Charly_SB Publicado 10 de Agosto del 2017 Denunciar Compartir Publicado 10 de Agosto del 2017 Hola a todos Tras cascar mi centralita bluetooth que traía el coche de origen (fallo 014 defective), he instalado una que hace unos días le he comprado a un compañero del foro. Tras una primera pasada del vag com, me ha dado los siguientes errores: 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Malfunction 1010 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 M HW: 8P0 820 043 M Component: KlimavollautomatH18 0300 Revision: 370677 Serial number: 8P0820043M Shop #: WSC 06314 000 00000 VCID: 36693E9841B9BCAE7EF-8063 1 Fault Found: 01301 - Control Module for Voice Recognition (J507) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 112 Mileage: 227556 km Time Indication: 0 Date: 2017.07.29 Time: 00:01:41 Freeze Frame: ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8P0-953-549-F.lbl Part No SW: 8P0 953 549 F HW: 8P0 953 549 F Component: J0527 H34 0070 Coding: 0004042 Shop #: WSC 03492 572 55179 VCID: 41835D4418770B16DBD-8014 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H07 0090 2 Faults Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent 01301 - Control Module for Voice Recognition (J507) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb Part No SW: 1K0 907 530 J HW: 1K0 907 951 Component: J533__Gateway H12 0160 Revision: H12 Serial number: 32001067288090 Coding: 7D3F0BC207002102 Shop #: WSC 03492 572 55179 VCID: 2E5916F8B9E9846E36F-807B 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 107 ------------------------------------------------------------------------------- Address 56: Radio Labels: 8P0-035-1xx-56.lbl Part No SW: 8P0 035 186 C HW: 8P0 035 186 C Component: concert II EU H52 0100 Revision: 02S Serial number: AUZ2Z3F4365832 Coding: 0002425 Shop #: WSC 03492 572 55179 VCID: 32610288ADD1A08E527-8067 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 112 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8P0 862 335 H HW: 8P0 862 335 H Component: FSE_255x BT H25 0290 Revision: 00000000 Serial number: 00000005005724 Coding: 0001255 Shop #: WSC 00000 000 00000 VCID: 3B7F2FAC7A9B61C6811-806E 1 Fault Found: 01523 - Microphone for Telephone (R38) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 124 ------------------------------------------------------------------------------- Al cambiarle la codificación por la propia de mi coche (con volante multifunción y sin navegador) y al borrarle los fallos, me encuentro con que la centralita conecta con mi teléfono, vuelca la agenda, consigo activar el control por voz pulsando el botón derecho del volante, pero no me escuchan por el micrófono a los que llamo ni el asistente por voz. Al hacer un diagnóstico, mantengo el fallo del módulo 77 que, aunque borre, vuelve a aparecer Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8P0 862 335 H HW: 8P0 862 335 H Component: FSE_255x BT H25 0290 Revision: 00000000 Serial number: 00000005005724 Coding: 0001255 Shop #: WSC 00000 000 00000 VCID: 3B7F2FAC7A9B61C6811-806E 1 Fault Found: 01523 - Microphone for Telephone (R38) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 72 He de decir que solamente cambié el código para indicarle que no tenía rnse, que si tenía volante multifunción y poco más, sin cambiar el work shop code ni nada más. La centralita corresponde a la misma letra (H) que la que tenía mi coche en origen y la antena que le he puesto, es la que me ha enviado el compañero con la centralita. Entrando con el vagcom en el módulo 77, he comprobado que al micrófono le llega voltaje (8 voltios), pero al comprobar el status del micro input, me indica 0.000A y no tengo la más mínima idea de si es producto de que no funciona el micrófono o si se debe a otra cuestión, porque parece que corriente le llega. Hay alguno que le haya pasado? En caso de que el micro haya palmado, tengo que obligatoriamente comprarle un micrófono original de audi o podría instalarle otro? Espero que alguien pueda echarme un cable con el fallo. Un saludo Carlos Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Charly_SB Publicado 11 de Agosto del 2017 Autor Denunciar Compartir Publicado 11 de Agosto del 2017 Hola a todos. Actualizo las comprobaciones He comprobado que el cable que va de la centralita al micrófono da continuidad en los dos cables (negro y verde). Una vez comprobado esto, he comprobado los cables que tiene el propio micrófono y dan continuidad, por lo que pienso que el micro no lo cierra y esto último podría ser por lo que el circuito está abierto. Puede ser o estoy dando palos de ciego?. Puestos a pensar, es posible que haya algo mal en alguno de los módulos del coche (aunque no salte ningún fallos en ellos) y por eso me da este error en el módulo del teléfono?. Desconozco si esto podría ser así. Espero toda ayuda que me podáis ofrecer. Un saludo Carlos Responder Enlace al comentario Compartir en otros sitios web More sharing options...
korny1976 Publicado 12 de Agosto del 2017 Denunciar Compartir Publicado 12 de Agosto del 2017 Open circuit puede significar circuito abierto año mejor alguno de los cables del micro q Esta suelto o roto podría ser Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Charly_SB Publicado 16 de Agosto del 2017 Autor Denunciar Compartir Publicado 16 de Agosto del 2017 En 12/8/2017 a las 15:45, korny1976 dijo: Open circuit puede significar circuito abierto año mejor alguno de los cables del micro q Esta suelto o roto podría ser He abierto el micro y parece que está todo bien. Empiezo a pensar que el micro está averiado a nivel interno (la placa). He leido bicheando por ahí que puede ser ocasionado por la polaridad, que estuviera invertida. Aunque esto último me extraña pues es una centralita igual a la que yo tenía (mismo código y letra). A ver si a alguno se os ocurre alguna cosa por la que tirar. Un saludo Carlos Responder Enlace al comentario Compartir en otros sitios web More sharing options...
