Super-Raton Publicado 10 de Enero del 2011 Denunciar Publicado 10 de Enero del 2011 (editado) Supongo que será un tema tratado por el foro pero no lo veo... Se trata de los codigos PR que tiene cada coche y que estan especificados en la pegatina que va en el libro de mantenimiento... Yo me he fijado en dos en particular que creo que son imprescindibles para plantearse un cambio de suspension... (marcados en la foto con un cuadrado rojo) son los indices de peso para el modelo... En esta pagina se pueden poner los codigo para ver su significado: http://prsearch.planetvag.com/default.aspx Mis codigos son, por ejemplo: PRCode: 0G1 = gearshift lever PRCode: 0JG = weight category front axle (eje delantero) weight range 7 PRCode: 0YH = weight category rear axle (eje trasero) weight range 8 PRCode: 1AT = electronic stabilization program (ESP) PRCode: 1BA = standard suspension/shock absorption PRCode: 1KW = disc brakes, rear PRCode: 1LT = disc brakes, front PRCode: 1N1 = power steering PRCode: 1SA = without additional engine guard PRCode: 2K1 = reinforced bumpers PRCode: 2ZQ = leather trimmed multi-function steering wheel for airbag system PRCode: 3L3 = manual height adjustment for front seats PRCode: 3NZ = rear seat bench unsplit, backrest split folding PRCode: 3Y0 = without roll-up sun screen PRCode: 4GF = windshield, tinted PRCode: 4K4 = radio remote controlled central locking operated from inside and separate trunk release PRCode: 4KC = side and rear windows tinted PRCode: 4UE = airbag f. driver a. front seat passenger PRCode: 4X3 = side airbag front with curtain airbag PRCode: 5D7 = carrier frequency 868 MHz without panic button PRCode: 5RU = outer right rear view mirror: convex (large viewing field) PRCode: 5SL = outer left rear view mirror: non-spherical PRCode: 6XC = outer rear view mirrors: powered PRCode: 7A3 = CD player PRCode: 7K0 = without tire pressure warning light PRCode: 7Q0 = without navigation device PRCode: 8GU = alternator 140A PRCode: 8Q3 = automatic headlight-range adjustment dynamic (self-adjusting while driving) PRCode: 8Z4 = engine cooling system with increased cooling performance PRCode: 9Q2 = multi-function indicator/on-board computer with check control PRCode: CD6 = alloy wheels 7 1/2J x 16 offset 40 (3D0 601 025) PRCode: E0A = no special edition PRCode: J1U = battery 450 A (95 Ah) PRCode: Q1A = standard front seats PRCode: U1A = instrument insert with km/h speedometer,clock, tachometer and trip odometer PRCode: X3B = national sales program Spain (FBU) Espero que os sea util... Un saludo! Editado 10 de Enero del 2011 por Super-Raton Responder
paul2008 Publicado 10 de Enero del 2011 Denunciar Publicado 10 de Enero del 2011 Tema muy chungo..... Tu coche lleva suspensión de serie con peso en eje delantero 7 y peso eje trasero 8. Mi coche llevaba de serie peso eje delantero 6 y peso eje trasero 6. Porque llevando los 2 suspensión de serie llevamos un índice de peso diferente???????? He llegado a la conclusión que depende del equipamiento del coche. Un motor diesel es más pesado que un gasolina (a misma cilindrada), una caja automática es más pesada que una manual, llevar asientos eléctricos, navegador, techo, etc. es todo más pesado que no llevarlo. Mi siguiente conclusión es que a más índice de peso 7 --> 8 --> 9 --> 10, etc. el muelle aguanta más peso y por lo tanto necesita más peso para que baje. Por el contrario, a menos peso 7 --> 6 --> 5 --> 4, etc. el muelle aguanta menos peso y por tanto necesita menos paso para que baje. Con esto entiendo que un coche con motor 3.0 TDI, automático, quattro y bien equipado llevara un índice de peso mayor (por ejemplo índice 10) que un 2.0 TDI, manual y pelado (por ejemplo índice 6). Ahora bien: Trasladar todo esto a una suspensión Sline o deportiva.....es una put* (perdón) locura que nadie sabe como va. En los talleres por los que me he pasado no me han sabido decir nada y Audi España no quiso contestar, bueno si: Su coche no puede llevar otra suspensión.... Pasaros por mi post del cambio de suspensión...... Saludos!! Responder
javivitf Publicado 10 de Enero del 2011 Denunciar Publicado 10 de Enero del 2011 Aqui esta el otro tema: Saber extras que lleva el coche http://www.audisport-iberica.com/foro/inde...howtopic=232549 Responder
javivitf Publicado 10 de Enero del 2011 Denunciar Publicado 10 de Enero del 2011 La que comenta Super-raton me gusta mas, de todos modos dejo mas enlaces que se comentaron. ENLACE MAS PAGINAS: http://audioc.free.fr/ http://igorweb.org/equidec/Default.aspx Responder
Super-Raton Publicado 10 de Enero del 2011 Autor Denunciar Publicado 10 de Enero del 2011 Aqui esta el otro tema:Saber extras que lleva el coche http://www.audisport-iberica.com/foro/inde...howtopic=232549 Ese era! no lo encontraba.... GRACIAS! :crying_anim: Responder
