wenas tengo un a3 8p cpon sensores de parking traseros
suena muy flojito y me gustaria saber si se puede dar volumen y como se hace
es de serie y suena desde la parte traserami coche es del finales de 2003
un saludo y gracias
Pues a mi me pasa to lo contrario, cada vez q tengo q dar la marcha atras lo temo, xq me deja tonto de lo alto que suena... asiq tambien me vendria bien saberlo.
Un saludoO!
con vagcom se puede configurar el volumen y demas:
Aqui os dejo la adaptacion del modulo 76 (parking Aid).
Adaptation
Rear Buzzer Volume
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 001
[Read]
Adaptation of the rear warning buzzer volume.
Range: 1...9
[Test]
[save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Rear Buzzer Frequency
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 002
[Read]
Adaptation of the rear warning buzzer frequency.
Range: 1...9
[Test]
[save]
[Done, Go Back]
Front Buzzer Volume
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 003
[Read]
Adaptation of the front warning buzzer volume.
Range: 1...9
[Test]
[save]
[Done, Go Back]
Front Buzzer Frequency
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 004
[Read]
Adaptation of the front warning buzzer frequency.
Range: 1...9
[Test]
[save]
[Done, Go Back]
Confirmation Sound
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 005
[Read]
Adaptation of confirmation sound when switching into reverse gear.
* 0 = Confirmation Sound inactive
* 1 = Confirmation Sound active
[Test]
[save]
[Done, Go Back]
Factory Defaults
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 006
[Read]
To reset all values to factory defaults, save 0 as new value.
[Test]
[save]
[Done, Go Back]
espero que os sirva, un saludo :thumbsup:
Adaptation
Rear Buzzer Volume
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 001
[Read]
Range: 1...9
[Test]
[save]
[Done, Go Back]
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 002
[Read]
Range: 1...9
[Test]
[save]
[Done, Go Back]
Front Buzzer Volume
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 003
[Read]
Range: 1...9
[Test]
[save]
[Done, Go Back]
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 004
[Read]
Range: 1...9
[Test]
[save]
[Done, Go Back]
Confirmation Sound
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 005
[Read]
[Test]
[save]
[Done, Go Back]
Factory Defaults
[select]
[76 - Parking Aid]
[Adaptation - 10]
Channel 006
[Read]
[Test]
[save]
[Done, Go Back]
Muxas gracias Nextro, asi da gusto!! jejje
Un saludo!!
