Todo lo publicado por ibi
Activaciones Menú oculto (coches con navegador)
ibi responde a falobono de discusión en Vag-Com Audi A4 B8
El QZ7 supongo..... http://igorweb.org/equidec/Default.aspx e0a;7d5;4ue;6xe;5sl;5ru;1kw;j0p;1lt;1as;1be;3fa;5tg;7x4;f0a;9g2;0g7;0yf;0jd;tm4;3nz;8bp;u1a;qz7;1zw;8q3;9q8;8z4;de2;7t6;cv7;7k0;4x3;2k7;3l3;4kc;3y0;4k4;5d7;1sa;7mj;q1d;4gf E0A = No special edition 7D5 = DVD player 4UE = Air bag for driver and front seat passenger 6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated 5SL = Left exterior mirror: aspherical 5RU = Right exterior mirror: convex (large viewing field) 1KW = Disc brakes, rear J0P = Battery 580A (105 Ah) 1LT = Disc brakes, front 1AS = Electronic stabilization program (ESP) 1BE = Sports suspension/shock absorption 3FA = Without roof insert (standard roof) 5TG = Decorative aluminum inserts, dulling 7X4 = Park distance control, front and rear F0A = No special purpose vehicle, standard equipment 9G2 = Alternator 100-150 A 0G7 = Tiptronic 0YF = Weight range 6 installation control only, no requirement forecast 0JD = Weight category front axle weight range 4 TM4 = 4-cylinder diesel engine 2.0 l unit 03L.M 3NZ = Rear seat bench unsplit, backrest split folding 8BP = Bi-functional headlight with gas discharge lamp U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer QZ7 = Power steering 1ZW = code not found :-( 8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving) 9Q8 = Multi-function display/on-board computer 8Z4 = Moderate hot country DE2 = 4-cyl. turbo dies. eng. 2.0 l/130 kW 4V TDI common rail Base engine TR1,TD1,TM4/TL4/TP4 7T6 = Navigation system (MID) CV7 = Alloy wheels 8.5J x 18 7K0 = Without tire pressure warning light 4X3 = Side air bag front with curtain air bag 2K7 = Reinforced bumpers 3L3 = Manual height adjustment for front seats 4KC = Side and rear windows in heat-insulatingglass 3Y0 = Without roll-up sun screen 4K4 = Radio remote controlled central locking 5D7 = Carrier frequency 868 MHz without panic button 1SA = Without additional front underbody guard 7MJ = Emission standard EU5 plus Q1D = Sports front seats 4GF = Windshield in heat-insulating glass -
Y si no aparece en mi papel el 1n3 ni el 1n1, ¿qué llevo? Noto que la dureza varía con la velocidad.... -
Muchas gracias.... -
¿Y para navegador cual es el S? Tengo un MMI 3G+ por lo cual debo hacerlo desde el menú oculto... de serie me viene A5 que es el canal 19, si pongo el 20 me sale S5, si pongo 21 me sale RS5 y si pongo 22 ya me voy a Q5, en el 18 me sale el del A4 o RS4... ¿Cómo tengo que hacerlo para que me salga lo de S? Saludos.
- 20 respuestas
[BRICO] AUDI DRIVE SELECT (ADS) A4 B8 Facelift by @Marrones
ibi responde a marrones de discusión en Electricidad Audi A4 B8
O al menos poner: en el canal 63 .... 47 en el canal 64 .... 218 en el canal 65 .... 47 en el canal 66 .... 218 (para ver que modos salen en el MMI del navi) y luego dejarlo en 47 Aunque no estaría mal sumar los 64 del modo RACE para ver si es más deportivo que el Dynamic.... En cuanto al modo offroad, supongo que afectará a la suspensión, más blanda... y a la respuesta del acelerador y la dirección, más suave....- 477 respuestas
- efficiency
- dynamic
- (y 5 más)
El modo race y el Offroad para mi que tienen que ver con modelos superiores de equipamiento. La verdad no se sobre que sistemas actua, pero fijate en la imagen y puedes hacerte una idea. En el mío antes de activarlo...... (Sin ADS de serie) Ponía 218 en el canal 64 y 15 en el canal 66. Es un A5 Coupe 2.0 TDI facelift con Multritronic y no sé si lleva la dirección normal, la servotronic, lo seguro es que no lleva la dinámica... Pero sí te puedo decir que antes de activar el ADS ya se modificaba sola la direccion entre ir despacio o ir deprisa el coche. Tengo que probar a poner 218 en todos los canales para ver que me sale en el MMI del navi.- 477 respuestas
- efficiency
- dynamic
- (y 5 más)
Pero el 3G+ no lleva tecla Setup, en el navi.... al menos en el A5..... -
Yo acabo de adquirir un 11.11.4 y muchos módulos no los lee.... y otros a veces si y a veces no. El mío es un Coupe de marzo-abril 2013
Hoy he intentado poner lo de bajar el espejo derecho en mi coche. En el bit dónde hay que pasar de 40 a 4C o de 50 a 5C, en mi coche tiene puesto directamente un 5E. ¿Qué debo hacer? Es un facelift de principios de 2013. Saludos.
