txispis
Todo lo publicado por txispis
  1. Tranqui era sobre esto.... de los codigos Quiero saber si este coche tiene el clima digital o analogico.... ya que navegador color lleva.
  2. me autorespondo jejejeje, la respuesta estaba en este foro como siempre http://igorweb.org/equidec/Default.aspx E0A = no special edition 0GG = emissions concept EU 4 4UE = airbag for driver and front seat passenger 6XD = outer rear view mirrors: powered, heated 5SL = outer left rear view mirror: non-spherical 5RU = outer right rear view mirror: convex (large viewing field) 1KD = disc brakes, rear J1U = battery 450 A (95 Ah) 1LG = disc brakes, front 1BA = standard suspension/shock absorption 3FA = without roof insert (standard roof) 5TD = decorative aluminum inserts 7X1 = ultrasonic park distance control F0A = no special purpose vehicle, standard equipment 8GV = alternator 180A 0G7 = Tiptronic 0YH = weight category rear axle weight range 8 0JK = weight category front axle weight range 10 T14 = components for, base engine, unit 06E.A 3NZ = rear seat bench unsplit, backrest split folding 8BB = halogen headlight for left-hand drive U1A = instrument insert with km/h speedometer, clock, tachometer and trip odometer X3B = national sales program Spain (FBU) 1N3 = speed-related variable steering assist (Servotronic) 2ZQ = leather trimmed multi-function steering wheel for airbag system 8Q1 = headlight-range adjustment 9Q4 = multi-function indicator/on-board computer with check control 8Z4 = engine cooling system with increased cooling performance D2G = 6-cylinder gasoline engine 3.2 L/184 kW 24V fuel-stratified injection, base engine is T14 7Q2 = navigation system with color screen C5V = alloy wheels 7 1/2 J x 16 (4F0 601 025 E) offset 45 7K0 = without tire pressure warning light 4X4 = side airbag, front and rear with curtain airbag 2K1 = reinforced bumpers 3L3 = manual height adjustment for front seats 4KC = side and rear windows tinted 3Y2 = electrically operated roll-up sun screenfor rear window 4K4 = radio remote controlled central locking operated from inside and separate trunk release 5D7 = carrier frequency 868 MHz without panic button 1SA = without additional engine guard Q1A = standard front seats 4GH = windshield tinted with windshield sunshield
  3. Hola a todos: necesito saber que equipamiento opcional lleva un A6 4F, sabiendo las siglas que vienen en el libro son estas: E0A... 0GG...4UE... 6XD... 5SL ... 5RU 1KD ... J1U ... 1LG ... .... .... ... 1BA 3FA .... ... ... ... ... 5TD ... 7X1 F0A .... ... ... 8GV ... 0G7 ... 0YH ... 0JK T14 ... 3NZ ... 8BB ... U1A ... X3B ... 1N3 2ZQ ..... ...... 8Q1 ... 9Q4 ... 8Z4... D2G 7Q2 ... C5V ... 7K0 ... 4X4 ... 2K1 3L3 ...... .... 4KC ...3Y2 ...4K4 ... 5D7 1SA ...... .... ...... Q1A ... ...... 4GH Haber si me podeis ayudar, gracias
