A los interesados del TTDA
jeTT
Bueno ya he recibido respuesta de S.Schwing!!! Os lo pongo aqui para total trasparencia de la opreacion. !!!!
Es largo, pero os pido q cogais 5 minutos para leerlo todo y intentad comprender lo q vai a adquirir. No quiero sorpresa despues :(:(
JGG ya le he enviado un mail!!! Esperando respuesta!!! :o
Juan Carlos...Hi! Yes Robo is very happy with his TTDA! I would be happy
to make a batch for you in Spain. I have 2 black and a red tube prepared so
delivery time would be pretty quick. I may need to order a few more filter
elements though as I have 3 committed now. 2 weeks at the most to ship. I
build these in my spare time and the next few weekends I have some things to
do that will slow me up a little. Here is what I would do. For an order of
3 they would be $235 US apiece + $60 shipping to one address. Shipping is
$45 each so if I can consolodate a shipment to you it would save you money.
I generally handle all this through Paypal. My adr. is
seschwing@earthlink.net I would also need a list of the cars to be fitted
so I can include the small MAF adapter if required. Here's the specs again.
Let me know how you'd like to proceed!
Steve
TTDA Airbox construction details:
Tube: Non-Brittle Phenolic Microseam 7.51 ID x 8 inches long
Insulation: Fiber Tech 3/8" insulation with aluminum skin for reflective and
absorptive heat handling
Filter: K&N Inverted cone #RR-3003 w/polished cap, New with warranty card
Lamination: Carbon fiber or carbon/kevlar weave. Laminated with Epoxy then
Dupont clear coated.
Stainless Version: T-304 Brushed stainless wrap. 26
gauge
Endcaps: 3/8 inch ply with Black carbon lamination
Edging: Vinyl with aluminum reinforcement
Intakes: (2) Spun aluminum, 2.5" OD, or custom to your spec.
Clamp: Stainless
Cold Start Filter: Foam, slip on
"No Tools" disassembly for filter cleaning
Construction and color pictures here:
http://public.fotki.com/ttschwing/cai_and_other_intak/
Price: $250 in your choice of Black Carbon (gloss or matte finish), Moro
Blue, Desert green or Red Carbon/Kevlar (Gloss only), OR brushed stainless
verion (T-304, 26 gauge, #4 brushed finish) . Color swatches here:
http://www.uscomposites.com/hybrids.html (note: colors darker when
epoxied)
Note: Since these are individually made, custom modifications can be
incorporated
Includes paypal and shipping within the continental US, Add $40 for shipping
to the UK, $15 To Canada.
Other quotes on request.
Includes filter sock for the cold start breather line
Does not include feed lines (see links below for sources)
Specify 180 OR 225. 180 version will include silicone adapter sleeve.
First Dyno reviews from Phill in the UK at a recent AMD "Rolling Road" day:
After: Hi Steve, first I hope that you and your family and friends are safe
and sound after the terrible storms .
We had a rolling road shoot out at AMD today as you said the car is getting
better and better the BHP was 272 and the torque 297lbs-ft , a lot of people
were very inpressed and we had a hot day 30c , so many thanks again and
might be some new orders on the way ?
Best reguards,
Phill
Before: Hi Steve, my numbers before were 264 bhp 291 lbsft also fitted FMIC
after these , but the really good part was I was run later in the day when
it was hotter the early runners were not bad but the figures started
dropping off as the day went on but not mine !!
Cheers mate,
Phill
Performance Testimonial from Carlos in Puerto Rico:
1/4 ET ---- 14.057
1/4 MPH --- 94.56
I'm sure that my car run in the 13's because when I did the run the gas tank
was full(93 octane), that means too much weight, and my DV fluttering a bit.
The TTDA make a huge difference. Before the TTDA I did 14.6. Thanks Steve
for a great product. Yess...
Late 02 TT225 Quattro Lake Silver Coupe...
