Errores en mi Audi
denis a4
Pues hoy me ha pasado un amigo del foro el VAG.COM y estos son los errores que me han salido:
Alguien sabe como los puedo arreglar?
Chassis Type: 8T0
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 55 56 62 72 77
VIN: WAUZZZ8KX9A074621 Mileage: 71020km/44129miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JM HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3173
Revision: 11H01---
Coding: 0104002C18072020
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TDI03L906022JM A01005
ROD: EV_ECM20TDI03L906022JM.rod
VCID: 79FDE9D74B19
1 Fault Found:
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - No Signal/Communication
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 70720 km
Date: 2013.02.26
Time: 20:22:33
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 160500
VCID: 78FBECD37013
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 A HW: 8K0 907 064 A
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030100
VCID: 2E570A8BC2D7
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
Component: KLIMA 1 ZONE H06 0140
Revision: A0000000 Serial number: 0114.07.081364
Coding: 34000000
VCID: 428F4E3B664F
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000182811
Coding: 260050914034AF000001000000001D0D0F1C030800010101000000
VCID: 2F69178FC5DD
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119
Component: WWS 100708 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 C HW: 8K0 941 531 C
Component: E1 - LDS H07 0070
1 Fault Found:
00379 - Terminal 58s
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 230
Mileage: 71029 km
Time Indication: 0
Date: 2013.03.03
Time: 11:14:00
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD17J2G2
Coding: 30343434363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7330C304AB
Driver's Airbag Crash Sensor:
Serial number: 6334MSME38736B6CT
Passenger Side Airbag Crash Sensor:
Serial number: 6344MSME3F26091DN
Driver's Rear Airbag Crash Sensor:
Serial number: 6352QSME7B533515H
Passenger's Rear Airbag Crash Sensor:
Serial number: 6362QSME7A0D1723L
Driver's Front Airbag Crash Sensor:
Serial number: 63732SME77101D7D5
Passenger's Front Airbag Crash Sensor:
Serial number: 63832SME77103D21Y
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HG8000KJ
Coding: 000012
VCID: 3D753DC71FB1
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 C HW: 8K0 920 900 C
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 98V21Z878
Coding: 0F04080002000008050000
VCID: 2A5F069BFE3F
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0871185C2
Coding: 000303
VCID: 4687522B4A67
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007436108
Coding: 011C02204100410001
VCID: 3F8947CF15BD
1 Fault Found:
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 5
Mileage: 70720 km
Time Indication: 0
Date: 2013.02.26
Time: 20:22:37
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0112709981
Coding: 0100062000390040012001
VCID: 2E570A8BC2D7
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007470634
VCID: 3E773ACB12B7
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 5
Mileage: 70720 km
Time Indication: 0
Date: 2013.02.26
Time: 20:22:37
00110 - Right Mirror Turn Signal Lamp (L132)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 161
Reset counter: 5
Mileage: 67390 km
Time Indication: 0
Date: 2012.11.22
Time: 14:51:33
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000173153
Shop #: WSC 00000 000 00000
VCID: 316D11F7D3E9
1 Fault Found:
03200 - Switch for Electric Parking Brake (E538)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 70720 km
Time Indication: 0
Date: 2013.02.26
Time: 20:26:32
Freeze Frame:
Voltage: 14.10 V
Count: 11
Speed: 0.0 km/h
Hex Value: 0x0262
Hex Value: 0x0011
Hex Value: 0x1010
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 346318E32CFB
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 156
Mileage: 62296 km
Time Indication: 0
Date: 2012.08.16
Time: 03:31:21
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 C HW: 8T1 035 186 C
Component: Concert3 H02 0310
Revision: 00000004 Serial number: AUZ5Z6H1092800
Coding: 05000482040105000159070000
Shop #: WSC 02231 572 88480
VCID: 37792FEF3D8D
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
2 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 71029 km
Time Indication: 0
Date: 2013.03.03
Time: 11:13:22
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 71029 km
Time Indication: 0
Date: 2013.03.03
Time: 11:13:22
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007388675
Coding: 010C02204000210001
VCID: FF0987CFD53D
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007415281
VCID: FEF77ACBD237
Address 77: Telephone Labels: None
Part No SW: KTC 364 31P HW: KTC 364 31P
Component: SWP:3.21.9 H24 0199
Revision: 00000000 Serial number: 00000000000000
Shop #: WSC 21977 142 74100
VCID: 33611BFF29F5
End ---------------------------------------------------------------------
has probado borrarlos desde cada módulo en cuestión?. Es decir, entras por ejemplo en el modulo 9, tienes un botón para ver los errores de ese módulo y puedes borrarlo. Lo digo, porque a mí cuando me han salido errores a veces he tenido que borrarlos así. Y los errores que te dan parece un fallo de comunicación...
Suerte
