jlarce95 Publicado 16 de Diciembre del 2014 Denunciar Compartir Publicado 16 de Diciembre del 2014 Hola buenas! Le he hecho un auto scan a mi coche y me gustaría que le echarais un vistazo y me explicarais un poco los fallos... Tuesday,16,December,2014,11:03:44:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8D - Audi A4 B5 Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-AJM.lbl Part No: 038 906 019 AN Component: 1,9l R4 EDC 0000SG 1063 Coding: 00002 Shop #: WSC 06335 VCID: 63CFB155F14E991 1 Fault Found: 17552 - Mass Air Flow Sensor (G70) P1144 - 35-00 - Open or Short to Ground Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 8D0 907 389 D Component: ABS/ESP front D36 Coding: 04255 Shop #: WSC 00028 VCID: 346D020904204E9 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl Part No: 8D0 820 043 M Component: A4 KLIMAAUTOMAT D57 Coding: 00043 Shop #: WSC 06335 VCID: 2A511C71D6E4089 2 Faults Found: 00779 - Outside Air Temp Sensor (G17) 30-00 - Open or Short to Plus 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.lbl Part No: 8D0 959 655 J Component: Airbag Front+Seite 1001 Coding: 00104 Shop #: WSC 06335 VCID: 3D7B272D376A8F1 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-920-xxx-17.lbl Part No: 8D0 920 930 M Component: KOMBI+WEGFAHRS. M73 D15 Coding: 00140 Shop #: WSC 02136 VCID: 30650E19F038729 Subsystem 1 - Part No: Ident Component: Nr. Wegfahrs.:AUZ5Z0Y2244044 Ident.-Nr. Wegfahrs.:AUZ5Z0Y2244044 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8D0 862 257 B Component: ZV-Pumpe, Funk D12 Coding: 12865 Shop #: WSC 06335 VCID: 2C5D1A69DC10169 1 Fault Found: 00991 - Interior Lights 28-00 - Short to Plus End --------------------------------------------------------------------- Tuesday,16,December,2014,11:07:53:32264 VCDS Version: Release 11.11.3 Data version: 20120401 También he mirado los inyectores... pero no sé si estan bien o no. Address 01: Engine (038 906 019 AN) 11:07:35 Group 013: Idle Speed Smooth Running Control -0.47 mg/str Cyl 1 -2.8 to +2.8 mg/H 0.42 mg/str Cyl 2 -2.8 to +2.8 mg/H 0.00 mg/str Cyl 3 -2.8 to +2.8 mg/H -0.02 mg/str Cyl 4 -2.8 to +2.8 mg/H Tuesday,16,December,2014,11:32:59:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine (038 906 019 AN) 11:32:32 Group 013: Idle Speed Smooth Running Control -0.16 mg/str Cyl 1 -2.8 to +2.8 mg/H 0.42 mg/str Cyl 2 -2.8 to +2.8 mg/H -0.12 mg/str Cyl 3 -2.8 to +2.8 mg/H -0.19 mg/str Cyl 4 -2.8 to +2.8 mg/H El primer log es con el coche frío y el segundo a unos 80 grados o así... Gracias! Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jmholgadog04 Publicado 16 de Diciembre del 2014 Denunciar Compartir Publicado 16 de Diciembre del 2014 Del unico fallo que yo me preocuparia, es del primero, ese de Mass air flow .... (G70), eso es el caudalimetro, los demas, hay alguno del sensor de temepratura del clima, pero no son importantes. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
sata Publicado 16 de Diciembre del 2014 Denunciar Compartir Publicado 16 de Diciembre del 2014 Pueden ser fallos de hace "mil años" y tal vez quedó reflejado ciertodía que se de desconectó el cauda. Lo suyo es borrar todos y volver a hacer el scan,....si no lo has hecho así claro. S2 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
A4B51.8T Publicado 16 de Diciembre del 2014 Denunciar Compartir Publicado 16 de Diciembre del 2014 (editado) http://wiki.ross-tech.com/wiki/index.php/00779 http://wiki.ross-tech.com/wiki/index.php/01273 Cuando es caudalimetro pone algo así "limited excedid" que también deriva a la sonda de temperatura del refrigerante, primero lo mas barato y luego lo mas caro jeje. Editado 16 de Diciembre del 2014 por A4B51.8T Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jlarce95 Publicado 20 de Diciembre del 2014 Autor Denunciar Compartir Publicado 20 de Diciembre del 2014 Hola sata! Gracias x tu respuesta... ese log era el segundo, primero le hice un scan le borre los fallos, le hice unos 20 km y le volví a pasar el vag, y ese es el resultado... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jlarce95 Publicado 20 de Diciembre del 2014 Autor Denunciar Compartir Publicado 20 de Diciembre del 2014 Gracias a todos x las repuestas! Recomendais cambiar el cauda? Como puedo saber si pide un cambio? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jlarce95 Publicado 20 de Diciembre del 2014 Autor Denunciar Compartir Publicado 20 de Diciembre del 2014 Que me podeis decir sobre los inyectores?? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jmholgadog04 Publicado 27 de Diciembre del 2014 Denunciar Compartir Publicado 27 de Diciembre del 2014 Gracias a todos x las repuestas! Recomendais cambiar el cauda? Como puedo saber si pide un cambio? Yo en mi caso, un gasolina, no me llego a torar jamas error del caudalimetro, pero notaba que el coche no tenia fuerza ninguna pa los 150cv que tiene, y con el aire acondicionado ya era la leche, le costaba salir en los semaforos una barbaridad, asi que un dia me decidi y lo desconecte, y el coche andaba incluso mejor que con el, con lo cual, llegue a la conclusion de que el caudalimetro estaba mal, asi que lo cambi, y la mejora, es alucinante. Saludos. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
