Este hilo para estos temas. “Vag-Com / OBDEleven”
Salu2.
  • 10 meses más tarde...
Copio y Pego de varios sitios que he recopilado, yo ya he activado un par con OBDEleven:
CarPlay Wireless Activation
First - unpair/delete any Apple devices from CarPlay and Bluetooth (including removing the car if already paired from the Apple device itself - setting/general/CarPlay).
Module : 5F. (Information Control Unit)
Adaptation
Vehicle Configuration
MirrorLink = On
WiFi_Client_HMI = On
Apple_DIO_Wireless = On
wlan_5ghz_switch = Activated
Apple_DIO = On
Reboot the MMI  by holding down the volume button for 30 odd seconds.
Do not plug your Apple device into USB !!
Make sure the WIFI hot-spot is turned on in the MMI settings.
Pair your Apple device with Bluetooth - it should now ask if you want to enable CarPlay.
If it doesn’t, delete the pairing, and connect to the car’s wifi first from the Apple device, and try pairing via Bluetooth again.
Mine worked fine first time, and has worked successfully each and every time I’ve entered the car.
There's some additional settings for CarPlay under nhtsa_properties, I've not touched any of them, as I have no idea what effect they have.
Needle Sweep in Virtual Cockpit - Confirmed
a. Select Control Module
b. 17 – Instruments
c. Coding – 07
d. Long Coding Helper
e. Byte 1, Check Bit 0 “Staging, Yes” (Not sure why it’s labelled this way, but it does enable the needle sweep)
f. Exit Long Coding Helper
g. Click “Do It!”
Display transmission gear for "D" and "S" drive modes - Confirmed
b. 02-Auto Trans
c. Adaptation – 10
d. Chanel IDE04111-Single Gear Display
e. Select from New Value drop-down “D on/S on”
f. Click “Do it!”
DRL (Daytime Running Lights) turn Off when vehicle is in Park with EPB applied - Confirmed
b. 09-Cent. Elect.
c. Coding – 07
e. Byte 2, Check Bit 2 “drl_break,active”
g. Click “Do It!”
 Enable Lap Timer - Confirmed
b. 17 – Instruments
c. Coding – 07
e. Byte 1, Check Bit 3 “Lap counter, Yes”
g. Click “Do It!”
 Daytime Running Lights (DRL) On/Off setting in MMI - Confirmed
b. 09-Cent. Elect.
c. Coding – 07
e. Byte 2, Check Bit 1 “drl_mmi,active”
g. Click “Do It!”
Automatic Lock On/Off setting in MMI - Confirmed
b. 46-Central Conv.
c. Coding – 07
e. Byte 35, Uncheck Bit 0 “automatic_lock_not_at_mmi,0=not active / 1=active”
g. Click “Do It!”
Turn on parking brake when selecting Park
* Select Control Module
* 03-ABS
* Security Access - 16
* 38561
* Adaptation - 10
* Channel IDE08134 - Automatic parking brake
* Select Activated
* Click “Do It!”
Activating rear lights for DRLs.
 1. Module 9 (Central Electrics)
2. Long Coding
3. Enable SL_AT_DRL
Zitat:
- VIM
Nur mit VCP möglich.
Zitat:
- 5ghz WLAN aktiv
STG 5F
Anpassungskanal
-Fahrzeugkonfiguration-wlan_5ghz_switch
Zitat:
- Apple CarPlay (wireless)
STG 5F
Anpassungskanal
-Fahrzeugkonfiguration-Apple_DIO_Wireless
Zitat:
- Parkbremse immer aktivieren
STG 03 (Bremse)
Zugriffsberechtigung 40168
Anpassung auswählen
Kanal "Automatische Parkbremse" auswählen
Wert auf aktiv setzen
Zitat:
- Zeigertest / Inszenierung beim Start
STG 17
Byte 1 Bit 0
Zitat:
- Rundenzeiten im MMI
STG 17
Byte 1 Bit 3
Zitat:
- AutoLock über MMI konfigurierbar
STG 46
Byte 35 Bit 0 auf 0
Zitat:
- Tagfahrlicht über MMI konfigurierbar
STG 09
Byte 2 Bit 1
Zitat:
- Gurtwarnung deaktiviert
STG 17
Byte 0 Bit 2 auf 0
  • 6 meses más tarde...
Luces AUDI RS6 traseras. SOLO PARA MATRIX HD en los faros traseros que ya tengan la animacion de frabrica!!!!!
  • Modulo 46
  • Coding
  • Byte 02 > Byte 37 SSBR_Variante to „1“ (Bit 4 from 0 to 1)
  • 1 mes más tarde...
