hace 2 horas, grabie dijo:
Dejo esto aquí para los maestros de programación. Está en inglés y es un mensaje que han subido al hilo audizine del 10,25"
"Hi Daniel,
the headunit 10.25 is amazing. I still have to get my A4, but I am already looking forward to it to install one of these units. I have read through the thread and I noticed that you have had some problems that remind me 100% of the ones I had with another android head unit for a Audi. These units are called generically MTCB/C/D/E
Probably you already know about it, but there is a really big community on Android headunits in xda-developers. We even managed to get a thread for android auto. https://forum.xda-developers.com/android-auto
When I first bought my unit for an A3 in 2014 it had nothing. SWC would not work with 3rd party apps, had no standby, ... etc. Many mods have been done later, both on the Android part as well as on the MCU. Now all the buttons can be re-programmed with one or even 2 functions (double click, one click) and we can choose how long the headunit stays in standby (5min to 24h). I guess it would not be difficult at all for the devs that did this to repeat it. Now there are a bunch of specific apps that make the experience of the MTCX units much much better (autobrightness control with day-time, auto start of apps, sound synchronises with speed, screensaver function, music toasts, tweaks to allow TomTom to work with the units, etc. etc.)
Some key users in xda would be:
Malaysk
7floor
dsa8310
Halk9_
MVG-V70
borondooook
R4D3N
dark alex
agentdr8
KeiserSozeyFr
typos1
dark alex, typos1, Malaysk, ds8310, and agentdr8 have followed the thread since the beginning of times, so they are the guys contact.
I hope it helps."
Los maestros de programacion creo que están todos en xda developers,de ahi salieron las mejores modificaciones
de Android desde el "principio de los tiempos". Si algo bueno saldrá para este equipo seguro que serán ellos quienes
lo desarrollen.Unas máquinas.
  • Respuestas 1,2k
Buenas después de probarlo un par de dias la verdad es que estoy contento con el,pero le he detectado varios bugs
Si estoy reproduciendo un video de youtube y no sales al menú principal el equipo no se apaga cuando cierras el coche(espere hasta que se apagó el botón del freno de mano)
El otro ya es conocido,es que salen caracteres chinos cuando bajas o subes la temperatura del aire acondicionado(o la velocidad ahora no recuerdo bien)
Otro que he detectado es que salen 2 ruletas de velocidad del aire acondicionado y cuando mueves la velocidad sólo se mueve una
Y el mío ha venido defectuoso,no me reconoce la sim
Eso es lo que he detectado por ahora,mañana contactare con daniel a ver que solución me ofrece para lo de la sim
Editado por paxama
hace 9 horas, paxama dijo:
Lo del retraso en la desconexión, algunas veces tarda en apagarse más de lo que tarda el coche pero termina apagándose, compruébalo. A mi me tenía obsesionado este tema hasta que me di cuenta de que es normal.
Lo que hago a veces es dejar la Tablet en su pantalla de inicio antes de salir del coche y así se apaga antes.
Editado por grabie
En 9/2/2018 a las 10:37, grabie dijo:
Ahora mismo es la que tienen colgada aquí:
http://wiki.rsnav.com/Help%3ASoftware_Update
El procedimiento es este:
I did the following
1. Copied update.zip to my USB drive,
2 .plugged it in the unit.
3. Brings up the update code to be entered cancelled that
4. Copied update.zip to SD card and Internal storage root.
5. Unplugged the USB drive and plugged it in
6. Brings up the update code and you enter '888666'
After the update of about 30min and multiple restarts
1. Delete update.zip on USB drive, SD card and internal storage root.
2. Copy mcu_update.bin to USB drive
4. Copied mcu_update.zip to SD card and Internal storage root.
Again let the unit restart a few times, but its a lot quicker
And finally delete the zip files from all of the storage locations to clean up
Más info aquí: http://www.audizine.com/forum/showthread.php/786535-Audi-Android-Interface-Units/page13
En unos días pondrán la segunda.
Gracias @grabie lo habia visto pero hay tres que me cuadran. Actualizaciones de software del sistema Android RSNAV , SISTEMA ANDROID RSNAV CAN BUS Actualizaciones, RSNAV SISTEMA ANDROID MCU Actualizaciones ¿? Cual de ellas¿?pq que las tres me cuadran
En ‎09‎/‎02‎/‎2018 a las 10:51, grabie dijo:
Yo instalé dos y este orden según el procedimiento que te he dado:
- RSNAV Android System Software Updates (archivo update.zip de 1 gb).
- RSNAV ANDROID SYSTEM MCU Updates (archivo mcu_update.bin de unos pocos Kb).
Tras varios reinicios y uno final que me pilló conduciendo cuando ya pensaba que algo había fallado se aplicó la actualización.
Yo tengo Concert y, si te fijas, no hay archivo disponible para Canbus Update, así que son las dos que te digo arriba.
