:07 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG Component: KlimavollautomatH09 0100 Revision: 000420 Serial number: 8P0820043BG Shop #: WSC 00000 000 00000 VCID: 72E0D89652F5378C 1 Fault Found 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 70 Mileage: 75438 km Time Indication: 0 Freeze Frame: Voltage: 8.30 V el primero de la CAN Gateway ya me salia creo que desde que compre el coche asi que yo creo que ese lo descartaria Editado 19 de Febrero del 2013 por templario88 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
eryayi Publicado 19 de Febrero del 2013 Denunciar Compartir Publicado 19 de Febrero del 2013 Los errores ZF son normales ya que seguramente tienes los amplificadores de la radio concert que no son los mismos, perderas recepcion de radio pero nada mas. Por los otros errores da la impresion que son fallos de los conectores de antena y altavoces. Verifica que todo este bien conectado, antena gps, antena de radio... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
templario88 Publicado 19 de Febrero del 2013 Autor Denunciar Compartir Publicado 19 de Febrero del 2013 (editado) si eso de los amplificadores de la radio lo se y bueno el conector de la antena GPS tampoco le doy importancia el GPS va bien lo que lo he conectado y desconectado 1000 veces y por eso saldra el fallo igual que el del micro que micro no tengo pero me marca un fallo Editado 19 de Febrero del 2013 por templario88 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
juan252 Publicado 20 de Febrero del 2013 Denunciar Compartir Publicado 20 de Febrero del 2013 Parece que las conexiones no se encuentran de manera firme, habrá que verificarlas, por otro lado dice que busca la conexión a manos libres, y busca volante multifunción, tienes estos dos dispositivos instalados? si no habrá que desactivarlos para que el rns-e no los busque mas, después de ajustar esto borrar fallos y verificar que vuelve a salir, saludos. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
templario88 Publicado 20 de Febrero del 2013 Autor Denunciar Compartir Publicado 20 de Febrero del 2013 No tengo manos libres, multifuncion si he borrado fallos y he vuelto hacer el scan y me salen los siguientes errores Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 S HW: 1K0 907 951 Component: J533__Gateway H16 0210 Revision: H16 Serial number: 3400K094160B4C Coding: E9801F06500202000100 Shop #: WSC 06314 000 00000 VCID: 37762982791792A4 3 Faults Found 00470 - Combination comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 9 Reset counter: 36 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:05:17 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 74 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:15:27 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 74 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:15:27 Address 56: Radio Labels: None Part No SW: 8P0 035 193 G HW: 8P0 035 193 G Component: RNS-E PU EU H06 0220 Revision: 0000012S Serial number: AUZBZ7LD220322 Coding: 0205755 Shop #: WSC 10935 000 10485 VCID: 346C1E8E686179BC 2 Faults Found 00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 34 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:06:30 Freeze Frame: Mileage: 75550 km Count: 1902 Clock: 21:06 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 34 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:06:24 los que estan en negro los doy por normales pero los rojos no entiendes porque me aprecen en el modulo 17 intruments channel 62 es posible que no lo tenga o deveria de aparecer siempre? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
juan252 Publicado 20 de Febrero del 2013 Denunciar Compartir Publicado 20 de Febrero del 2013 Ya le indicase al RNS-e que no llevas teléfono?, hay que decirle que lo no llevas para que ya no lo busque. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
juan252 Publicado 20 de Febrero del 2013 Denunciar Compartir Publicado 20 de Febrero del 2013 Ese can gateway parece ser de golf y no de audi... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
juan252 Publicado 20 de Febrero del 2013 Denunciar Compartir Publicado 20 de Febrero del 2013 Esa centralita 1K0 907 530 S de Gateway es la que montaba el cabrio de 2008, ese es tu coche? aquí pueden pasar varias cosas, que esa centralita la hayan puesto a posterior, que no sea la original de tu auto 2009, y al ser de 2008 es compatible con los rns 192 y al haber montado el 193 tu gateway no es completamente compatible, ojalá haya gente con mas experiencia con lo ojos en el tema que nos pueda ayudar, por lo pronto dile a tu rns que no lleva teléfono, saludos. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
