alfo1971as
Todo lo publicado por alfo1971as
Problemas en el cuadro y no arranca coche
alfo1971as responde a alfo1971as de discusión en Electricidad Audi A4 B6/B7
Muchas gracias Carlisu84, hare todo lo que me dices y te ire dando novedades con los avances Buen domingo -
Actualizo con los datos de diagnosis Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06D-906-018-AWA.lbl Part No SW: 8E0 906 018 K HW: Hardware No Component: 2.0L R4/4V FSI 0008 Shop #: WSC 63351 512 00000 VCID: 306FA5C7A0235A0D32-5178 VINID: 9D196AAAA2151434431831461C85C34ACB Subsystem 1 - Part No: 8E0 907 807 A Component: NOX 0302170139 002 3205 8E0907807 A NOX 0302170139 002 3205 4 Faults Found: 18058 - Powertrain Data Bus P1650 - 004 - Missing Message from Instrument Cluster 19648 - Intake Manifold Runner Control P3192 - 008 - Basic Setting Aborted - Mech. Stop Closed 18043 - Powertrain Data Bus P1635 - 008 - Missing Message from A/C Controller 17978 - Engine Start Blocked by Immobilizer P1570 - 008 - Readiness: 1010 0001 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 3429 Coding: 04275 Shop #: WSC 06435 VCID: 65C10493FF61CFA511-515A 2 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-00 - - ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 H Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 VCID: 2643439FC2E704BDD8-515A 3 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications 00474 - Control Module for Immobilizer 49-00 - No Communications 00474 - Control Module for Immobilizer 27-00 - Implausible Signal ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul RDW 0416 Coding: 01001 Shop #: WSC 63351 VCID: 356194D30F417F2561-4B18 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 B Component: Airbag 8.4EP 2000 Coding: 0010602 Shop #: WSC 63351 000 00000 VCID: 366393DF4247743D68-5178 1 Fault Found: 00474 - Control Module for Immobilizer 004 - No Signal/Communication - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 N Component: Lenks·ulenmodul 0308 Coding: 02011 Shop #: WSC 63351 VCID: 3E738BFF3A77BC7DB0-4B18 3 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications 01304 - Radio 49-00 - No Communications 00474 - Control Module for Immobilizer 49-00 - No Communications ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0604 Coding: 00001 Shop #: WSC 00000 VCID: 6BD572AB1985F9D547-5178 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb Part No: 8E0 959 433 BC Component: Komfortger·t T3B 1211 Coding: 02656 Shop #: WSC 63351 VCID: 73E56ACB41B521158F-4B18 Subsystem 1 - Part No: 8E1959801 Component: Tırsteuer.FS BRM 0003 Subsystem 2 - Part No: 8E1959802E Component: Tırsteuer.BF BRM 0003 Subsystem 3 - Part No: 8E0959801A Component: Tırsteuer.HL BRM 0003 Subsystem 4 - Part No: Steuerger Component: t HR antwortet nicht 4 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications 00956 - Key 2 35-00 - - 01559 - Drivers Door 61-00 - Won't De-Safe 01562 - Rear right door 61-00 - Won't De-Safe End-------------------------(Elapsed Time: 06:00)-------------------------- -
alfo1971as publicó una discusión en Electricidad Audi A4 B6/B7
Buenas tardes Desde hace unos dias, cuando intento arrancar el coche arranca y se para, he cambiado la bateria y he puesto una nueva, he comprobado que la llave esta codificada correctamente Os doy detalles y adjunto video de lo que sucede, meto la llave en la puerta y el cuadro no enciende nada, luego meto llave en bombin y se encienden dos luces el el cuadro tras girar la llave pero los KM y mas dispositivos no se encienden tal y como se ve en el video, doy las luces o los intermitente y funcionan perfectamente pero en el cuadro no se refleja, me esta volviendo loco de que puede estar pasando. Me podeis ayudar, muchas gracias Adjunto video en Youtube -
Ayuda: Cuadro apagado -> Coche no arranca
alfo1971as publicó una discusión en Audi A4 B6/B7 (2002-2008)