Super-Raton Publicado 10 de Enero del 2011 Autor Denunciar Publicado 10 de Enero del 2011 Hola paul2008, De los codigos que llevo me quedo con los siguientes... PRCode: 0JG = weight category front axle (eje delantero) weight range 7 PRCode: 0YH = weight category rear axle (eje trasero) weight range 8 PRCode: 1BA = standard suspension/shock absorption En el ETKA puedes encontrar referencias de muelles para cada combinacion de tipo de suspension / codigo de peso. De hecho las referencias que corresponden a mi tipo de suspension (estandar) con mi codigo de peso son las que llevo... Si el tipo de suspension lo determinara la combinacion de pesos sobraria el PRCode 1BA que llevo... no? Seguramente el mio lleva mas codigo de peso por ser Avant que se supone que lo voy a cargar mas (barras de techo, mas carga = mas codigo de peso...) en la trasera hay mas chapa por lo que todavia un poco mas... no sé... es la idea que tengo. He pedido sus codigos de peso a dos foreros con modelos igual que el mio y con suspension deportiva. Con sus codigos de peso y sus referencias creo que podremos llegar a una conclusion... Saludos! :crying_anim: Responder
Super-Raton Publicado 20 de Enero del 2011 Autor Denunciar Publicado 20 de Enero del 2011 La que comenta Super-raton me gusta mas, de todos modos dejo mas enlaces que se comentaron. ENLACE MAS PAGINAS: http://audioc.free.fr/ http://igorweb.org/equidec/Default.aspx Hola JAVIVTF, El link que pones ahi: http://igorweb.org/equidec/Default.aspx es el mas completo de los tres que he consultado... Aparecen mas codigos. Saludos! Responder
javivitf Publicado 20 de Enero del 2011 Denunciar Publicado 20 de Enero del 2011 (editado) *Bueno pues si no te importa lo dejamos asi de momento El mas completo,Aparecen mas codigos: 1 http://igorweb.org/equidec/Default.aspx Mas enlaces: 2 http://prsearch.planetvag.com/default.aspx 3 http://audioc.free.fr/ Editado 20 de Enero del 2011 por JAVIVITF Responder
spiderfredy Publicado 5 de Mayo del 2017 Denunciar Publicado 5 de Mayo del 2017 En 10/1/2011 a las 10:42, Super-Raton dijo: Supongo que será un tema tratado por el foro pero no lo veo... Se trata de los codigos PR que tiene cada coche y que estan especificados en la pegatina que va en el libro de mantenimiento... Yo me he fijado en dos en particular que creo que son imprescindibles para plantearse un cambio de suspension... (marcados en la foto con un cuadrado rojo) son los indices de peso para el modelo... En esta pagina se pueden poner los codigo para ver su significado: http://prsearch.planetvag.com/default.aspx Mis codigos son, por ejemplo: PRCode: 0G1 = gearshift lever PRCode: 0JG = weight category front axle (eje delantero) weight range 7 PRCode: 0YH = weight category rear axle (eje trasero) weight range 8 PRCode: 1AT = electronic stabilization program (ESP) PRCode: 1BA = standard suspension/shock absorption PRCode: 1KW = disc brakes, rear PRCode: 1LT = disc brakes, front PRCode: 1N1 = power steering PRCode: 1SA = without additional engine guard PRCode: 2K1 = reinforced bumpers PRCode: 2ZQ = leather trimmed multi-function steering wheel for airbag system PRCode: 3L3 = manual height adjustment for front seats PRCode: 3NZ = rear seat bench unsplit, backrest split folding PRCode: 3Y0 = without roll-up sun screen PRCode: 4GF = windshield, tinted PRCode: 4K4 = radio remote controlled central locking operated from inside and separate trunk release PRCode: 4KC = side and rear windows tinted PRCode: 4UE = airbag f. driver a. front seat passenger PRCode: 4X3 = side airbag front with curtain airbag PRCode: 5D7 = carrier frequency 868 MHz without panic button PRCode: 5RU = outer right rear view mirror: convex (large viewing field) PRCode: 5SL = outer left rear view mirror: non-spherical PRCode: 6XC = outer rear view mirrors: powered PRCode: 7A3 = CD player PRCode: 7K0 = without tire pressure warning light PRCode: 7Q0 = without navigation device PRCode: 8GU = alternator 140A PRCode: 8Q3 = automatic headlight-range adjustment dynamic (self-adjusting while driving) PRCode: 8Z4 = engine cooling system with increased cooling performance PRCode: 9Q2 = multi-function indicator/on-board computer with check control PRCode: CD6 = alloy wheels 7 1/2J x 16 offset 40 (3D0 601 025) PRCode: E0A = no special edition PRCode: J1U = battery 450 A (95 Ah) PRCode: Q1A = standard front seats PRCode: U1A = instrument insert with km/h speedometer,clock, tachometer and trip odometer PRCode: X3B = national sales program Spain (FBU) Espero que os sea util... Un saludo! yo tengo el mismo problema, quiero saber exactamente cuales cosas son consideradas como extras en mi coche y cuales son consideradas de "serie" para no tener luego problemas con el seguro, la cuestión es que vengoo hace un rato del conce y me han sacado un informe del coche con el número de chasis de todos los códigos PR y me han dicho que todo lo que venga como código PR son consideradas cosas de serie, pero me vienen un montón de cosas, equipamiento sline exterior e interior y muchisimos códigos PR más, 5 folios de código PR. Esto es así??, todo lo que venga con códigos PR es considerador de serie y el seguro no me tendría que poner problemas a la hora de que venga asegurado por defecto??, comento todo esto porque yo el coche no lo he comprado nuevo, lo he comprado de segunda mano en Alemania. Responder
