Radio cassets con pantalla TFT TV/DVD/Mp3/Divx Etc.
abro este post para el tema precios i tal. asi queda arriba y no preguntais los precios ya que sino me ago ujn lio ai va.
Modelo Ref : LFT700
Las caracteristicas de este casset son
7 inch TFT LCD
• 1 din car dvd
• Built in TV reciver
• Divx/Mpeg4 compatible
• Built in FM radio
• Touchscreen Function ( Tactil )
Full automatic flexibility
• DVD/VCD/SVCD/D-VCD/CD/MP3/Mp4/Divx discs are compatible
• TUNER Function: Digital FM/AM Recuver
• TV Function: PAL/NTSC system
• AUX Function: AV audio/video input and output
• 7 inches 16:9 high-definition TFT LCD
• Automatic memory(replacement) parameter adjustment
• Fully remote control
• OSD menu order
• Automatically switch to back radar (you need to equip with back radar)
• Adopting high definition TFT color LCD, built in DVD, FM, AM, TV, backing radar, CDC ,rearview mirror for backing, and four-speaker power output.
• 4-line automatic TV antenna reception
• It can be connected with bass amplifier
• 4-line audio output
• All functions integrated in one machine
Sale por 500€
Modelo LF3500
• 3.5 inch Widescreen (16:9) TFT LCD
• Built in FM radio
• Built in USB 2.0 port(Pen Drive, Mobile HDD, MP3 Player, USB Memory, Card Reader)
• 3.5" wide TFT colour LCD screen
• MP3 Files Playback from USB, MMC & SD Card Direct
• Build-in TV tuner
• Full Detachable Front Panel with Carry Case
• Electronic anti-shockNTSC/PAL compatible
• Picture control: brightness/contrast/colour/ tint/DVD/ DVD-R/ MP3/CD/CD-R/CD-RW compatible
• Repeat/program/random/intro play
• AM/FM stereo receiver
• 30 preset stations
• Auto memory store/preset scan
• Preset EQ (pop/rock/classic)
• 40W x 4 high power output (Max. Power Output 60W x 4)
• Parking detector interface
• 2V preamp output (2prs RCA)
• Subwoofer output
• Card size full function remote control
• Rear monitor video output
• Power Requirements : 12V-14.4V DC
• 1 Pair of RCA Line Out
• 16 Pins ISO Connector
• Aux Input
• Load Impedance : 4
• Tone Controls : +-8DB(Bass 100Hz,Treble 10 KHZ)
• Dimensions : Approx. 192 x 178 x 50mm(d x w x h)
• Mounting Dimensions : Approx. 169 x 182 x 53mm
• Weight : Approx. 2.00kg
 (Multi-functional)
This DVD player are capable of audio output and video signals to both front
and rear seat monitors for everyone
 DVD Deck Section:
• 4 Channel RCA Preamp Output (DVD)
• Preset EQ(POP/Rock/Classic)
• Discs Played : DVD,VCD 1.0/1.1/2.0/3.0,MP3,CD,CD-R,CD-RW,DVD-R,Picture-CD
• Video System : AUTO/ PAL/ NTSC
• Mounting Angle : 0 to +/- 30 Degree
Video Section:
• 2 Channel RCA Preamp Output
• Video System : 4:3 Letter Box and 4:3 Pan Scan
• Video Output Level : 1.0V p-p 75 ohms
• Horizontal Resolution : 500
Audio Section:
• 2 Channel RCA Preamp Output (MP3)
• Maximum Output Level : 2Vrms(+/-3DB)
• Frequency Response : 20 to 20 KHZ
• Signal-to-Noise Ratio : 85DB
• Separation : 80DB
TV System:
• PAL/NTSC/SECAM
AM/FM Tuner Section:
• Frequency Range: 522-1620(Europe/China),530-1710(U.S.A.)
• IF Range : 450MH
• Usable Sensitivity(-20DB) : 25DB
• Tuner Range : 87.5-108(Europe/China), 530-1710(U.S.A.)