  4. Un 190 sl siempre fue uno de mis favoritos... claro que el 300 sl descapotable tambien, pero el precio....
  5. De todas formas no os lieis.... una cosa es comprar unas réplicas de llanta mercedes pidiendola para audi que ir al desguace, coger una llanta de mercedes e intentar colocarsela al audi.... ya te digo que si no vas al tornero no la pones, por que el buje es mas gordo en el audi. Y lo se porque vendi unas mille miglia evo de mi a6 para un mercedes y tuve que comprarles unos aros adaptadores (centradores) para el buje. Asi que al reves pues a comerle con la vidia del torno. Alla cada cual. Lego no digais que no se avisa. :crying_anim:
  6. Pues lo hemos hecho muchos... unos artesanalmente, otros comprando todas las piezas..... pero poderse se puede. Lo mejor, no tener prisa, para que te salga bien y barato. Sin embargo si eres de los que les quema el navi en las manos pues te toca apoquinar... o si eres un manitas pues con un poco de ingenio y y bricomania y una chapa de aluminio o algo asi.... se puede hacer. Yo tenia un brico hecho pero las fotos caducaron... Pero al final tampoco queda muy bien... Mira en ebay, te hace falta una consola doble din para A6, un clima para doble din, estropeado da igual, asi es mas barato, y luego intercambias la electronica, ya que todos los climas no valen para todos los A6, varian en los años de montaje. Ten en cuenta el color de este, pues del 97 al 01 es negro oscuro y del 01 al 05 es tirando a grisaceo... Luego tiuenes que buscar un cenicero ya que es mas pequeño o pasar de el como yo hice... saludos
  7. Hazme caso olvidate, tu cuadro es de los que no tiene can-bus saludos
  8. : Vamos a ver: La antena larga de los avant llevan tres cosas: navegador, radio y telefono La antena corta de los limousina llevan dos cosas: navegador, y telefono. (ya que la radio la llevan en la luneta termica del cristal trasero) Si tu tienes un avant y quieres poner la corta, pierdes la radio. Con lo que tendras que añadir una antena de esas que se pegan al cristal interiores y que ademas deberas de alimentar con 12v a traves de llave de contacto o salida para antena automatica de la radio. Aunque yo creo que esto ya te lo han explicado anteriormente. Y si se compra en el concesionario, yo de hecho la compre alli, y tienen tanto la moderna como la antigua. Y tambien en ebay están. Saludos
  9. Bienvenido y mucha suerte en todas las carreras. Un placer contar contigo, espero que algun dia nos cuentes los secretillos de ese audi que gastas <_< Saludos
  10. Que yo sepa las de audi para mercedes valen con casquillo centrador del buje. Por lo tanto las de mercedes para audi, deberian pasar por el tornero, para aumentar el diametro del buje. saludos
  11. Pues en principio, valen para conectar el modulo TMC, para la navegacion dinamica, osea via radio, en el mapa se te deberian de reflejar obras y tal... si la zona por donde viajas esto funciona. Ademas vale si tienes modulo TMC para ver los pictogramas de navegacion en el fis. Yo no conozco ese modulo y esa conexion, asi que no te puedo informar de si o que no, te funcionara, o de que te puedes cargar algo... Saludos
  12. Este es el esquema que le hice a un amiguete y no necesito cables, si no modificar un poquito los actuales: Ademas lee este articulo: http://www.audimb.net/contenidos/content.asp.191.html
  13. txispis
    Hoy DTM y WTCC
    la de wtcc en tele 5 sport TDT en directo a las 12 y a las 15h30: http://www.fiawtcc.es/fiawtcc/zandvoort/2007/calendar.shtml Y la DTM el que tenga ONO digital a las 14H por el canal motors tv: http://www.dtm.com/rennen.php?rennen=2007-05-06 Saludos
  14. Hay aqui mismo otros hilos que lo explican... yo como ese no lo tengo, pues ni idea... aunque creo que se hace por soft... Saludos
  15. Lo tendras mal cortado. Si se hace bien los rns-d funcionan perfectamente, como he puesto antes solo pasa que no funciona el volumen automatico en funcion de la velocidad. saludos
