  • Respuestas 284
Posted Images
Bonitas fotos!!!
si señor
espero q en la nacional sea mejor, mucho mejor!!!!
A la siguiente subo con el nuevo ala madrileña q se está fraguando
un saludo
GRACI.........:p ...tienes el buzon lleno ... ASI que aqui te dejo el resultado del VAG..antes de limpiar la memoria....limpia el buzonnnnnnnnn :drooling:
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 J
Component: 1.8L R4/5VT G 0004
Coding: 10710
Shop #: WSC 06435
WAU xXXXXXXXXXXXXXXXXXXXXXXXXXXX
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 L
Component: A3 KLIMAAUTOMAT 0101
Coding: 00040
Shop #: WSC 06435
Address 15 -------------------------------------------------------
Controller: 8L0 959 655 J
Component: Airbag Front+Seite 4008
Coding: 00104
Shop #: WSC 06435
1 Fault Found:
00588 - Airbag Igniter: Driver Side (N95)
32-10 - Resistance too High - Intermittent
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 A
Component: AB-KOMBIINSTR. VDO D12
Coding: 01044
Shop #: WSC 00234
WAUZZZ8LZ1A055750 AUZ7Z0Y1620677
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15211
Shop #: WSC 06435
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 37 -------------------------------------------------------
Controller: 8L0 035 192 D
Component: RNS 4.1 H05 BNO 0011
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 06435
Address 56 -------------------------------------------------------
Component: Radio BNO 0001
Coding: 00107
Shop #: WSC 06435
End -------------------------------------------------------
Jade, espero que Seneca ya se haya repuesto del ac***ne que paso el viernes llendo ha cenar. :p:p:lol2::lol2:
a mi despues de descansar el domingo ya se me ha pasado. :lol2::lol2::lol2:
Si no fue para tanto
Acojonaaoooooooosssssssssssss!!!!!!!!!!!!!
La culpa d Luisppp q iba abriendo camino. Yo solo le seguia.
Os aseguro q he ido muchisimo + rapido x ahí.
Y lo q hago siempre cuando voy x esa carretera es apagar las luces. Mola un monton.
Evidentemente el viernes no lo hice xq ya ibais agarrados, como para encima apagar las luces y guiarte x la luna
Una anecdota muy muy buena....
A q no sabeis d q color tienes las sabanas la hija d As..?
Pues empieza x M y acaba x U
Jejejeje.... MORAU??? :lol2:
jod** q bueno cuando lo dijo.
Estabamos escuchandola Quebdani, su mujer y yo.
Claro, M.....U. Ni idea
Y de repente MORAU :lol2::lol2::lol2:
:p:p
Para partirnos.
X cierto, un encanto las 2 peques
Editado por Jade
GRACI.........:p ...tienes el buzon lleno ... ASI que aqui te dejo el resultado del VAG..antes de limpiar la memoria....limpia el buzonnnnnnnnn :p
Coding: 10710
Shop #: WSC 06435
1 Fault Found:
Muchas Gracias As.. espero volver a verte pronto.Un saludo :lol2:
Coding: 18448
Shop #: WSC 06435
Coding: 00040
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
1 Fault Found:
Coding: 01044
Shop #: WSC 00234
Coding: 15211
Shop #: WSC 06435
5 Faults Found:
35-00 - -
35-00 - -
28-00 - Short to B+
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 06435
Coding: 00107
Shop #: WSC 06435
Qué bien, cuántas fotos ... :lol2:
La de GONCHITO en la bodega no tiene precio ... :lol2: El amo del calabozo ... (Qué grande eres :roll1: ).
Aun faltan fotos por lo menos de Gonchito, Josema y Pinchadisco, esperaremos que disfruten de sus vacaciones .... :clap1:
Jade, en la Nacional charlamos algo más, que se me fue la olla y no me acordaba de ti :p . Espero se solucione lo de tu coche y ya estaremos.
Jade, espero que Seneca ya se haya repuesto del ac***ne que paso el viernes llendo ha cenar. :clap1: :lol2::lol2::p
a mi despues de descansar el domingo ya se me ha pasado. :roll1::roll1::roll1:
Ya estamos que si la abuela fuma... :p es que no es lo mismo ir fuerte pero conduciendo tu que ir fuerte conduciendo otro y tu en el asiento trasero en la sillita del niño :p:lol2:
