3am4
 Share
Recommended Posts
Hola, recientemente me llegó el vag com y probandolo he hecho un autoscan y me han salido estos fallos. Alguien me puede echar una mano??
Address 01: Engine
2 Faults Found:
012691 - Intake Manifold Runner Control
P3193 - 002 - Open Stop outside of Valid Range - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 104571 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 51.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.446 V
001602 - Sensor Reference Voltage A: Circuit
P0642 - 002 - Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 104571 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 51.0°C
Voltage: 12.446 V
Address 25: Immobilizer
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Address 37: Navigation
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 63
Mileage: 99237 km
Time Indication: 0
Date: 2016.08.28
Time: 16:49:41
Freeze Frame:
Voltage: 12.60 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Address 46: Central Conv.
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 63
Mileage: 99237 km
Time Indication: 0
Date: 2016.08.28
Time: 16:49:41
Freeze Frame:
Voltage: 12.60 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Link to comment
Share on other sites
Borrar los fallos, dejar unos dias y volver a leer.
Tienes 2 fallos intermitentes en el navi. Probablemente de haberlo quitado. Otro mas intermitente en el motor, este puede volver y ser un problema real o no.
La segunda llave te funciona bien?
La que mas me preocupa es la 'ROM defective'. Algunos cuadros FIS de los 8P tienden a morir, y el primer sintoma es ese. Luego suelen dejar de encender el FIS esporadicamente, luego dejan de encender totalmente, hasta morir.
El problema es que si lo dejas morir no se puede hacer nada, mas que pasar por el conce y palmar los aproximandamente 600€ que te piden por poner un cuadro nuevo. Si lo pillas a tiempo puedes clonar los datos a otro cuadro, y salvar las papeletas. Yo consultaria el tema a una empresa que se dedique a reparar cuadros de coche, por no encontrarte con una sorpresa.
Link to comment
Según vi el fallo de la llave, cogi la 2ª la probé, abrir, cerrar y arrancar y no hubo ningún problema.
En su día inicié este tema por un ruido que hacía y hace la mariposa de la admisión y pensé si el fallo del motor pudiera tener relación con ello. Te dejo enlace del post, a ver si le puedes echar un vistazo que en un vídeo de oye el ruido que digo Ruido en el acelerador s3 8p
https://r.tapatalk.com/shareLink?share_fid=42432&share_tid=361024&url=http%3A%2F%2Fwww%2Eaudisport-iberica%2Ecom%2Fforo%2Findex%2Ephp%3F%2Ftopic%2F361024-Ruido-en-el-acelerador-s3-8p&share_type=t
Por si acaso no borré los fallos, puedo borrarlos y así comprobar después si vuelven a aparecer??
Gracias
Link to comment
Gracias
Buenas;
Si, claro puedes borrarlos y observar si vuelven a aparecer.
De hecho, es el procedimiento 'standard' para los fallos intermitentes. Apuntar, borrar, rodar y volver a leer y comparar.
Respecto al fallo que tienes en Engine, una buena pagina es la Wiki de Rosstech:
http://wiki.ross-tech.com/wiki/index.php/19649/P3193/012691
Donde pone 'Special Notes', pincha en 'Basic Settings' y sigue el procedimiento para inicializar la mariposa, que es;
Prerequisites:
  • Ignition ON
  • Engine OFF
  • System voltage at least 11.0 V.
[select]
[01 - Engine]
[basic Settings - 04]
Group 142
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch Ignition OFF for at least 60 seconds.
Es sencillo, tardas 1 min y asi ya sabes que esta adaptada.
Si no recupera, yo empezaria por cambiar la mariposa.
Edited by Lazpi
Link to comment
Gracias
Buenas;
Prerequisites:
  • Ignition ON
  • Engine OFF
[select]
[01 - Engine]
Group 142
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Hoy he borrado los fallos y he probado a hacer eso con el vag com y no sé si lo habré hecho bien o no pero me sigue apareciendo el fallo del motor. Te pongo lo que me sigue apareciendo.
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number: AUX7Z0G0FNN0ZJ
Coding: 01030003180F0160
Shop #: WSC 00939 572 186126
VCID: 377D41BA468CAEFA51-8062
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 104571 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 51.0°C
Voltage: 12.446 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 104571 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 51.0°C
Voltage: 12.446 V
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 8P0 920 931 C HW: 8P0 920 931 C
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: AUX7Z0G0FNN0ZJ
Shop #: WSC 29315 000 1048576
VCID: 336575AA52F442DA6D-8066
1 Fault Found:
014 - Defective
El resto de fallos han desaparecido.
Link to comment
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
