borjabarea Publicado 16 de Abril del 2023 Denunciar Compartir Publicado 16 de Abril del 2023 Hola buenos dias, ando desesperado con estos errores, alguien sabe por donde meterle mano Address 08: Auto HVAC Labels: 8P0-820-043.lbl Control Module Part Number: 8P0 820 043 BG HW: 8P0 820 043 BG Component and/or Version: KlimavollautomatH09 0100 Software Coding: Work Shop Code: WSC 00000 000 00000 VCID: 72EB3C436D5AFA8E927-8027 5 Faults Found: 01087 - Basic Setting Not Performed 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 114 Mileage: 253015 km Time Indication: 0 Freeze Frame: 01842 - Potentiometer/Actuator for Temperature Flap; Right (G221) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 106 Mileage: 252888 km Time Indication: 0 Freeze Frame: Voltage: 12.50 V (no units): 255.0 Temperature: 17.5°C 01842 - Potentiometer/Actuator for Temperature Flap; Right (G221) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 154 Mileage: 253015 km Time Indication: 0 Date: 2023.04.11 Time: 19:56:38 Freeze Frame: Voltage: 12.50 V (no units): 255.0 Temperature: 28.0°C 01272 - Positioning Motor for Central Flap (V70) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 5 Reset counter: 159 Mileage: 253035 km Time Indication: 0 Date: 2023.04.12 Time: 14:39:32 Freeze Frame: Voltage: 14.10 V Temperature: 35.0°C (no units): 197.0 (no units): 26.0 Temperature: 26.0°C 65535 - Internal Control Module Memory Error 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 156 Mileage: 253048 km Time Indication: 0 Date: 2023.04.12 Time: 14:49:18 Freeze Frame: Temperature: 36.5°C Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Lazpi Publicado 16 de Abril del 2023 Denunciar Compartir Publicado 16 de Abril del 2023 hace 8 horas, borjabarea dijo: Hola buenos dias, ando desesperado con estos errores, alguien sabe por donde meterle mano Address 08: Auto HVAC Labels: 8P0-820-043.lbl Control Module Part Number: 8P0 820 043 BG HW: 8P0 820 043 BG Component and/or Version: KlimavollautomatH09 0100 Software Coding: Work Shop Code: WSC 00000 000 00000 VCID: 72EB3C436D5AFA8E927-8027 5 Faults Found: 01087 - Basic Setting Not Performed 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 114 Mileage: 253015 km Time Indication: 0 Freeze Frame: 01842 - Potentiometer/Actuator for Temperature Flap; Right (G221) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 106 Mileage: 252888 km Time Indication: 0 Freeze Frame: Voltage: 12.50 V (no units): 255.0 Temperature: 17.5°C 01842 - Potentiometer/Actuator for Temperature Flap; Right (G221) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 154 Mileage: 253015 km Time Indication: 0 Date: 2023.04.11 Time: 19:56:38 Freeze Frame: Voltage: 12.50 V (no units): 255.0 Temperature: 28.0°C 01272 - Positioning Motor for Central Flap (V70) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 5 Reset counter: 159 Mileage: 253035 km Time Indication: 0 Date: 2023.04.12 Time: 14:39:32 Freeze Frame: Voltage: 14.10 V Temperature: 35.0°C (no units): 197.0 (no units): 26.0 Temperature: 26.0°C 65535 - Internal Control Module Memory Error 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 156 Mileage: 253048 km Time Indication: 0 Date: 2023.04.12 Time: 14:49:18 Freeze Frame: Temperature: 36.5°C Primero ejecuta un 'basic setting' que te lo esta pidiendo; [select] [08 - Heating/Air Conditioning] [basic Settings - 04] Group 001 [Go!] Activate the Basic Setting. [ON/OFF/Next] The basic setting takes approximately 40 seconds. [Done, Go Back] [Close Controller, Go Back - 06] Luego borras errores, que algunos son intermitentes. Ves que errores se quedan. Si no queda ninguno, andas un par de dias y vuelves a diagnosticar, y seguimos viendo. Unsaluso Responder Enlace al comentario Compartir en otros sitios web More sharing options...
borjabarea Publicado 18 de Abril del 2023 Autor Denunciar Compartir Publicado 18 de Abril del 2023 En 16/4/2023 a las 21:06, Lazpi dijo: Primero ejecuta un 'basic setting' que te lo esta pidiendo; [select] [08 - Heating/Air Conditioning] [basic Settings - 04] Group 001 [Go!] Activate the Basic Setting. [ON/OFF/Next] The basic setting takes approximately 40 seconds. [Done, Go Back] [Close Controller, Go Back - 06] Luego borras errores, que algunos son intermitentes. Ves que errores se quedan. Si no queda ninguno, andas un par de dias y vuelves a diagnosticar, y seguimos viendo. Unsaluso buenas tarde he comprobado lo que comentaste y nada me sale NOT OK cuando le doy a [ON/OFF/Next] he esperado mas de un minuto a ver si cambiaba pero nada, por un momento sale la palabra ADP.RUM y vuelve al NOT OK, me salgo borro los errores y sigue igual Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Lazpi Publicado 18 de Abril del 2023 Denunciar Compartir Publicado 18 de Abril del 2023 Si no puedes hacer una adaptacion, mal asunto, porque el climatizador no sabe cual es el recorrido de las trampillas. Por no decirte un 'cambia el climatizador' sin gastar otros cartuchos: que version de vagcom estas usando? Te pueden prestar otro cable? Un saludo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
borjabarea Publicado 29 de Abril del 2023 Autor Denunciar Compartir Publicado 29 de Abril del 2023 En 18/4/2023 a las 22:28, Lazpi dijo: Si no puedes hacer una adaptacion, mal asunto, porque el climatizador no sabe cual es el recorrido de las trampillas. Por no decirte un 'cambia el climatizador' sin gastar otros cartuchos: que version de vagcom estas usando? Te pueden prestar otro cable? Un saludo Buenas tardes lazpi, perdon por la tardanza pero he estado fuera todo este tiempo, pues resulta que pedi los servomotores v70 y v158 que es lo que me estaba dando fallos, y bingo , al cambiarlo me dejo hacer la configuracion de las trampillas como me dijiste y va todo perfe, me echa aire frio y tambien por el centro que me dejo de echar aire por culpa del servomotor v70, esta mañana he montado los dos y va todo perfecto por ahora, de pensar que podia ser el clima o el compresor resulta que han sido los servomotores y la multa a sido la cantidad que menos esperaba, muchas gracias por tu aporte y tiempo, ahh el el vag com que tengo es el 12.12 un poco antiguo pero me dejor hacer ajuste Responder Enlace al comentario Compartir en otros sitios web More sharing options...
PiPeS Publicado 16 Marzo Denunciar Compartir Publicado 16 Marzo Borja, podrías explicar cómo lo hiciste, por favor? gracias Responder Enlace al comentario Compartir en otros sitios web More sharing options...
