Me caigo de la lista, se la pillo a Pocoyo
Actualización:
1- --------------- SePuLTuR -------------------- Si ----------------------------- Pendiente
2- --------------- javicano---------------------- Si ----------------------------- SI (480€)
3-----------------Espurna------------------------Si------------------------------ SI (450€)
4-----------------mcflurri----------------- -------Si----------------------------- SI (480€)
5-----------------Cesar de Rianxo--------------SI------------------------------ SI (480€)
6-----------------Homer76-----------------------SI------------------------------ SI (480€)
7-----------------cheewie------------------------SI------------------------------ SI(480€)
8-----------------Jorge_21-----------------------SI------------------------------ Pendiente
9----------------xmax31------------------------SI------------------------------ SI (480€)
10----------------bocatapinchos-----------------SI------------------------------ SI (480€)
11-----------------sitor---------------------------SI------------------------------ SI (480€)
12-----------------Moy.---------------------------SI------------------------------ SI (480E)
13-----------------cantarero ---------------------SI----------------------------- SI (480€)
14------------------CesA3------------------------SI----------------------------- SI (480€)
15------------------gira2--------------------------SI----------------------------- Pendiente
16------------------seca--------------------------SI------------------------------ SI (480€)
17------------------DANIT------------------------SI------------------------------ SI (450€)
18-----------------inakif--------------------------SI------------------------------ SI (480€)
19----------------TIOLOPEZ---------------------SI------------------------------ Pendiente
20----------------FelipeMadrid------------------SI------------------------------ SI (480€)
  • Respuestas 1,7k
Gracias por los comentarios luisja.
El problema de la radio es que los que tenemos radios antiguas (simphony, concert II, ... ) tenemos una antena diversity. El amplificador de la antena coge la que mejor reciba la señal de las dos. En las nuevas radios que monta audi es una antena sencilla y este problema se soluciona montando un amplificador para la antena, pero no tiene mayor inconveniente.
Otra lectura que saco es que los que tenemos radios antiguas (los que usamos el segundo de los conectores opcionales) oiremos los altavoces traseros sin manipular nada, y los que vengan de una concert iii necesitarán algo adicional.
Lo dicho Luisja, gracias por todo lo que estás haciendo.
pues si, en mi caso el amplificador han sido 12 euros
sld
Hola luisja333,
Puedes indicarnos que amplificador compraste y donde para que vayamos mirandolo aquellos que tendremos que instalar uno?
Otra cosa, habria que ir mirando en mas detalle que necesitamos para los que tenemos Concert III para hacer funcionar los altavoces traseros y el sub, porque no me ha quedado claro si al final se necesita algo exterior de lo que ya viene en el pack de cables con el equipo SSO o no.
Tambien estaria bien que SSO nos comunicara si han recibido bien las transferencias y pagos del equipo de la lista que hemos indicado que ya hemos pagado.
inakif
sld
Hola luisja333,
inakif
A ver si nos aclaran todos esos puntos porque es muy importante.
19----------------TIOLOPEZ---------------------SI------------------------------ SI (480€)
1- --------------- SePuLTuR -------------------- Si -----------------------------SI (480€)
sld
Hola luisja333,
inakif
1+ pues si por que se supone que tiene que venir todo para usarse desde su recepcion... y por lo que comentais no es asi :S
Editado por cheewie
Yo me quede tranquilo cuando los llame y me confirmaron que si habian recibido
el ingreso.
Veo que van a tener que mojarse y darnos el amplificador para los que tengamos
concert III no me parece justo comprar algo y que no se pueda instalar con el
material que trae, hasta las radios de carrefor vienen con todo. :wub:
sld
Hola luisja333,
inakif
hola , del amplificador poca cosa puedo deciros , fui donde me la instalaron y se lo comente y ya esta , me dijeron que provarian un amplificador de antena y por lo poco que lo vi es muy simple . creo que era algo como esto y si no muy parecido
luisja333, podrías decirnos cual ha sido el taller q te lo ha instalado, donde está y el coste?? Por hacernos una idea...
Pocoyo, podrías preguntar a tu instalador si ha necesitado algo extra para hacer funcionar los altavoces traseros?? xq tu coche era un restyling con concert III.
Gracias a ambos.
Gracias a ambos.
hola , yo le he instalado en RIVAS-VACIAMADRID, se llama FONORADIO y el coste ronda sobre los 90-100 euros , en el mio estuvieron 3 horas y media mas o menos
Gracias a ambos.
menos mal que era quitar y poner..... :flwrs:
Editado por sitor
Gracias a ambos.
El mayor tiempo es desmontar cosas para colocar las antenas en el mejor lugar posible para q tengan buena recepción, y luego volver a montar. El navegador en sí, es desenchufar uno y enchufar el otro...
Hombre yo creo que el tema de los altavoces traseros y el amplificador de antena lo debe solucionar SSO,para los que tenemos concert III...
Lo voy a instalar yo mismo y segun ellos mismos comentan que en la caja debe venir todo lo necesario para su instalacion...Asi que ya saben que le pregunten al chino o a quien sea,para un esquema de conexiones y todo lo que se haga falta en la cajita....
y no modificar la publicidad que ya la tengo guardada ok.. :flwrs:
ADJUNTO CAPTURA....
TODO LO NECESARIO PARA FUNCIONAR DESDE EL MISMO DIA QUE LO RECIBA.............
luisja333, tendría que confirmarnos alguien si al final sirve el microfono del parrot como microfono externo, puesto que yo actualmente llevo un parroto y si me sirviera pues eso q gano, pueso que ya está instalado donde a mi me gusta y no tendría q desmontar cosas... jeje.
