Replicar pantalla SmartPhone en MMI?
giger2000
Ok so here are my thoughts on the issue...
It would have been nice for the OP to at least advise the route that he's gone down to be able to get a resolve. It all seems a one way street at the moment. Posting up asking if anybody had a resolve, if somebody knew how to do it then the OP would have tried and hopefully got a workable solution.
Now I'm not quibbling about time spent on researching it and possible parts used and so the OP is looking to re-coupe that money which is fair enough.
I believe this is what's happened and how VIM has been activated.
1 - Purchased a VAG COM PRO system from the guys here or possibly the UK Re-Seller - http://www.vag-tech.eu
2 - Downloaded a specific file format for the software here - http://www.vag-tech.com/vagcanpro/zdc/A3_MQB_SMALL_MMI_VIM.zdc
Run the software and then it has written the code to the ECU that handles this stuff and now has VIM. I can see the cable is 185 Euros and with the exchange rate it's about £160. Hence the arm and a leg part the OP is referring to.
I could be totally barking up the wrong train and if so - apologies. The above however seems the most logical solution.
I do think that £80 is rather high for something that probably only takes about 5mins... As a business if somebody wanted something coding then I think £25 as a favour is about right. For instance, Alarm Chirp. I'm sure other Retrofit Folk on here such as NHN and N8 would agree with me on this.
Alan - A bit of advice If I may. You have quite a low post count which others on forums may see you as quite new and that you don't post up much and so asking for £80 for a service you are offering is quite strange, hence why some of the replies...
Please remember though as you are not a sponsor to the forum you are not allowed to post up offering services for cash unless it's seen as beer tokens to help somebody out. I have seen that you have posted in another thread offering your "service" If you offered it at a £10 then I think that would be seen as "Beer Token" worthy.
The above is by no means to undermine you or the work you have done but more to explain why you may get a few questionable replies. I will however be looking for a resolution when my new car turns up.
Enlace al comentario
Compartir en otros sitios web
  • Respuestas 137
Buenas noches Vega, tiene muy buena pinta, es un cable caro, pero si cumple y se salta la restricción VIM sería estupendo, yo acabo de pedir mi Audi A3 y no lo tendré hasta Marzo, tu o algun otro user lo ha probado?
Que no decaiga éste hilo!!
Felices fiestas.
Felices fiestas.
Buenos dias Kratos84,
Yo estoy en tu misma situación, acabo de pedir el coche y no me llega hasta marzo.
Un forero me comento que el lo pido a polonia, pero que no le funciono. No se si es un caso puntual, o realmente no funciona.
La verdad que tiene muy buena pinta, y especifica que es para el Audi A3 V8, no veo el porque no iba a funcionar.
A ver si hay alguien que le haya funcionado.
Hola mirad con este cable se puede habilitar ver videos en movimiento:
http://www.stagemotion.com/index.php?option=com_virtuemart&page=shop.browse&category_id=8&Itemid=27
Algún manitas que se anime :clap: A mi me queda esperar para recoger el mío hasta Marzo.... :unsure:
Aquí otro video de youtube que con algún tipo de cable RCA o parecido consigue replicar la pantalla del iphone en la pantalla MMI.
Saludos!
Aviator, on 29 Apr 2014 - 20:46, said:
Buenas tardes,
Soy yo otra vez, un mes después de haber escrito el mensaje anterior he avanzado un poco más pero ahora si que necesito ayuda.
Me compré el cable y programa VAG COM, el cable AMI RCA y esta semana me llegará el conversor HDMI y el Mirror2TV.
Conseguiste hacerlo funcionar con el cable AMI RCA, el conversor HDMI y el Mirror2TV ??
Saludos y grcias.
Buenas noches jusarav,
Llevo un tiempo investigando el tema pero sin poder probar nada porque aun no he recivido el coche, pero creo que los tiros van en este sentido..
Para hacer el mirroring efectivamente hace falta el AMI RCA, el conversor HDMI2AV y el Mirror2Tv. Este ultimo lo puedes sustituir x el EZCAST.
Existe otra opcion para hacer el mirroring con el Mirabox Wifi.
Pero para desactivar el VIM segun he leido no vale con el VAG COM, tiene que ser el VAG CAM PRO.
Tambien existe la posibilidad de desactivarlo con el dongle de VNS.
Un saludo!
  • 5 semanas más tarde...
Yo aún no dispongo del coche para poder probarlo, pero si el teléfono soporta salida MHL, podéis probar con estos cables.
http://www.ebay.es/itm/like/181615096708?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=115
http://www.amazon.es/Patuoxun-Adaptador-conversor-Samsung-Galaxy/dp/B00GN2KTGY
Creo que así se podría hacer mirroring.
  • 3 semanas más tarde...
