Ragtop
Todo lo publicado por Ragtop
  1. Ragtop
    Novitec Rosso
  2. Ragtop
    Novitec Rosso
  3. Ragtop
    Novitec Rosso
  4. Ragtop
    Novitec Rosso
  5. Ragtop
    Novitec Rosso
  6. Ragtop
    Novitec Rosso
    F430 y F430 Spider NOVITEC SPORT Bi-compressor F1 430 02 including 2 supercharger with separated oil-circuit, modified induction tract complete heat-insulated, watercooled intercoolers with additional watercoolers, pumps, reinforced v-ripped belts, injectors, oil cooler as well as modified ECU‘s performance: 468 kW (636 hp) / 8.200 rpm max. boost-pressure: 0,35 bar max. torque: 638 Nm / 6.250 rpm Vmax: 348 km/h (in combination with NOVITEC gear-ratio) 0 – 100 km/h: 3,7 sec By the installation of the NOVITEC Bi-compressor system, it could necessary to change wear parts according to the mileage. NOVITEC power stage 2 F1 430 05 consisting of an air flow optimising Carbon Airbox including two sport air filters as well as a new adjusted engine electronic with modified group of curves and higher cutoff speed to 8.850 rpm (thereby higher end-speed). In addition a stainless steel exhaust system in combination with sport metal catalysts (100 Zeller) with reduced exhaust back pressure performance: 382 kW (520 hp) / 8.600 rpm max. torque: 490 Nm / 5.350 rpm Vmax: + 6 km/h For this performance step new ECU’s can be purchased. The original ones would remain with the owner and would not be reprogrammed.
  7. Ragtop
    Novitec Rosso
  8. Ragtop
    Novitec Rosso
  9. Ragtop
    Novitec Rosso
  10. Ragtop
    Novitec Rosso
  11. Ragtop
    Novitec Rosso
  12. Ragtop
    Novitec Rosso
  13. Ragtop
    Novitec Rosso
  14. Ragtop
    Novitec Rosso
  15. Ragtop
    Novitec Rosso
  16. Ragtop
    Novitec Rosso
  17. Ragtop
    Novitec Rosso
  18. Ragtop
    Novitec Rosso
  19. Ragtop
    Novitec Rosso
  20. Ragtop
    Novitec Rosso
  21. Ragtop
    Novitec Rosso
    360 Modena y Spider Para el 360 hay dos preparaciones disponibles: F1 360 02 NOVITEC SUPERSPORT Bi-compressor including 2 supercharger with modified turbine-blades and separated oil-circuit, modified induction tract complete heat-insulated, watercooled intercoolers with additional watercoolers, pumps, reinforced v-ripped belts with dynamic belt- tensioners, injectors, modified motronic in combination with NOVITEC- tectronic and Carbon airfilter-housing. performance: 446 kw (606 hp) / 8.600 rpm max. boost-pressure: 0,61 bar max. torque: 615 Nm / 6.250 rpm Vmax: 344 km/h (in combination with NOVITEC gear-ratio) 0 - 100 km/h: 3,7 sec F1 360 05 NOVITEC SPORT Bi-compressor including 2 supercharger with separated oil-circuit, modified induction tract complete heat insulated, watercooled intercoolers with additional watercoolers, pumps, reinforced v-ripped belts with dynamic belt-tensioners, injectors, modified motronic in combination with Novitec-tectronic and Carbon airfilter-housing. performance: 408 kw (555 hp) / 8.100 rpm max. boost: 0,48 bar max. torque: 562 Nm / 6.250 rpm Vmax: 335 km/h (in combination with NOVITEC gear-ratio) 0 - 100 km/h: 3,9 sec
  22. Ragtop
    Novitec Rosso
    En este hilo Javirex nos presentaba el F430 Spider Novitec. Ahora veremos lo que son capaces de hacer los chicos de Novitec sobre el resto de modelos de la gama Ferrari.
  23. Ragtop
    Audi RS5
  24. Ragtop
    Volvo XC60
  25. Ragtop
    Volvo XC60
