fallo ESP y parámetros de VagCom
PabloRamonMG
Hola buenas me salen por el vag com estos fallos, y en el fis me sale la averia del esp...no tengo ni idea pero a ver si alguien me ayuda por favor.
He borrado fallos y demás pero sigue saliendo.
VIN: WAUZZZ8KX9A216305 Mileage: 207610km/129002miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE
Component: ESP8 front H04 0240
Revision: -------- Serial number: --------------
Coding: 160500
Shop #: WSC 06325 000 00000
VCID: 7CF7127BFF1EBCFEC8B-8029
1 Fault Found:
00778 - Steering Angle Sensor (G85)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 9
Reset counter: 145
Mileage: 207240 km
Time Indication: 0
Date: 2015.12.19
Time: 03:57:56
Freeze Frame:
Hex Value: 0x1240
Hex Value: 0x4006
Hex Value: 0x121C
Hex Value: 0x23B2
Hex Value: 0x00FF
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IC500052
Coding: 000013
VCID: 3D71DF7FA48475F6BF5-8068
Component: E221 - MFL H02 0003
1 Fault Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 9
Reset counter: 145
Mileage: 207240 km
Time Indication: 0
Date: 2015.12.19
Time: 03:57:56
Freeze Frame:
(no units): 44.0
Text: 2CFFFFFF91FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFFC0FFFFFFFF
Fuel Consump.: 650.3 l/100
Raw, Index/Key Err.: 255 255 000
Text: 24FFFFFF9FFFFFFFC100FFFFFF9D2426490E
Temperature: -3231.9°C
Distance: 9254 cm
Resistance: 16.52 ohms
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G09225003E
Coding: 000303
VCID: 4B9581A7EA30CB46311-801E
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 114
Mileage: 206397 km
Time Indication: 0
Date: 2015.11.17
Time: 13:09:00
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 M HW: 8K0 907 064 M
Component: BCM2 1.1 H80 0145
Revision: 00002001 Serial number: 0117193130
Coding: 0100062020390040012002
VCID: 3A7BD463B5AA42CE9A7-806F
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 24
Reset counter: 105
Mileage: 205696 km
Time Indication: 0
Date: 2015.10.07
Time: 15:05:32
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 105
Mileage: 207162 km
Time Indication: 0
Date: 2015.12.17
Time: 13:24:49
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H01 0300
Revision: 00000003 Serial number: AUZ5Z6I1183407
Coding: 05000480040205000159070000
VCID: 4487AA9BC76E043EF0B-8011
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
02984 - Connection between Impedance Converter 2 and Window Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 150
Mileage: 147645 km
Time Indication: 0
Date: 2013.03.07
Time: 09:54:00
Después del primer scaneo he borrado y esto es lo que me sale.
Coding: 160500
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 145
Mileage: 207240 km
Time Indication: 0
Date: 2015.12.19
Time: 03:57:56
Freeze Frame:
Hex Value: 0x1240
Hex Value: 0x4006
Hex Value: 0x121C
Hex Value: 0x23B2
Hex Value: 0x00FF
Coding: 000013
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 145
Mileage: 207240 km
Time Indication: 0
Date: 2015.12.19
Time: 03:57:56
Freeze Frame:
(no units): 44.0
Distance: 9254 cm
Coding: 000303
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 114
Mileage: 206397 km
Time Indication: 0
Date: 2015.11.17
Time: 13:09:00
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 105
Mileage: 205696 km
Time Indication: 0
Date: 2015.10.07
Time: 15:05:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 105
Mileage: 207162 km
Time Indication: 0
Date: 2015.12.17
Time: 13:24:49
Component: Display
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 150
Mileage: 147645 km
Time Indication: 0
Date: 2013.03.07
Time: 09:54:00
Por último he hecho otra después de estar un rato con el coche arrancado y me ha salido esto. Agradezco algo de ayuda porque el fallo del esp no lo consigo borrar (y eso suena a caro :help: )
Coding: 160500
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 145
Mileage: 207240 km
Time Indication: 0
Date: 2015.12.19
Time: 03:57:56
Freeze Frame:
Hex Value: 0x1240
Hex Value: 0x4006
Hex Value: 0x121C
Hex Value: 0x23B2
Hex Value: 0x00FF
Coding: 000013
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 145
Mileage: 207240 km
Time Indication: 0
Date: 2015.12.19
Time: 03:57:56
Freeze Frame:
(no units): 44.0
Distance: 9254 cm
Coding: 000303
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 114
Mileage: 206397 km
Time Indication: 0
Date: 2015.11.17
Time: 13:09:00
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 105
Mileage: 205696 km
Time Indication: 0
Date: 2015.10.07
Time: 15:05:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 105
Mileage: 207162 km
Time Indication: 0
Date: 2015.12.17
Time: 13:24:49
Component: Display
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 150
Mileage: 147645 km
Time Indication: 0
Date: 2013.03.07
Time: 09:54:00
Puede que me deje algo borrado... :geek:
Se que el anterior dueño le cambió el altavoz trasero izquierdo y que la tapa del combustible no cierra cuando le doy a la llave (se queda abierta siempre aunque si no pulsas, no se sabe) pero lo que más me molesta y preocupa es el tema del sensor g85 y como solucionarlo. No quiero llevarlo al taller y que se limiten a cambiar la pieza sin saber si realmente está jodida o está mal calibrada.