• Usable Sensitivity (-30DB) : 15DB
• Signal-to-Noise Ratio : 60DB
• Stereo Separation : 30DB(1KHZ)
• Frequency Response : 30~15000HZ
Accessories
• Car Stereo Player (with removable front panel)
• Cables at the back of player
• Remote control
• Manual Instruction
• Box for the front Panel
Precio 250€uros.
Modelo : LF6500
• 6.5 inch TFT LCD
• 2 din car dvd
• Built in FM radio
• can be connected to GPS box
• Built in DVD, FM, AM, TV , functions,(AV and CDC and GPS functions optional)
• Full compatible DVD/VCD/MP3/CD/CD_R/CD_RW/Divx/Mpeg4 disc
• 6.5’’ TFT-LCD vivid screen with 16.9 aspect ratio
• Touch panel cam operate the characteristic OSD user interface directly
• Save the parameters automatically, and default parameters can be restored
• 1 channel AV output, very easy to connect with external AV device and compose a perfect car AV entertainment system]
• 4 channels TV antenna input :receive good and stable TV program in the car
• Auto-save function in DVD mode,conveniently watch all kinds of disc continuously
• Clock display, get the current date and time at any moment and built-in perpetual calendar very easy for inquiring about the current date
• Hi-tech GPS navigation system can connect with special GPS device, making it convenient for driving and reducing the trouble of looking for ways
• Auto switch to the backing car display status when backing a car, if external camera is available, the ca rear status can be seen on the screen in real time to ensure the safety
• Auto mute for answer the car telephone if it is available
• Hand brake detecting function, which switches off the TFT display automatically to ensure the safety during driving
• Auto detect the small light switch function: if the small light is on, the light of keys will be on and the TFT screen will switch to nigh mode automatically
• Fluorescent remote control, convenient for use in the night
• The TFT-LCD angel can be adjusted arbitrarily and the sliding mechanism can be auto-protected
• Can connect to the external control keys of steering wheel,easier and more convenient for operation.
• Control function for external power amplifier, avoiding impactive sound from switching power amplifier
Precio 400€uros
  • Respuestas 40
Modelo LF3600
•3.6 inch automatic TFT LCD
•Built in TV reciver
•Divx/Mpeg4 compatible
•Built in FM radio
•Built in USB 2.0 port(Pen Drive, Mobile HDD, MP3 •Player, USB Memory, Card Reader)
• 3.6" wide automatic TFT colour LCD screen
• Build-in TV tuner
• Subwoofer output
• Aux Input
(Multi-functional)
DVD Deck Section:
Video Section:
Audio Section:
• Separation : 80DB
TV System:
• PAL/NTSC/SECAM
• IF Range : 450MH
Accessories
• Remote control
Precio 270€uros
Modelo LF3601
•Built in FM radio
•Built in USB 2.0 port(Pen Drive, Mobile HDD, MP3 Player, USB Memory, Card Reader)
• Build-in TV tuner
• Subwoofer output
• Aux Input
 (Multi-functional)
 DVD Deck Section:
Video Section:
Audio Section:
• Separation : 80DB
TV System:
• PAL/NTSC/SECAM
• IF Range : 450MH
Accessories
• Remote control
Precio 290€uros
Modelo LF700
tambien esta en color negro que es mucho mas bonito. el cual no tengo foto ya la pondre. XD
•7 inch Widescreen (16:9) TFT LCD
•Built in FM radio
• Single DIN bracket
• Adjustable image brightness/color/contrast
• 7 inches wide view angle 16:9 display mode
• Divx/Mpeg4/DVD/VCD/CD/CD-R/MP3 player
• NTSC/PAL automatic identification
• 1 AV input and 1 AV output
• Manual stretching and all around circumrotate adjusting
• Card style remote control
• Single din 7-inch TFT LCD and DVD player
• TV tuner - Separate TV tuner unit included
• Built-in AM/FM stereo receiver
• Motorized display angle adjustment