Para la actualización de Android System Software, Daniel me remitió el enlace por correo privado. Pero el único archivo disponible para RSA-70201 europeo es:
B8(RSA-10XXX, RSA-70XXX) 1024x600 Resolution, Region Europe (LTE BAND 1,3,7,38,39,40,41): M8.Q5.1.0.1.01311026
Ante cualquier duda, contacta con Kim o rsnav: https://rsnav.com/pages/about-us
hace 2 minutos, Arturo_76 dijo:
Perdon por el post anterior estaba esditan no se que pasado.
Lo he montado y la verdad es que es mas facl de lo que parece, es mas parte mecanica de desmontar y pasar cables que otra cosa.
Tengo alguna cuestión para ver si me pòdeis ayudar.
La version con la que me llega del sistema es M8.Q5.1.0.1.01261614 pero la que veo tienen en wiki es posterior.
@paxama puedes confirmar cual es la tuya?   @grabie puedes confirmar que esta es la ultima ¿?. La version de MCU veo que es la ultima "Mcu:4.2.0115. adjunto mi version. No me funciona el AUX. Podeis alguno pasar el VAGCOM a ver si os da un error de la Radio?. Aproveche el brico de montaje en AUX en la guantera y no sé si tendrá que ver.  Estoy preparando el brico.
hace 1 minuto, Arturo_76 dijo:
Esta es mi versión, igual que la tuya:
No tengo VAGCOM así que no puedo ayudarte en esto, lo siento.
hace 9 minutos, grabie dijo:
Gracias!!!!
Tenemos la misma entonces...
Entonces tu no lo has actualizado ¿?
El archivo que te mandó Kim me lo puedes pasar¿?
Si ves el SN -numero de serie- el mio es bastante anterior al tuyo.
A kim le he mandado varios correos y no me contesta.
Tengo que mirar tus post a ver como configuro el equipo que lanzador y aplicaciones poner etc.
No hago que me funcione el AUX, lo tengo que revisar.
A ver que versión tiene @paxama
Editado por Arturo_76
Gracias!!!!
El archivo que te mandó Kim es el de la MCU¿?
Si que he actualizado y funciona de lujo. ¿?
Kim me mandó el enlace al update.zip    Si no te responde, ponte serio porque pagar le has pagado... y bien.
Ahora, grabie dijo:
Pero no entiendo... si has actualizado como es que no te aparece en la pantalla anterior la nueva versión¿?.
Mi experiencia con este hombre no esta siendo todo lo buena que debería, mucho me temo que no querrá reconocer que el equipo que tyo tengo tiene un SN inferior al tuyo.
hace 3 minutos, Arturo_76 dijo:
Ni idea... y viene de camino otra actualización a partir del día 16 (año nuevo chino) para poder personalizar los diferentes iconos de la nueva interfaz.
Kim es un tipo serio, por lo que seguro que te soluciona las pegas que puedas tener. Eso sí, ponte en tu sitio porque está muy liado y no te atenderá si no lo haces.
hace 7 horas, Arturo_76 dijo:
Alguien con RSNAV y vagcom que le pase el VAG y me pueda confirmar si le sale este error¿?,
 Es de la Radio(56), pero la info es de la pantalla, en Wiki de Ross Tech no dice nada...
De lo mas normal🤣
Y a inversas también 🤣
@Arturo_76 no te preocupes es por la apk del clima, por mas que lo borres sigue saliendo
A mi me sale esa otra del aux...pero porque mi aparato me permite ambos sistemas de manos libres para bluetow original y el del cacharro, no se me mezclan👍.
Otra..no entiendo porque kim les dijo al fabricante que suprimiera la chica AIDE que habla...esa aplicación de asistencia, supongo que como ese servicio suelen hablar en chino😂
2 mas
-3G  PHONE
- AIDE= Audi assistant, lo elimine en un reseteo :221_see_no_evil:, tenias que registrarte y con ello podías interactuar con servicios tipo siri, pero todo estaba en chino....
SAFETY
UNA ENTRADA DE CÁMARA DE GRABACIÓN en marcha
MARRÓN=CÁMARA TRASERA
VERDE=SAFETY
AMARILLOS=2 SALIDAS DE VIDEO (cabezales)
todas esas apk de coches tirando marcha atrás
entrada para TDT y sistema 360
INSTÁLATE ESE CIRCLE BAR...VA DE PM (derecha imagen) siempre esta escondido y cuando le das en una zona de la pantalla sale, su scroll lo puedes definir donde quieras.
POR ULTIMO...mi sistema con tiempos acortados en arranque (en frio...congelado, jajajjajaj)
Perdonar por la girada de cámara:p
Esto es lo que tarda mi sistema en arrancar.
Lo importante es toquetearrrrrrr, jajajjajajaj.