Desabilitar el mensaje de error que no permite usar las opciones del MMI mientras se conduce:
5F-Information Electr.
Adaptation-10
Starting at Channel IDE11502-FB_CAR_0, change anything ‘blocked’ to ‘non_blocked’
Starting at Channel ENG167428-nhtsa_properties-limitation_dependency, change all android and apple to ‘non_blocked’
Hay que tener el capo abierto, previamente a la codificacion
hace 10 horas, magnificus dijo:
Adaptation-10
Gracias por la aportación.
  • 9 meses más tarde...
  • 5 meses más tarde...
En 6/9/2021 a las 11:34, capa13g dijo:
Buenos dias,
He estado leyendo y bucando información sobre VCDS para nuestro modelo, y no he encontrado casi nada...por no decir nada.
Sabeis de algún sitio  para poder buscar??
Saludos y gracias de antemano.
El cable tiene que ser Vagcom V2 REAL 21.9.0 en ESPAÑOL (cuidado que en Aliexpress hay lo que ya sabes) y es el compatible para detectar el especial protocolo UDS del Audi A6 TDI C8 204 cv. fabricado en marzo de 2019 (tenemos el mismo vehículo), puesto que a partir de 2018 cambiaron el protocolo de comunicación con el vehículo.
En Mundodiagnosis = 104 € con atención asegurada y envío de la lista de los códigos de errores.
En Aliexpress = 72 €, aquí no se si lo envían.
Después de patear bastante por internet, yo me voy a decidir por Mundodiagnosis. No me arriesgo por 32 € menos en Aliexpress, puesto que en Mundodiagnosis también te lo entregan muy rápido y te aseguran su funcionamiento (no tengo comisión).
  • 11 meses más tarde...
Buenas, ayer active el control de descenso en mi A6, no he podido probarlo aun, pero supongo que debe ir bien.
Para activarlo :
Bloque 03 Frenos - Codificación larga - busque " Byte 8 Bit 7 y Byte 23 Bit 0 " y marque las casillas.
Bloque 09 Electricidad central - Codificación larga - busque " Byte 15 Bit 4 " y marque la casilla.
Bloque 5F Multimedia - Adaptación - elemento " Car Function Adaptation Gen2 " busque los elementos:
1. " Menu display brake function" configurado en " Activado "
2. " Menu display brake function over threshold high" configurado en " Activado "
  • 3 semanas más tarde...
Yo andaba buscando la opcion de que los espejos no se plieguen cada vez que cierro el coche. Mi idea es que se cierren solamente si hago una pulsación larga al boton del mando de cerrar, asi dependiendo de donde haya aparcado decido si los pliego o no.
Con el OBDeleven:
Confort System
Security access 20103
Long coding
Mirror retraction at comfort close
Set Active
  • 3 meses más tarde...
Buenos días:
Para un Audi A6 Allroad 2022.
Para poder hacer el reset de la revisión, veo que necesito entrar en el modulo 17 Adaptación.
El problema es que el botón me aparece desactivado.
He intentado meter los códigos 25327 y 47115, pero dice que no son validos.
Con 20103 dice que es correcto, pero el botón sigue desactivado.
Alguien me puede ayudar? No tengo experiencia con este software y no se como seguir.
Muchas gracias por adelantado.
Jose
  • 7 meses más tarde...
Buenas a todos. Me acaba de llegar mi vdcs y mirando por aquí por el foro solo veo este hilo con lo que puso el compañero @magnificus que por cierto no es poco… alguien me podría indicar dónde ver más activaciones como poder cambiar el virtual cockpit o poner el del rs6 o cosas así?
saludos!
  • 4 semanas más tarde...
Buenas, para cambiar el firmware del vc yo lo hice siguiendo las instrucciones de los enlaces que te dejo abajo.
https://www.drive2.ru/l/653096438955265133/
https://www.drive2.ru/b/645389137322470068/
En 5/1/2025 a las 1:54, PITERGUTIERREZ dijo:
saludos!
hace 15 horas, ivanken dijo:
Pero es cambiar el firmware? o hay que activar algo?
Muchas gracias!! le echaré un ojo!!
En 27/1/2025 a las 23:14, ivanken dijo:
Buenos días
Después de leerme y traducir los dos enlaces que pasaste no se la diferencia de uno a otro....en uno si creo que viene el link para descargar el software pero no me ha quedado muy claro.
Cual usaste tu? o cual es la diferencia? En el segundo si veo el link que creo que es para descargar los archivos...
Gracias!