  16. Aunque te lo he pasado por privi, te lo pongo aqui tambien: Hola: solo tienes que cortar un cablecito de detras del navi. Yo lo tengo en vez de cortado, pasado por un interruptor del salpicadero, de los que vienen vacios al lado del ASR. Asi lo pongo y quito cuando quiero. No te asustes con el esquema, como puedes ver solo debes de sacar el navi, con los utensilios que se pueden comprar o hacertelos tu mismo (hay mucha info en el foro) necesitas 4. es una radio pero es igual en el navi este desmontaje Coges el conector negro de 8 pines y cortas el cable que va al pin 1 (gala), lo aislas con cinta aislante los dos lados y ya esta. Si quieres hacer como yo pues a esos dos estremos del cable cortado, alargas unos cablecitos y conectas un interruptor, para poder activar o desactivar cuando quieras. Ya sabes que si te ven con la tv en movimiento, te pueden multar. Ademas hay una funcion con el cable cortado que se pierde, que es la subida o bajada del volumen automaticamente en funcion de la velocidad (aunque es casi inapreciable) Saludos
  17. Aunque ya te he contestado a una cosita por privado.... queria tambien darte la bien venida :clap1: estas en tu casa saludos
  18. Que quereis que os diga, quizas en los coches de despues del restiling del 2001, las lamparas sean diferentes, no lo se. Ya sabeis que los faros tambien son distintos. Habra que ver por ahi... Ya está: Puede llevar de las dos dependiendo si son "longlife" o no mirar la posicion 9, hay dos posibilidades H1 y H7. Todos teneis razon. Saludos
  19. Hola: Si es un rns-d que es lo que yo conozco: Si se puede, en sintonizador antiguo, tiene entrada de a/v compuesto en el sintonizador; en el moderno hay que comprar un adaptador baratito y tienes hasta 2 entradas aux de a/v compuesto Si se puede es muy facil (un interruptor cortando un cablecito) Depende de que sintonizador tengas (hay 2 ref) el dvd es facil verlo en todas pero la tv es mas dificil. Solo la veras adelante. Hace falta un adptador para convertir el rgb en Video compuesto... y eso es tela... y caro, mejor olvidarse. Tambien puedes poner un tdt a posteriori, colgando de una entrada del dvd y lo veras en todos lados Saludos
  20. Mira si hay un aparato debajo del cargador de cd, ahi suele ir la tv A lo segundo... hay que utilizar el clone cd con las opciones safedisck 2/3 y tal y tener suerte con lo que te bajas. Y depende de tu navi... Saludos
  21. txispis
    A q os dedicais?
    Con tu edad, trabajaba en varios sitios a la vez, para poder comprarme un coche nuevo de 1.9 mill. Ya que tenia u n R7 de 4ª mano. Entregar el sueldo en casa y no se que mas. Pero que he tenido que currar como un Hp eso te lo aseguro. Ahora soy responsable de automatización de un grupo de empresas. Pero de ahi a estar forrao.... tenemos un coche y punto. :drool: :crying_anim: (comprado de 2ª mano y en el 2000). Y ya me gustaria comprarme un coche de 60000 eurillos pero no puedo.... que somos 4 en casa :crying_anim: Saludos
  22. Os dejo un poco de info y fotos del mio (no es muy tuning): Las modificaciones exteriores: Paragolpes y taloneras dietrich, rejillas originales modificacion by txispis, mas parktronic trasero no original (look RS6). Faros xenon allroad. Calandra Kamei + aritos, y la chapita RS6 ya me la soplaron... escapes modificacion by Txispis, de un doble a dos simples laterales reales, con colas ovaladas. Espejos pintados en color aluminio y cambiados a restiling 2001 los dos grandes. Aleron trasero, imitacion RS6. Llantas 18" RS4 no originales Antinieblas delanteros hella Antena A6 +2001 (GPS+GSM) Pilotos traseros Led+antinieblas traseros restiling 2001 (funcionan los dos) Portamatriculas ASI Y el punto de partida era este, pero con llantas de serie: Las modificaciones interiores (hechas por mi, como casi todo): Asientos recaro RS6 Pantallas en reposacabezas Navi+Rns-d con sonido Bose Sintonizador de Tv DVD Playstation Calefaccion asientos traseros Parktronic Telefono nokia 6090 con iluminacion roja etc. El proceso es este: http://www.audisport-iberica.com/foro/inde...showtopic=30707 Aunque hay fotos que ya no salen... una pena. Saludos
  23. Tienes un RNS-d o RNS-e? el antiguo o el moderno?
  24. txispis
    WIFI direccional
    Yo puse un enlace de 15 km y funcionan como un tiro Saludos
  25. Hola: Solo una curiosidad: La foto es de tu coche entiendo. Y la antena que llevas arriba es de GPS y GSM, y la de abajo (varilla) es solo GSM. La de la radio va en la luneta termica. Si solo tienes un telefono en el coche, acepta un consejo: Quita la de varilla y pasa un cable hasta el techo y engancha la de arriba. Te olvidaras de un problema para siempre. Yo lo hice y de maravilla. Saludos
