  1. Última hora
  2. Hi could you give me advice on how to program aua ecu with aub ecu.
    i read in one of your posts about the julie emulator?
  3. Hi. I have a skoda kodiaq with standard sound system. I have MIB 2.5. (display9.2") and i read 0x003B00 and 0x003000 data from 5F and edit it by editor https://mqb-blog.com/en/2023/04/17/sound-settings-editor/ But i have a problem. I set gain for subwoofer but when setup in menu subwofer example +6 and then change source or turn off my car and again turn on , subwoofer play like gain 0, but in meny graphical show +6. When change to+5 and again +6 i hear that sub play more volume again. But also to change source or restart/turn off unit. Is any chance to help me.... It is my file dataset: 0x003000 https://drive.google.com/file/d/1vAmuh6buXe6wGzWPW4DSWguLCsK5f92m/view?usp=drive_link 0x003B00 https://drive.google.com/file/d/15Cj1BtSnIoEYhr5PHTTvT5qCTKpavxBu/view?usp=drive_link Please help
  4. Hi. I have a skoda kodiaq with standard sound system. I have MIB 2.5. (display9.2") and i read 0x003B00 and 0x003000 data from 5F and edit it by editor https://mqb-blog.com/en/2023/04/17/sound-settings-editor/ But i have a problem. I set gain for subwoofer but when setup in menu subwofer example +6 and then change source or turn off my car and again turn on , subwoofer play like gain 0, but in meny graphical show +6. When change to+5 and again +6 i hear that sub play more volume again. But also to change source or restart/turn off unit. Is any chance to help me.... It is my file dataset: 0x003000 https://drive.google.com/file/d/1vAmuh6buXe6wGzWPW4DSWguLCsK5f92m/view?usp=drive_link 0x003B00 https://drive.google.com/file/d/15Cj1BtSnIoEYhr5PHTTvT5qCTKpavxBu/view?usp=drive_link Please help
  6. Menuda diferencia de filtros ! He sacado un filtro de habitáculo de 14 años de edad... que ni os imagináis como está jajajaja. Bueno poco a poco así fui haciendo mi A6, un mes correas, otro aceite diferencial, otro mes filtro gasoil... poquito a poco...
  7. Hoy
  8. Hola! Finalmente como bien dijiste en el once oficial Audi...... Nuevo código! Muy majos y amables han sido..... Sinceramente. Coste 0
  9. Hola y gracias por vuestros comentarios. No tengo prisa por repros ni nada por el estilo..... No me hacen falta caballos ni mucho menos..... Jajajja Quizá tocar algo de escapes...... Algo elegante y sin macarrismos! Remus.... O algo con clase. No sé...... De momenro a disfrutar y cuidar lo bien!
  10. Así fue jejejej, gracias!! por cierto veo que tienes un RS3, el sádabo estuve en el aeródromo de Matilla (Valladolid) en pruebas de DRAG, y entre RS3 y RS4 se lo llevaron todo, como zumbaban, madra mía que maravilla, bajaban de los 9seg en 401mts
  11. Disculpa si no he captado bien la intención de tu mensaje, pero intriga no tengo ninguna, simplemente me gusta ver Audis chulos y compañeros que los disfruten con salud. Además mi mensaje no iba para ti. Veo a diario y en persona pepinos de Audi que sí que son únicos, y que directamente no están a la venta (me refiero a modelos que han corrido en Le Mans por ejemplo). Hay montón de Audis que deben ser únicos en España, imagino que hasta mi actual RS3 tal vez lo sea
  12. Jajaja es verdad, recuerdo la fiebre por el diesel que teníamos todos pensando que era lo más ecológico, a mi me pasó parecido.. y el primer A3 que tuve resultó estar afectado por el Dieselgate aquel que hubo, que los cab***cetes hacían que el coche contaminase menos solo cuando detectaba que estaba en modo medición de emisiones Pues disfruta tu cochazo @FreeZeeR, no entiendo por que cambiaron ese motorazo gasolina que además suena genial, por el Diesel. Imagino que por tema consumos, pero la prueba está en que ahora vuelven al gasolina. Saludos!
  13. Muy bonito si señor!! que lo disfrutes!!
  14. Cierto compañero, sorry por insistir. En cuanto actualizar el MMI no esperé ya que viajo bastante y tenía mapas del 2020. No creo que se borren los mapas si actualizo a posteriori, y si es así pues le echo otro rato. Y tb estoy sopesando xq tb tengo la opción de desbloquear google maps sin pasar por audi, pero veo que solo puedo en la 1117
  15. Buenas @gorgoroth!! así es!! Goku estaba cogido jjajaj, por suerte tb tengo freezeer@h***l.com jejej, ya sé que no está bien escrito pero en esos año que había poco internet pensaba que se escribí así Del 2018 es esta "bestia", tengo un Evoque diesel xq en 2015 (cuando lo cogí) era lo más ecológico y parece que si cogías un gasolina eras un put* contaminador... y resulta años después que el diesel es peor bla bla bla. En fin, que tenía claro que un gasolina ya que lo eléctrico no lo veo... no contaminan dicen... se contamina un 500% más en fabricarlo más luego tema baterías, enganches... bueno que esto es otro melón con un debate muy amplio y me lío jjajaj
  16. buenos días mira te hago una marca en verde donde va metido tanto el rele como el condenador @carlisu84 a ver si me puedes decir de qué son
  17. Yo no soy muy de tecnologías, y menos de subir fotos...pero si te vale para tu intriga... jaja ajaaj.... el mío es único es España!!!! No hay otro igual jaja ajajaj!!!!! Y te lo digo en serio!!!!!
  18. Welcome to Audisport Iberica. Please feel free to browse around and get to know the others. If you have any questions please don't hesitate to ask.
  19. Y con el coche has tenido algun problema mas al respecto de que no se te inicia el usuario coml ami? Y luego otro problema que nose si es por que no piso bien el freno o que a veces en el primer clic que le doy al encendido solo me da contacto y al segundo clic ya me arranca. Eso te a pasado?
  20. Buen dia, si porque cogen temperatura En realidad no tendrias que hacer eso, si lo demas funciona bien. haber si alguien sabe si tiene algun sitio por donde ventilar
  21. El Audi RS4 Avant que desata la locura y se vende a precio de Audi RS6 Avant GT FUENTE: https://www.motor16.com/noticias/audi-rs4-avant-locura-precio-rs6-gt/ . . . . . .
  22. . . . . . . . . . El Audi RS4 Avant que desata la locura y se vende a precio de Audi RS6 Avant GT FUENTE: https://www.motor16.com/noticias/audi-rs4-avant-locura-precio-rs6-gt/ .
  23. El Audi RS4 Avant que desata la locura y se vende a precio de Audi RS6 Avant GT FUENTE: https://www.motor16.com/noticias/audi-rs4-avant-locura-precio-rs6-gt/ . . . . . . . . . .
  24. te empezo a hacer hace mucho eso? es raro que con la maquina no detecte nada, porque ya solo que no arranque deberia arrojar algun error. las rpm se mueven cuando le das al arranque?
  25. . . . . . . . . . . . El Audi RS4 Avant que desata la locura y se vende a precio de Audi RS6 Avant GT FUENTE: https://www.motor16.com/noticias/audi-rs4-avant-locura-precio-rs6-gt/ .
  26. El Audi RS4 Avant que desata la locura y se vende a precio de Audi RS6 Avant GT FUENTE: https://www.motor16.com/noticias/audi-rs4-avant-locura-precio-rs6-gt/ . . . . . . . . . . . .
  1. Cargar más actividad