Avisador Kermes Plus III por altavoces de MMI 3G Plus en A5
ibi responde a ibi de discusión en Car Audio / Navegadores
En principio lleva el cable de conexión al mute del teléfono cómo si un manos libres fuese.... ¿Llevará más cables? ¿Cuantos cables suelen llevar los manos libres de bluetooth que se instalan en los coches? Es que el conexionado será el mismo, supongo..... -
ibi publicó una discusión en Car Audio / Navegadores
Buenos días Me he comprado el Kermes Plus III y me encuentro que el aviso de bienvenida es mucho más fuerte que el del aviso de radar, hasta tal punto que tienes que llevar la música muy baja para enterarte del aviso. He visto que para el Kermes hay un accesorio que se llama AudioCall Kermes que sólo vale 40€, con el que se consigue que los avisos suenen por los altavoces del coche, atenuando la música. Debe de ser mediante la entrada de mute del teléfono. ¿Sabéis si el MMI 3G Plus de un A5 facelift del 2013 lleva disponible esa salida? ¿Sabéis si al ser los altavoces por fibra óptica sirve este aparato? Es el último de la página: http://www.kermesgps.com/eu/sp/index.php?option=com_content&view=article&id=59 Saludos. -
Vete con varios del foro y con colegas, y le montas la encerrona y de paso le dais dos buenas ostias.... quédate con su dni y le dices que ahora sabe donde vive, cómo se llama y donde tienes que ir a buscarlo si vuelve a pasar algo en ese garaje o en alguno de la zona. No te cortes, id 20 o 30 y que se escondan... y das la señal por teléfono cuando sepas que son las tuyas....
Diferencias entre A5 Normal y A5 S Line
ibi responde a Andres de Benito de discusión en Audi A5 / A5 SB 8T (2007-2016)
¿En el conce? Sobre 380 más IVA según el ETKA. -
Con todos los respetos.... ¿Poner algo truñing en un coche de 50.000 euros?
¿Qué os regalaron cuando os entregaron el A5?
ibi responde a ibi de discusión en Audi A5 / A5 SB 8T (2007-2016)
Bueno, al final un descuento de la o****, la cajita de Audi Class, una caja de caramelos y que en cuanto salga un curso de conducción me apunta. -
No hace falta desconectarlo. Simplemente, cuando se detenga el coche no pises el pedal del todo, sólo la puntita. El coche no se moverá y el start-stop no actúa. Este sólo actúa si el pedal está pisado al fondo.
Presion para neumaticos, en mi caso.
ibi responde a J-A5 de discusión en Audi A5 / A5 SB 8T (2007-2016)
Cuidado con la medida 245/40 R18 que tiene dos tipos de presiones, para la 93Y y para la V.... una son 2,1 más o menos y la segunda son unos 2,5... -
PLATAFORMA AFECTADOS POR VIBRACIONES EN A5
ibi responde a AFECTADOA5 de discusión en Audi A5 / A5 SB 8T (2007-2016)
0 km Ahora dentro de un rato me paso por el concesionario para ver que dicen. -
Buenas, hoy me han entregado el coche, es un A5 Coupe S-Line Edition y el coche me vibra. ¿Cuales son los síntomas? He notado a 120 que el coche vibraba y que a partir de 160 casi no se notaba. A 120 parecía un pequeño sillón de masaje el asiento. Pero el asiento, el volante no transmitía vibraciones, o eso parecía. He notado por una carretera que parecía que vibraba también pero iba a 60 o así, y parecía de la parte trasera derecha. Mañana hablaré con el comercial para que me hagan un equilibrado de las ruedas, por empezar a descartar. Pero sería raro que de serie venga mal equilibrada una rueda, aunque todo podría ser, ya que era de stock y ha estado parado 9 meses en el concesionario, es de abril del 2013. -
ibi publicó una discusión en Audi A5 / A5 SB 8T (2007-2016)
Buenas noches. Pues eso, ¿que os regalaron cuando os entregaron el A5?. Me lo entregan esta semana y no sé que me van a regalar. ¿Qué suelen regalar? Recuerdo que la VW con el Golf IV, regalaba una mantita. La verdad que no está mal para después del polvete en invierno, jejejejeejeje.... -
Gracias tio, voy a pujar a ver si caen....jijiji En principio no envía a España.....
Vamos, que tiene alarma y en el conce no lo saben.... ¿Dará problemas poner otra alarma más por CAN BUS? Estoy pensando en una con localizador y que cambie de frecuencia.
En que consiste el WAV Paquete de equipamiento España? -
Suspensión deportiva o s line?
ibi responde a davises de discusión en Audi A5 / A5 SB 8T (2007-2016)
Y la adaptativa.... 4 suspensiones... -
El led del marco de la puerta lo traen todos. Para saber si tienes alarma tienes dos formas: 1.- Mira en el canto de la puerta del conductor, debería haber dos botones para desactivarla. 2.png 2.- Abre una ventanilla, cierra el coche, espera 1 minuto y mete la mano en el interior a ver si salta. Es que todavía no tengo, me lo tienen que entregar, y no me fijé muy bien cuando lo estuve viendo en el concesionario. Lo que sí te puedo decir es que en ese sitio hay un botón, que no sé para que será, ya que el coche es dos puertas, por lo que para lo de los niños no es. ¿Si hay un solo botón de que será?