clones Publicado 5 de Mayo del 2017 Denunciar Publicado 5 de Mayo del 2017 hace 1 hora, spiderfredy dijo: yo tengo el mismo problema, quiero saber exactamente cuales cosas son consideradas como extras en mi coche y cuales son consideradas de "serie" para no tener luego problemas con el seguro, la cuestión es que vengoo hace un rato del conce y me han sacado un informe del coche con el número de chasis de todos los códigos PR y me han dicho que todo lo que venga como código PR son consideradas cosas de serie, pero me vienen un montón de cosas, equipamiento sline exterior e interior y muchisimos códigos PR más, 5 folios de código PR. Esto es así??, todo lo que venga con códigos PR es considerador de serie y el seguro no me tendría que poner problemas a la hora de que venga asegurado por defecto??, comento todo esto porque yo el coche no lo he comprado nuevo, lo he comprado de segunda mano en Alemania. Yo lo que hice para no tener ese problema con el seguro fue copiar toda la lista de equipamiento que figura en myaudi asociado a mi nº de bastidor y se lo mandé por correo a la compañía de seguro indicándoles que quería que me incluyeran todo el equipamiento opcional en la póliza, no tuve ningún problema y creo que el precio de la póliza me subió unos 30 euros. un saludo. Responder
clones Publicado 6 de Mayo del 2017 Denunciar Publicado 6 de Mayo del 2017 yo no tuve problema, les mandé todo el equipamiento por correo y luego me llamaron por teléfono para para incluir todos los extras en el apartado de coberturas de equipamiento opcional, no el de serie, así tengo todos los extras incluidos en la póliza. Ellos mismos me indicaron que todo los elementos con los que el vehículo ha salido de fabrica están cubiertos, pero llevando mas de 20000 euros en extras que quieres que te diga me quedo mas tranquilo si están por escrito en la póliza. Mas aun con la experiencia que tuvimos con el coche de mi mujer, que aun teniendo la culpa el otro y como teniendo el seguro a todo riesgo nos arreglaron el vehículo antes de saliese la resolucion y no querían hacerse cargo de la luz de xenón alegando que no venia ese elemento en ningún sitio cuando era un elemento de serie. Responder
fnatalau Publicado 8 Octubre Denunciar Publicado 8 Octubre Hola, tengo una duda e igual es una duda tonta, ¿ los códigos PR que vienen en el libro de mantenimiento se supone que lo que aparece es lo que lleva, no ?, en el mío hay varias cosas que el coche no lo tiene, sí me podéis informar os lo agradezco. Gracias. Saludos. Responder
deckel Publicado 8 Octubre Denunciar Publicado 8 Octubre hace 17 minutos, fnatalau dijo: Hola, tengo una duda e igual es una duda tonta, ¿ los códigos PR que vienen en el libro de mantenimiento se supone que lo que aparece es lo que lleva, no ?, en el mío hay varias cosas que el coche no lo tiene, sí me podéis informar os lo agradezco. Gracias. Saludos. Buenas. Debería ser así, es la equipación y extras que lleva. Responder
luislucena Publicado 9 Octubre Denunciar Publicado 9 Octubre hace 11 horas, fnatalau dijo: Hola, tengo una duda e igual es una duda tonta, ¿ los códigos PR que vienen en el libro de mantenimiento se supone que lo que aparece es lo que lleva, no ?, en el mío hay varias cosas que el coche no lo tiene, sí me podéis informar os lo agradezco. Gracias. Saludos. Si el coche es tuyo y esta a tu nombre, llamas a audi españa le envias la documentacion y te envian todo lo que tu vehiculo lleva montado, Extras y todo, codigo de color, que tipo de faros llevas, si tienes sensor de aparcamiento...etc. asi lo hice yo, y sales de dudas, porque cada coche salio de fabrica con una configuracion difernte. s2. Responder
fnatalau Publicado 9 Octubre Denunciar Publicado 9 Octubre hace 16 horas, deckel dijo: Buenas. Debería ser así, es la equipación y extras que lleva. Hola, voy a volver consultar los códigos en: https://www.oemvwshop.es/ y anotaré lo que no cuadra y os digo, ah me acabo de acordar que había diferencia en las pulgadas de la rueda, puede ser equivalencia pero bueno lo investigo.... Gracias. Saludos. Responder
