Error VagCom
FabianESP
Buenas a todos, seria genial si pudieseis ayudarme con unos problemas que tengo en mi Audi A4 B8 1.8 TFSI 160Cv. Le pase el escaner VagCom porque me salto un problema de anomalía de iluminación del vehículo. Tras realizar el escaner me retornó los siguientes resultados.
Wednesday,09,December,2020,22:01:39:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8K59N024511   License Plate:
Mileage: 166760km-103619mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 40 42 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K59N024511   Mileage: 166760km/103619miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
40-AC Compressor -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 A    HW: 8K0 907 064 A
   Component: BCM2 1.1      H80 0141
   Revision: 00002001
   Coding: 030100
   Shop #: WSC 02399 823 56573
   VCID: 2E53E83379E29E6E36F-807B
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H37 0060
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: ELVAUDIB8  H36 0041
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
            013 - Check DTC Memory
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 A    HW: 8K0 907 063 A
   Component: BCM1 1.0      H22 0253
   Revision: 02022001    Serial number: 00000000103444
   Coding: 690040B10034A7010001000000005F5F0F1C020800000101000000
   VCID: 2D51EF3F74E4E5760F5-8078
   Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 200808  H06 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 025028
2 Faults Found:
01800 - Light Switch (E1)
            004 - No Signal/Communication
03280 - Switch Position of Light-Switch Knob
            008 - Implausible Signal
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90315HHS000EH
   Coding: 000012
   VCID: 3D71DF7FA48475F6BF5-8068
   Component: E221 - MFL  H02 0003
1 Fault Found:
00457 - Control Module for Network (J519)
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0113853706
   Coding: 0100062000390040013001
2 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000081934
   Shop #: WSC 00000 000 00000
   VCID: 3169F34F68DC81962BD-8064
1 Fault Found:
03182 - Clutch Position Sensor (G476)
            007 - Short to Ground
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 C    HW: 8T1 035 186 C
   Component: Concert3      H02 0310
   Revision: 00000004    Serial number: AUZ5Z6H1111038
   Coding: 05020082010185000159070000
   VCID: 377DCD5786B85FA6659-8062
1 Fault Found:
02259 - Information Display and Control Head (Front) (J685)
            011 - Open Circuit
Address 77: Telephone        Labels: 8P0-862-335.lbl
   Part No SW: 8T0 862 335 C    HW: 8T0 862 335 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005026640
   Coding: 0010350
   Shop #: WSC 02145 785 00200
   VCID: 3A7BD46375AA42CE9A7-806F
1 Fault Found:
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
Sería genial que me pudieseis echar una mano para poder solventarlo, suelo hacerle todo al coche por mi mismo pero no encuentro suficiente información al respecto de las fallas. Las de Open circuit si estan claras, debe tener el cable de la radio suelto o algo similar pero me preocupan mas el resto. Un saludo y muchas gracias de antemano, espero que con vuestra ayuda pueda solventarlo.