Si alguien me ayuda lo agradecería y ante todo agradecer a los bricos que del b8 que andan por ahí porque ya he activado 4 cosillas como la luz del portón, test de agujas y he intendado el nivel del agua del limpia y batería pero no se por qué no salen. Un saludo. :hi:
Dales un poco mas de tiempo a los compañeros, porque en el fin de semana se conecta poca gente y de los que nos conectamos, al menos yo, no tengo ni idea. :unknw:
Suerte y un cordial saludo desde Galicia. :hi:
No nos indicas si el coche tiene servotronic,
Parece que hay un problema o incongruencia relacionado con el anillo de dirección, si han hecho un alineado de dirección o intervenido en la suspensión puede aparecer este fallo
Prueba a hacerle un ajuste basico
http://wiki.ross-tech.com/wiki/index.php/Audi_A5_(8T)_Steering_Wheel_Electronics#Basic_Setting
Sino todo apuntaría a un problema físico en el anillo. Han sacado el volante por algún motivo?
Editado por Tineo
Tienes razón...perdonad mi impaciencia.
Prueba a hacerle un ajuste basicohttp://wiki.ross-tech.com/wiki/index.php/Audi_A5_(8T)_Steering_Wheel_Electronics#Basic_Setting
Supongo que no tiene servotronic porque el coche es de segunda mano y viene bastante pelado de extras...
Alineado si le hice pero no retocaron casi nada según el mecánico y el fallo vino 3 o 4 meses desp de eso.
Probaré a hacer el ajuste y cruzar los dedos porque el volante no lo he sacado aun aunque tengo comprado el tempomat para instalarlo en breve y así que toca desmontar.
Muchas gracias y ya cuento en estos días cuando lo haga.
Es lógico estar impaciente, tienes desactivado el control de estabilidad y tienes que darle solución.
De todas formas, este hilo estaría mejor enmarcado en el subforo vagcom a4 b8.
Deseo cumplido señor Tineo :p:p:p
Buenas noches PabloRamonMG, por los códigos que he podido ver en el Auto-Scan de tu coche llevas servotronic. Este fallo 00778 se produce cuando no está calibrado el sensor de ángulo de la dirección (G85) o porque no existe comunicación entre el sensor de ángulo de dirección con la unidad del ABS/ESP. Revisa la calibración del mismo y el cableado también por si hubiera algún cable dañado que deje el circuito abierto y no permita comunicación de las unidades. En bloques de valores de medición puedes comprobar todos estos valores en el módulo 03 y 16.
Saludos. :thumbsup:
Saludos. :thumbsup:
Madre mía no se ni lo que lleva mi coche ...lo de calibrar el sensor g85 lo haré en estos días con tranquilidad y lo de los cables tendré que indagar porque no tengo ni idea que cables mirar. A no ser que se vean con los módulos esos que me comentas.
Mil veces agradecido.
Buenas por ahora en 20 km no ha saltado pero cuento lo que he hecho.
Aprovechando que he comprado un tempomat de desguace y que venía con sensor g85, he aprovechado y le he montado el que traía. Al conectar tempomat, batería y activarlo con el pc me daba fallo de esp y una resistencia. He borrado 3 veces los fallos pero no se quitaban y así que lo moví unos km. He intentado calibrar el sensor y creo que no lo conseguí (es demasiado lioso) pero por ahora no me ha saltado el fallo.
Espero haberlo solucionado con vuestra ayuda pero creo que tendré que volver a calibrar el sensor ese (mañana volveré a hacer un scan y pondré lo que sale por si me podéis ayudar), muchas gracias.
