Cobrabf
Todo lo publicado por Cobrabf
  1. Datos: - El coche se me quedo sin bateria. - Me sale en el cuadro FIS la advertencia de la regulaccion automatica de faros. Dudas. - Que puedo hacer para solucionar esto. - ¿Pasa algo si borro los fallos todos?
  2. VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 JL Component: 1,9l R4 EDC 0000SG 1519 Coding: 00002 Shop #: WSC 63351 WAUZZZ8EX2A243973 AUZ6Z0B0008174 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-10 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 8E0 820 043 A Component: A4 Klimaautomat 1012 Coding: 00000 Shop #: WSC 63351 3 Faults Found: 01810 - Actuating Motor for Temperature Flap: Right (V159) 41-10 - Blocked or No Voltage - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to B+ - Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00011 Shop #: WSC 63351 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00011 Shop #: WSC 63351 1 Fault Found: 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent Address 17 ------------------------------------------------------- Controller: 8E0 920 900 G Component: KOMBI+WEGFAHRS. RB4 D26 Coding: 00000 Shop #: WSC 04243 WAUZZZ8EX2A243973 AUZ6Z0B0008174 2 Faults Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent 01304 - Radio 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AG Component: Komfortgerát T87 0315 Coding: 06720 Shop #: WSC 63351 3 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent 01331 - Door Control Module: Driver Side (J386) 80-10 - Single-Wire Operation - Intermittent 01332 - Door Control Module: Passenger Side (J387) 53-10 - Supply Voltage Too Low - Intermittent Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00060 Shop #: WSC 63351 3 Faults Found: 01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49) 30-00 - Open or Short to B+ 01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48) 30-00 - Open or Short to B+ 00532 - Supply Voltage B+ 07-10 - Signal to Low - Intermittent End -------------------------------------------------------
  3. Supongo que se referirán a los autoniveladores de altura de los faros de xenon. Saludos. Eses mismos que me traen por el camino de la amargura?ejejjee
  4. Le pase el vagcom. Y me dio la repera de fallos. Todos ellos relacionados con Voltaje o intensidad. Luego a la tarde intento colgar el log de errores. Para ver si alguien me puede decir si son fallos temporales o es que quedaron grabados al descargarse la bateria y pasa algo si los borro.
  5. Gracias, intentare pasarle el vagcom ahora para ver que tal. Graciasssssss
  6. Pues eso, el faro de xenon que compre el otro dia para cambiarle a mi coche por lo del golpe. Parpadea un poco, como una luz de neon cuando esta a punto de fundirse, lo hace solo al poco tiempo de encenderse. Otra cosa que note en ese foco es que se empaña un poco :shocked: Y la gran put*da es que no puedo reclamar en la audi porque me diran que es culpa del montaje. jod**, me parece que tengo coche para meses de arreglo de un lado y de otro.
  7. Cobrabf
    problemas instalacion
    vagcom instalado y me detecta el coche, pero no me deja hacer algunas acciones me dice que tiene que estar registrado. Como lo registro? tengo el keygen pero no me pidio ninguna clave ni nada :clap1: Gracias
  8. nadie??
  9. vilanova ..... fariña city jejeje
  10. Cobrabf
    rs4
    si es cierto a mi tambien me da envidia, pero no por eso hay que criticar a nadie. Luismy ni put* caso <_<
  11. Pues eso. Ahora al recojerlo en el chapista. Tiene encencido una luz de regulacion de altura de faros encendida en el FIS Me puso tambien la advertencia de luz de freno central. Y la primera vez que arranque puso frenos. la unica que quedo permanente es la de regulacion de altura de faros. Que puede ser? como dato, anoto que se quedo sin bateria y se arranco con pinzas.
  12. :clap1: Ay! Que me emocionooooo! :clap1: El sentimiento es mutuo!!! Como que no queremos recibir nada a cambio? Y tus post s..uales que? Uno al mes minimo, ehhh! A cuidarse amigo! jajajajajajajaj mu weno, xD
  13. Pa la semana estoi de vacacions.
  14. FERRARI 340 VIGNALE
  15. Gracias gente Sinceramente gracias. :clap1: :crying_anim: :clap1: :clap1:
  16. Deje el coche en el taller el otro dia por lo de arreglar el golpe, y ayer al ir vi que estaba sin bateria, no le dije nada al tio, pero supongo que la cambiara antes de darmelo no? O si no la cambia, es recomendable que la cambie yo? es posible que se vuelva a agotar? Cual puede ser el motivo de que se descargara? Supuestamente se deberia hacer cargo el del taller de la reparación o no? Y recomendarme marcas por si las moscas tengo que cambiarla yo. Gracias. PD: espero no quedarme nunca tirado por ahi, cruzo dedos, que ya me espero de todo.
  17. Cada dia me siento mas agusto de pertenecer ASI. Me siento acojido, lo forman unos foreros estupendos, y esta lleno de gente dispuesta a dar sin querer recibir nada a cambio. Un dia me senti agraciado, susopampin me dejo una llave que para mi era imposible de conseguir, gracias suso, espero poder dartela en Lalin. Cuando tuve el golpe, me animasteis bastante, y el forero Tineo me regalo una de las piezas que me hacian falta para reparar el coche. Gracias Tineo, gracias gracias gracias. El foro esta lleno de gente impresionante. Podria decir algunos nombres: Mark, Galliani, mil_ocho_t , susopampin, Xan, Arlong, Josema, abuelo, Luiso, Danielon, Lctr, Tineo ........ y un largo larguisimo etc (Mil perdones a los que no nombré, sois muchos :clap1: ) Gracias por ser ASI :clap1:
  18. no, el rojo es mas rojo que eso, xD
  19. yo escojia una tonalidad que no exista en audi , aunque se asemeje a los demas, un toque individual
  20. Te gusta culear en las curvas ehhhhhhhhh, xD
  21. tan dificil esta?
  22. Las rs4 son feisimassssssssssss
  23. Voi a intentar aclararte tus dudas. Necesitas traer una factura con nº de identificacion internacional del vendedor. Necesitas traer la documentacion alemana del coche. Necesitas traer una ficha reducida, (es como una ficha de homologacion) del coche, y si no la tienes o no te la consiguen en alemania, la puedes hacer en españa por unos 100€, pero si insistes al vendedor el te la consigue e incluso te tramita las placas temporales, y el seguro por 15 dias. Respecto a la forma de pago, la mas rapida y fiable, es llevar el dinero encima. Si tienes que hacer transferencia, te puede tardar sobre 3 dias en llegar el dinero alla, y no es plan de estar esperando 3 dias para poder cojer tu coche. Yo cuando fui lo lleve encima, mi tio, tambien, mi jefe tambien. Llevabamos entre todos mas de 100.000€, y no nos atracaron jejeje, no te preocupes, solo tu sabes que llevas el dinero, llevas un justificante del banco conforme el dinero es tuyo, por si te lo detectan en aduanas, y listo. Cualquier duda mas, no dudes en preguntarme y si puedo te la contestare.
  24. jooooooooooo yo tambien quierooooooooo jejejejeje Que envidia me das
  25. va una facilisisisisisisima.
