Sign in to follow this
play23
Fallos Vagcom
Recommended Posts
Hola. ¿Alguien puede decirme los fallos que me ha dado el vagcom y a que pueden deberse?
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 BP
Component: 1.8L R4/5VT 0002
Coding: 10710
Shop #: WSC 01236
WAUZZZ8L831212284 AUZ7Z0C2313544
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 N
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 01144
Shop #: WSC 03109
Address 22 -------------------------------------------------------
Controller: 02D 900 554 C
Component: HALDEX LSC ECC 0010
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15215
Shop #: WSC 03109
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 01236
Address 56 -------------------------------------------------------
Controller: 8L0 035 186 J
Component: concert II GRO 0008
Coding: 00001
Shop #: WSC 01236
End -------------------------------------------------------
Muchas gracias. Un saludo.
Share this post
Link to post
Share on other sites
En el Address 08 parece que ha tenido muchos errores de comunicación, seria bueno volver a pasar el test solo de ese modulo.
Address 22
1 Fault Found:
Este de arriba controla el pulsador del pedal del freno de pie, puede estar defectuoso.
Saludos,
Odón.
Share this post
Link to post
Muchas gracias por tu respuesta. ¿Podrías decirme que es el pulsador del pedal del freno de pie? ¿Tiene que ver con las luces de freno?
Share this post
Link to post
<_< :):D
Eiiinnn?
Salu2.
PD.- Odón, se te echó de menos en Ocaña.
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
Utilizamos cookies para asegurar que damos la mejor experiencia al usuario en nuestro sitio web (personalizar anuncios, ofrecer funciones de redes sociales y analizar el tráfico). Compartimos esa información con nuestros partners. Privacy Policy.