eryayi Publicado 21 de Febrero del 2013 Denunciar Compartir Publicado 21 de Febrero del 2013 Hola, has comprobado la codificación? No estoy seguro pero en tu coche creo que no aparece el canal 62 de adaptación del módulo 17 de Instrumentos. Es posible que eso sea sólo para los A4 B7 y quizás para los A3 8L? En el mío que es del 2008 (8P) no aparece nada en ese canal y no tengo errores ni problemas, y en un seat Exeo que tengo, que tiene el mismo RNS-E que el que tu tienes tampoco hay que codificarlo. Con las opciones que has comentado (Volante multifunción y sin teléfono) si no me equivoco, deberías tener lo siguiente codificado en el módulo 37: 0205115 - Sin equipo Bosé ni entrada AUX de audio. 0209155 - Con equipo Bosé y entrada AUX de audio. Y si sigues sin poder acceder al módulo 37 del Navegador, comprueba en el módulo 19 del Can Gateway a ver si tienes marcado el bit 6 del Byte 4 en el Long Coding para que reconozca el navegador (La tuya es la referencia terminada en "S"): Coding (from Index L) Byte 00 Bit 0 [01] Engine Electronics Byte 00 Bit 1 [11] Engine Electronics II Byte 00 Bit 2 [02] Transmission Electronics Byte 00 Bit 3 [03] Brake Electronics (ABS) Byte 00 Bit 4 [53] Parking Brake Byte 00 Bit 5 [04] Steering Angle Sensor (G85) Byte 00 Bit 6 [44] Steering Assist Byte 00 Bit 7 [15] Airbags Byte 01 Bit 0 [55] Xenon Range Byte 01 Bit 1 [22] All Wheel Drive Byte 01 Bit 2 [13] Distance Regulation Byte 01 Bit 3 [14] Suspension Electronics Byte 01 Bit 4 [4C] Tire Pressure Monitoring II Byte 01 Bit 5 [10] Park/Steering Assist Byte 01 Bit 6 [32] Differential Locking Byte 01 Bit 7 [17] Instrument Cluster Byte 02 Bit 0 [25] Immobilizer Byte 02 Bit 1 [09] Central Electronics Byte 02 Bit 2 [46] Central Convenience Byte 02 Bit 3 [42] Door Electronics (Driver) Byte 02 Bit 4 [52] Door Electronics (Passenger) Byte 02 Bit 5 [62] Door Electronics (Rear Left) Byte 02 Bit 6 [72] Door Electronics (Rear Right) Byte 02 Bit 7 [36] Seat Memory (Driver) Byte 03 Bit 0 [65] Tire Pressure Monitoring Byte 03 Bit 1 [16] Steering Wheel Electronics Byte 03 Bit 2 [08] Climate Control Byte 03 Bit 3 [76] Park Assist Byte 03 Bit 4 [7D] Auxiliary Heating Byte 03 Bit 5 [26] Auto Roof Byte 03 Bit 6 [69] Trailer Byte 03 Bit 7 [06] Seat Memory (Passenger) Byte 03 Bit 0 [3D] Special Function Byte 04 Bit 1 [6D] Trunk Electronic Byte 04 Bit 2 [63] Easy Entry Driver Side Byte 04 Bit 3 [73] Easy Entry Passenger Side Byte 04 Bit 4 [47] Sound System Byte 04 Bit 5 [75] Telematic/Emergency Call Byte 04 Bit 6 [37] Navigation Byte 04 Bit 7 [57] TV-Tuner Byte 05 Bit 0 [0F] Radio (digital) Byte 05 Bit 1 [56] Radio (analog) Byte 05 Bit 2 [77] Telephone Byte 05 Bit 3 [18] Auxiliary Heater Byte 05 Bit 4 [1C] Position Sensing Byte 05 Bit 5 [5D] Operations Byte 05 Bit 6 [6C] Rear View Camera Byte 05 Bit 7 [59] Tow Protection Byte 06 Bit 0 [4F] Central Electronics II Byte 06 Bit 1 [19] CAN-Gateway (Standard) Byte 06 Bit 2 [3C] Lane Change Assist Byte 06 Bit 3 [5C] Lane Maintenance Assist Byte 07 Manufacturer/Model Byte 08 Options Por otra parte, en el módulo 16 creo deberías confirmar que está bien codificado sin teléfono: 00?xxxx: Transmission0 = Manual Transmission 1 = Automatic Transmission [*]00x?xxx: Steering Wheel 0 = 3-Spoke, w/o Tiptronic, w/o Multi-Function 1 = 3-Spoke, with Tiptronic, w/o Multi-Function 2 = 4-Spoke Multi-Function (with Radio Control) 3 = 4-Spoke Multi-Function (with Radio/Telephone Control) 4 = 4-Spoke Multi-Function (with Radio/Telephone/Voice Control) [*]00xx?xx: Tiptronic/Heating +1 = Tiptronic on Steering Wheel[*]00xxx?x: Cruise Control/Board Computer 0 = no Board Computer, no Cruise Control 1 = Board Computer, no Cruise Control 2 = no Board Computer, Cruise Control 4 = Board Computer, Cruise Control [*]00xxxx?: Rear Wiper 0 = w/o Rear Wiper 1 = with Rear Wiper A ver si te sirve de ayuda... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
templario88 Publicado 21 de Febrero del 2013 Autor Denunciar Compartir Publicado 21 de Febrero del 2013 (editado) Ok, gracias por las respuestas Juan252 la centralita getway es la original alomejor como fue de los primeros restylings me montaron la atigua no lo se, llame a la audi y se puede actulizar pero me cobran como 1 hora (84€) un poco caro a las malas lo are. Eryayi si que puedo entrar y ya lo hecho en el modulo 37 en principio lo he configurado todo pero siguen esos fallos lo que me parecia raro es que no me aparece el globo de informacion de los codigos lo he tenido que hacer atraves de otros post del foro intentare a ver si puedo quitar lo del telefono.. gracias Editado 21 de Febrero del 2013 por templario88 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
eryayi Publicado 21 de Febrero del 2013 Denunciar Compartir Publicado 21 de Febrero del 2013 Lo de la referencia del can gateway yo tengo la misma pero terminada en "P" y es un A3 del 2008. Si consigues solucionar el poblema de la bateria mantennos informados. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