Buenas tardes compañeros, Tengo un audi a4 b6 2.0 fsi que no lográ arrancar. Al entrar en el coche, el cuadro esta como apagado salvo dos testigos (ESP y otro más) y hace el amago de arrancar pero al segundo se para. La batería es nueva y el coche tiene electricidad, pero debe de ser algo eléctrico ahora que han venido las humedades... ¿Se os ocurre que puede estar pasando? En cuanto vuelva de viaje le haré un diagnostico con el VAG-COM y añadiré foto del cuadro. Algo muy parecido a esto -
Cambio de embrague - a4 b6 1.9 tdi
alfo1971as responde a alfo1971as de discusión en Mecánica Audi A4 B6/B7
gracias por la info montare LUK -
Buenas compañeros Necesito de vuestra sabiduría, tras realizar a mi a4 b6 de diciembre del 2001 "AWX" 370M KM ya ha llegado el momento de cambiar el embrague, cualquier dia me deja en la cuneta...... Dos preguntas: Que taller me recomendaís por la zona de móstoles, alcorcon o alrededores para su cambio, con buena calidad precio Entiendo que ademas del embrague tendre que cambiar el volante bimasa por los KM que ya he realizado, ¿hay alguno mas que sea necesario cambiar? Muchas gracias anticipadas
Buenas tardes a todos alguien por boadilla que me deje un vagcom para A4 B6? Muchas gracias y felices reyes
Error en el cuadro a4 b6 2.0 FSI
Noo no marca nada de nada y cuando meto la llav solo enciende 2 testigos del cuadro Eres de Madrid?? -
No noo marca nada de nada ni el fis ni el cuentakilometros. he mirado fusible que estan en lado conductor a la izquierda y todos OK -
A que te refieres con te marca las cerraduras al abrir la puerta Gracias -
Buenas comprobado esta seco y bateria nueva -
Hola tengo un problema y tiene toda la pinta de ser algo eléctrico He cambiado la bateria y la alarma suena sn parar, meto la llave y en el cuadro solo se ilumina el testigo de ESP y ABS el resto no se enciende nada de nada Alguien sabe que puede pasar?? Muchas gracias
Buenas ya esta resuelto fue algo eléctrico y se soluciono solo es como que pillo humedad o algo asi
Muchas gracias por la ayuda os ire informando de los resultados
Donde esta la caja de agua y tienes algún brico para del cuadro? Gracias
He probado lo que me haa comentado y nada al salir todo el rato el tiempo para inspeccionar el coche no deja y lo mas curioso es que al montarme en el coche esro aparece en el cuadro, esto sin meter la llave y ayer no le pasaba, parece algo eléctrico
No deja el boton del check no te deja ya que esta en el fis sacando cuando hay que pasar la inspección, es como un fallo eléctrico quizas con un vagcoom podria ver algo pero no tengo alguien me podria ayudar? Gracias
Buenas noches me ha pasado algo muy raro y es que cuando pongo la llave en el contacto la aguja del velocimetro se queda en 10 KM con el coche apagado, ademas cuando arranco el fis se enciende con el control de velocidad 1 activo y el tiempo que me queda para la inspeccion y no se pone en modo normal Alguien me puede ayudar Muchas gracias
Buenas necesito de vuestro conocimiento y ayuda Hoy poner la llave en el contacto el velocimetro no marca 0 sube a 10 ademas cuando arranco esta activo el control de velocidad y no me deja desactivarlo, parece un tema electrico pero no se que puede pasar, no tengo Vag Com, ademas las llaves se han desconfigurado y cuando cierro el cocche desde el mando las ventanillas no se suben. Me puede ayudar alguien?? Mil gracias
lo que se ve brillante es que se ha partido de una pieza de metal sabes si eso afecta a algo, el coche va bien o al menos eso parece Es un a4 B6 TDI 130
Hola hoy en un bordillo he roto una pieza que esta en la aprte de abajo cerca del cartel Sabeis para que sirve Adjunto foto
Y sabes como puedo ver el nivel de la valvulina?? Gracias
Buenos dias Si lo detecte hace una semana, desmonte la tapa del motor de la parte de abajo para ver la cantidad que perdia y la fuga esta a la altuta más o menos un poco despues del radiador, llevo un 1.9 TDI de 130 Manual Sabes como puedo ver si lo que pierdo es aceite de la caja de cambios?? como puedo mirar el nivel La caja de cambios lleva reten??? Mil gracias