Mods for now are: APR 93Octane Chip, ECS Race N75, Hyperboost Adjustable DV,
SAMCO Intake Hose and Upper Turbo Hoses, O.CT FMIC, TTSchwing TTDA, Forge
Super High Flow Exhaust,
Set-up for OEM 225 car :
You won't be able to take full advantage of the design without having an
FMIC and running feeds into the free'd up grill area, but you will see
advantages in less heat soak, and a less restrictive intake. You may remove
the plastic MAF vanes with this filter as it appears to supply a very clean
flow of air to the MAF element. I currently have my vanes out. This will
make a big difference (See the Autospeed article on Negative Boost
http://www.autospeed.com/cms/article.html?&A=0629 ) The filter end will
fit directly on the MAF housing. Lubricate a little as it is a tight
squeeze. The filter is sized so that no other support should be necessary.
It will nestle right into the OEM airbox area. Run a short hose to the
fender opening from the top flange. Feed through 6-8 inches or so. Route
the bottom into the area behind the headlight. This will at least get you a
little fresh air in there. I use 2.5 inch neoprene hose. Expensive, but
better and more flexible than most. This can be sourced in bulk at
http://www.racerpartswholesale.com (10 ft lengths only) ,
http://www.pegasusautoracing.com (6 foot lengths), or by the foot at
http://www.aircraftspruce.com (Best deal $42 for 10 feet) You'll need 6
feet for a full feed system, 3 feet for the quick install method.
FMIC (or 180) car:
This is the best set-up but requires cutting a little metal if you want to
get the dual pressure feeds up to the box. If you can settle for one
pressure feed, no cuts are necessary. See Pic here:
http://public.fotki.com/ttschwing/cai_and_...ocut_feeds.html
. Here's Ryans write-up on this:
http://forums.audiworld.com/tt/msgs/963116.phtml My Fotki pics show all
these pretty clearly, so I won't go into a lot of detail.
http://public.fotki.com/ttschwing/cai_and_other_intak/ More feed detail
in this album:
http://public.fotki.com/ttschwing/cai_and_...eding_the_ttda/ One
hose up the fender liner side, and one up under the headlight. You can get
the hose through here with the front end on. You may have to remove the
battery box depending on how dexterous you are! Both end in some sort of
collector in the lower grill. Mines a home-made, but commercial inlets are
available.
Note on early 2001 cars and earlier with Xenons: The Xenon ballasts on
earlier cars are attached to the chassis under the lights, rather than on
the actual light fixtures themselves. Because of this it may be impossible
to route the headlight hose without removing the front end and headlight.
The ballast needs to be relocated to allow for hose clearance.
Install album of various pics from TTDA users:
http://public.fotki.com/ttschwing/cai_and_..._installs_from/
Additional Install Notes:
Depending on how you intend to install the air box, here are some tips,
links and notes to help you along:
Stock 225 or 180 (easy install method):
1) remove the stock box
2) lubricate the filter flange and clamp on to the MAF. Orientation of the
box should be with the seam down and the intake ports at about a 60 degree
angle
3) Hose routing can be simple but you won't get the Ram air effect. You
will get better flow and heat control though. Jeff Bipes installed his this
way and pics and details were posted here:
http://forums.audiworld.com/tt/msgs/887991.phtml
He used a relatively thick hose that does not look too flexible. I would
highly recommend going with the high quality Neoprene as seen in my
installs. Very flexible and should eliminate trimming sheet metal at the
snorkle exit area.
This stuff can be sourced at http://www.pegasusautoracing.com 2 1/2 inch
part # 3620-2.50-6 foot for$34. Or http://www.aircraftspruce.com PN
#05-29810 $4.10/ft. 6 feet will let you do even the more involved install
later if you choose and it can be screwed together to lengthen cut pieces.
4) Route 1 hose through the snorkle hole to get some fresh air, and tuck the
other down behind the headlight.
5) Place the black foam sock over the cold air inlet tube you removed from
the airbox side and zip tie out of the way.
225, 180 or VW with front feeds:
1) Mount as above (180 or VW applications will have a silicone hose spacer
in the filter end to match up to the 2 3/4 inch MAF)
2) Most of the pics for this have been pretty well documented here:
http://public.fotki.com/ttschwing/cai_and_...shack_3_mark_2/
The only tricky part is cutting a little sheet metal to the left of the
fender liner screw hole as seen here:
http://public.fotki.com/ttschwing/cai_and_...2/dscf0145.html
This is easily done with tin snips and then dressed up a bit with a dremel
or die grinder. Cut until you can fit the hose in there without interfering
with the fender liner when re-installed.