• Multi-channel auto-EQ setting;
• Automatic display positioning
• Picture adjustment (brightness, contrast, color, settings)
• Volume/Treble/Bass/Balance/Fader controls
• Real time display
• Viewing Angle up to 106 degrees
• Selectable Widescreen Mode
• Instant Track Selection, Source TV Control, Source DVD Control
• DTS, Dolby pro II surround
Specification
Item Specification
•Supply voltage DC 10 -15V
•Current consumption 4- 15 A
•Working temperature 20-60
•I/O option 1-channels video input, 2 channels video output
•Screen dimensions 7 inches (diagonal)
•Weight 2.8 kg
•Dimensions 178 (w) x 210 (L) x 50 (H)
•Resolutions 480 (H)x3, (RGB) x 234 (V) pixels
•Pixel dot pitch 0.119 (H) x 0.345 (V)
DVD parameters
•Disc Compatible Divx,DVD, DVD-R. DVD+R. DVD-RW, DVD+RW/ VCD/SVCD/ CD/ CD-R, CD+R, CD+RW, CD-RW/ MPEG-4/ MP3/ WMA
•Signal noise ratio >900dB
•Distortion 500 Lines
•System PAL/NTSC
Radio parameter
•Range of frequency FM: 87.5-108MHz AM: 522-1611KHz
•Tuning mode Phase-locked loop Frequency synthesis tuning
•Display Mode LCD Panel display or OSD
•Memory capacity 18 FM stations / 9 AM stations
•Search mode Automatic Manual
TV Parameter
•Receiving system PAL, NTSC, SECAM, PAL-N, PAL-M
•Search mode Automatic/ Manual
•Memory capacity 125 channels
Channel parameters
•VHF-L: 48.325-170.00MHZ VHF-H: 170.00-450.00MHz UHF: 450.00-863.25MHz
•Amplifier parameters
•Max Power output 4 x 45W
•Output Parameters
•Range of audio output 1.0 App.
•Range of video output 10 +/- 0.2Vpp
•Impedance of video output 75
•Channels of audio output 2/ 4 channel (option)
•Video system PAL/NTSC
Accessories
• Car DVD Player
• Remote Control
• Connecting Wire Adaptor
• User manual
• Disassembly hook
• Mounting cage
• Double booster TV Aerial
Precio 360€uros
Abro este post para el tema referente a precios. Asi queda escrito arriba detalladamente
Mi cuenta del messenger es FERRAN_BCN86@HOTMAIL.COM Y LOS ENVIOS SE EFECTUARAN A TODO ESPAÑA i portugal ( andorra tb :ranting2: )
Editado por keitaro69
los de pantalla 3,6" y 3.5" i el de 7" de 500€uros son los mejores como calidad de sonido i te dejan regularlo todo, para ekipos de sonido son los k mas recomiendo.
a ke te llamas regularlo todo?
el de 3,5" he visto que regula, pero solo algo, por lo parecer, y ee algo es menor que mi algo. así pues :laugh:
aver no es como un alpine que sonb los mejores para regulacion de sonido que tienen mil cosas, pero tampoco sale la mitad de cosas, yo se que los de 3,5" i 3,6" para equipos con etapa van muy bien puedes regular lo que que tiene otods los casets, i tiene para agudos y etc.. el ultim ode todo tendra mas mobidas pero para regular no tiene nada, solo puedes regular q suene mas deu n lado que de otro pero nada mas, encambio los otros sip, y es mas el de 3,5 lo se seguro porque lo tienen 3 amigos montados en un ekipazo i son muy destos cn la musica i man dixo que se regula todo i etc.. y sino pues nada, no te arriesgues si no tas seguro i ya esta pero al lado de un clarion no tienen nada que envidiar ninguno de ellos e ncalidad de sonido ;)
yo soy de tocar mucho y claro no quiero arrepentirme, que no estoy por la labor de tirar 500€
Hombre gordon,tirarlos tirarlos....tampoco.....la verdad es que yo he visto un par de 1 din que esta bien,el problema es que para mi proximo coche no quiero 1din,por que quedara un pegote...no se no se...me lo pensare......este 5 necesita algo nuevo!!
Pero digo yo que estos trastos tendran salida de audio,y si se conecta al aux(si lo tiene) de la radio,puedes tener las dos cosas no?
Hombre,si lees la especificaciones(que yo no lo he hecho),pondra que no,que lleva para meter CD,osea,que tambien llevara para conectar altavoces,no?
