jcarmona Publicado 4 de Mayo del 2016 Denunciar Compartir Publicado 4 de Mayo del 2016 (editado) estimados,alguien me ayuda a interpretar este log? Wednesday,13,April,2016,10:42:41:12173 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 15.7.4.1 (x64) Data version: 20160216 www.Ross-Tech.com VIN: WAUZZZ8E*********** License Plate: WY7077 Mileage: 111220km-69108mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E********* Mileage: 111220km-69108miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.clb Part No SW: 8E0 910 115 L HW: 8E0 907 115 D Component: 2.0l R4/4V TFSI 0060 Revision: 5EH15--- Serial number: Coding: 0104000002070120 Shop #: WSC 06324 602 57308 VCID: 2A51F1D585D0A46E00-807E 4 Faults Found: 000665 - Boost Pressure Regulation P0299 - 002 - Control Range Not Reached Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 10 Reset counter: 255 Mileage: 109772 km Time Indication: 0 Freeze Frame: RPM: 2557 /min Load: 67.0 % Speed: 84.0 km/h Temperature: 84.0°C Temperature: 28.0°C Absolute Pres.: 950.0 mbar Voltage: 13.589 V 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 9 Reset counter: 255 Mileage: 110496 km Time Indication: 0 Freeze Frame: RPM: 3417 /min Load: 96.0 % Speed: 50.0 km/h Temperature: 85.0°C Temperature: 38.0°C Absolute Pres.: 940.0 mbar Voltage: 13.335 V 000770 - Cylinder 2 P0302 - 001 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 9 Reset counter: 255 Mileage: 110496 km Time Indication: 0 Freeze Frame: RPM: 3417 /min Load: 96.0 % Speed: 50.0 km/h Temperature: 85.0°C Temperature: 38.0°C Absolute Pres.: 940.0 mbar Voltage: 13.335 V 012555 - Low Pressure Fuel regulation P310B - 004 - Fuel Pressure Outside Specification - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 3 Reset counter: 255 Mileage: 110715 km Time Indication: 0 Freeze Frame: RPM: 795 /min Load: 23.9 % Speed: 0.0 km/h Temperature: 99.0°C Temperature: 66.0°C Absolute Pres.: 940.0 mbar Voltage: 13.081 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 8E3 910 155 Q HW: 01J 927 156 HT Component: V30 01J 2.0TFSI RdW 0010 Revision: 00000012 Serial number: 00000002035184 Coding: 0000001 Shop #: WSC 04940 001 00001 VCID: 3669D5A54168F08E94-8062 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.clb Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF Component: ESP8 FRONT H06 0140 Revision: 00000000 Serial number: 00000000000000 Coding: 0004525 Shop #: WSC 06325 000 00000 VCID: 2C5DF7CD8F24BA5EF2-8078 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BL Component: A4 Klimaautomat 2833 Coding: 00000 Shop #: WSC 06325 VCID: 6CDD37CD1CA47A5EB2-5102 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 N Component: int. Lastmodul ECE 0907 Coding: 01031 Shop #: WSC 65536 VCID: 3D7BCA89375E23D655-4AE6 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H12 3730 Revision: 91H12373 Serial number: 0036M0G3CHRK Coding: 0031612 Shop #: WSC 06325 000 00000 VCID: 3B7FC4917A4A2DE66B-806E Subsystem 1 - Serial number: 6332DRB403E34D97- Subsystem 2 - Serial number: 6342DRB403E44E17V Subsystem 3 - Serial number: 6352ARB4018B99FB3 Subsystem 4 - Serial number: 6362ARB4018C833EW Subsystem 5 - Serial number: 63729RB4019C445EW Subsystem 6 - Serial number: 63829RB4019C4484Q 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 58 Reset counter: 39 Time Indication: 0 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0701 Coding: 02141 Shop #: WSC 06325 VCID: 4183B6794BA6473631-4AE6 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 931 Q HW: 8E0 920 931 Q Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0006111 Shop #: WSC 06324 602 999999 VCID: 3669D5A54268F08E94-5120 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 931 Q HW: 8E0 920 931 Q Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0006111 Shop #: WSC 06324 602 999999 VCID: 3669D5A54268F08E94-5120 No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 VCID: 6BDF34D119AA7D66BB-5120 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CH Component: Komfortgerát T3B 4135 Coding: 07790 Shop #: WSC 10005 VCID: 79F31E9963F6DFF639-4B00 Subsystem 1 - Part No: 8E1959801H Component: Tõrsteuer.FS BRM 0606 Subsystem 2 - Part No: 8E1959802H Component: Tõrsteuer.BF BRM 0606 Subsystem 3 - Part No: 8E0959801E Component: Tõrsteuer.HL BRM 0606 Subsystem 4 - Part No: 8E0959802E Component: Tõrsteuer.HR BRM 0606 5 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H02 0010 Revision: 00000001 Serial number: Coding: 0000005 Shop #: WSC 00011 602 22417 VCID: 3D7BCA89645E23D655-8068 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8J0-035-1xx-56.clb Part No SW: 8E0 035 195 AC HW: 8E0 035 195 AC Component: R Symphony2+ H02 0070 Revision: 00H02000 Serial number: AUZ1Z4F2835304 Coding: 0230112 Shop #: WSC 06325 000 00000 VCID: 68D54BDD585C567ED6-5120 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl Part No SW: 8E0 919 283 D HW: 8E0 919 283 D Component: Parkhilfe 4-Kan H06 0010 Revision: 00H06000 Serial number: 00067802020625 Coding: 0001104 Shop #: WSC 06325 000 00000 VCID: 3163E6B9AB06D7B6C1-5120 No fault code found. End-------------------------(Elapsed Time: 05:57)-------------------------- Editado 8 de Mayo del 2016 por Serjio Eliminar numero bastidor Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Carlisu84 Publicado 5 de Mayo del 2016 Denunciar Compartir Publicado 5 de Mayo del 2016 borra los fallos y vuelve a pasar el Scan haber que dice. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
COLLECTED Publicado 5 de Mayo del 2016 Denunciar Compartir Publicado 5 de Mayo del 2016 Aquí todos los fallos, y porque..http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jcarmona Publicado 6 de Mayo del 2016 Autor Denunciar Compartir Publicado 6 de Mayo del 2016 Muchas gracias!! hare lo que me indican! saludos Responder Enlace al comentario Compartir en otros sitios web More sharing options...