The feed horns are simple parts available at Home Depot. The angle bracket
shown holding the assembly to the car is from the garage door dept. (Track
bracket). It's slotted and sized perfectly for this. There's even a
threaded stud on the car to mount it too! You can also use the stock IC
Bracket that used to mount there for support. Commercial air inlet ducts
probably will not work here as there is VERY little room between the inlets
and where the hose has to go 90 degrees to head up to the box. None will fit
according to my measurements.
Cleaning
I've noticed that if you use front mounted feeds, a lot of stuff is sucked
up into the box and the inverted part of the cone gets dirty fast. I'd
clean every 3,000 miles under these circumstances.
Non force fed, you're probably good for 10-15K or so. K&N's actually work a
little better with some miles on them
To remove filter, take the box out of the car, remove the vinyl edging from
the filter side and the whole endcap with filter attached can be removed.
Follow the K&N procedures fro cleaning, Lightly oil, and re-assemble.
That's pretty much it! Go out and drive and let me know what you think.
The car will need a little time to adapt to the different flow
characteristics. The box is also quiet. You may consider removing the
plastic vanes in the MAF housing also as this is a big restriction in the
inlet system. Read this article to find out more:
Let me know how they work for you! Questions, I can be reached most anytime
at (252) 327-7737
----- Original Message -----
To: <ssheron@earthlink.net>
Sent: Thursday, January 15, 2004 11:49 AM
Subject: TTDA
Enlace al comentario
Compartir en otros sitios web
  • Respuestas 180
Posted Images
Ok!!! gracias a todos!!! solo me faltan q me confirme PSQ el tono de su TTDA, si brillante o mate.
JGG!!! no hay problema!!!! tambien lo he puesto en la lista!!! :D:)
Por cierto, usando este convertidor de divisas, me sale q 235$ USD de envio, son 188.619 €.
http://www.xe.com/ucc/es/
Porfavor comprovadlo!!! Por lo q pone en el mail, si el lo manda a una solo direccion, el porte es de 45$USD . Si por el contrario ha de mandarlo a cada uno de nosotros el porte sube a 60$USD. ASI q si os parece bien, y si no tenies ninguna objecion q me lo mande a mi y yo me encargo de repartirlos a cada uno q lo haya pedido. A menos de q alguien quiera hacerlo , por mi ningun problema.
Gracias PSQ!!!! acabo de enviar el mail con la actualizacion de los acabados. Ahora le toca a el dare respuesta sobre plazo de entrega. Le he comentado q ahora al ser mas cantidad de TTDA, a ver si se puesde ajustar un poquito mas con el precio. :):D A ver si hay suerte.!!!!
Con el tema pago, ....en cuanto me conteste hablamos al respecto. Os mantengo informados!!
Ok. Me parece buena idea que te los mande todos a ti y luego tu nos los mandas, así es menos lío. También para simplificar las cosas lo que podemos hacer es hacerte todos una transferencia a tu cuenta por el importe final que él te diga (lo que nos toque pagar en total a cada uno) y así le pagas tu a él todos de golpe.
Hola gente yo tambien estoy interesado en un TTDA para mi S3, pero acabado en rojo brillante, Lo ke pasa es ke no tengo claro lo de los acabados. hay alguna pagina para verlo. Yo he visto esa de los diferentes colores del Carbono, pero me refiero a ver la "caja" del TTDA.
Por ahora mi coche esta de serie, pero un futuro igual lo reprograma, lo compro ahora o me espero despues?
Te aconsejo que pidas ahora el TTDA con el resto de gente para que te salga mas barato.. ademas si haces la repro con el filtro de aire nuevo .. los parametros se modificaran en base del flujo de aire que meta el TTDA...
Creo que es mejor asi...
Para que veas los colores en terminados del TTDA esta es una foto que encontre por ahi, espero te sirva ;)
Un saludo y animate !!!
Robo
