Todo lo publicado por ferchir
formatear y perder vag com, ayuda por favor
ferchir responde a JAVIER82 de discusión en Vag-Com Audi A4 B6/B7
Tienes que entrar en options desactivar la actualización automatica y haer test y salvar. un saludo -
Problema tras la limpieza EGR y poner junta 9mm
ferchir responde a luis9 de discusión en Mecánica Audi A3 8P
Si. No hay mayor problema. Un saludo -
Creo que en la can gateway solo tienes que activar como que tienes instalado el navegador y ya esta. un saludo Coding (through Index F) Byte 00 Bit 0 [01] Engine Electronics Byte 00 Bit 1 [02] Transmission Electronics Byte 00 Bit 2 [03] Brake Electronics (ABS) Byte 00 Bit 3 [00] Steering Angle Sensor (G85) Byte 00 Bit 4 [15] Airbags Byte 00 Bit 5 [44] Steering Assist Byte 00 Bit 6 [55] Xenon Range Byte 00 Bit 7 [22] All Wheel Drive Byte 01 Bit 0 [09] Central Electronics Byte 01 Bit 1 [46] Central Convenience Byte 01 Bit 2 [42] Door Electronics (Driver) Byte 01 Bit 3 [52] Door Electronics (Passenger) Byte 01 Bit 4 [62] Door Electronics (Rear Left) Byte 01 Bit 5 [72] Door Electronics (Rear Right) Byte 01 Bit 6 [36] Seat Memory (Driver) Byte 01 Bit 7 [65] Tire Pressure Monitoring Byte 02 Bit 0 [16] Steering Wheel Electronics Byte 02 Bit 1 [08] Climate Control Byte 02 Bit 2 [76] Parking Aid Byte 02 Bit 3 [7D] Auxiliary Heating Byte 02 Bit 4 [18] Auxiliary Heater Byte 02 Bit 5 [26] Auto Roof Byte 02 Bit 6 [69] Trailer Byte 02 Bit 7 [06] Seat Memory (Passenger) Byte 03 Bit 0 [3D] Special Function Byte 03 Bit 1 [47] Sound System Byte 03 Bit 2 [75] Telematics Byte 03 Bit 3 [37] Navigation Byte 03 Bit 4 [57] TV-Tuner Byte 03 Bit 5 [0F] Radio (digital) Byte 03 Bit 6 [56] Radio (analog) Byte 03 Bit 7 [77] Telephone Byte 04 Bit 0 [17] Instrument Cluster Byte 04 Bit 1 [25] Immobilizer Byte 04 Bit 2 [19] CAN-Gateway Byte 04 Bit 3 [1C] Position Sensing Byte 04 Bit 4 [5D] Operations Byte 05 Manufacturer/Model Byte 06 Options Coding (from Index F through Index K) Byte 00 Bit 0 [01] Engine Electronics Byte 00 Bit 1 [02] Transmission Electronics Byte 00 Bit 2 [03] Brake Electronics (ABS) Byte 00 Bit 3 [00] Steering Angle Sensor (G85) Byte 00 Bit 4 [15] Airbags Byte 00 Bit 5 [44] Steering Assist Byte 00 Bit 6 [55] Xenon Range Byte 00 Bit 7 [22] All Wheel Drive Byte 01 Bit 0 [09] Central Electronics Byte 01 Bit 1 [46] Central Convenience Byte 01 Bit 2 [42] Door Electronics (Driver) Byte 01 Bit 3 [52] Door Electronics (Passenger) Byte 01 Bit 4 [62] Door Electronics (Rear Left) Byte 01 Bit 5 [72] Door Electronics (Rear Right) Byte 01 Bit 6 [36] Seat Memory (Driver) Byte 01 Bit 7 [65] Tire Pressure Monitoring Byte 02 Bit 0 [16] Steering Wheel Electronics Byte 02 Bit 1 [08] Climate Control Byte 02 Bit 2 [76] Parking Aid Byte 02 Bit 3 [7D] Auxiliary Heating Byte 02 Bit 4 [18] Auxiliary Heater Byte 02 Bit 5 [26] Auto Roof Byte 02 Bit 6 [69] Trailer Byte 02 Bit 7 [06] Seat Memory (Passenger) Byte 03 Bit 0 [3D] Special Function Byte 03 Bit 1 [47] Sound System Byte 03 Bit 2 [75] Telematics Byte 03 Bit 3 [37] Navigation Byte 03 Bit 4 [57] TV-Tuner Byte 03 Bit 5 [0F] Radio (digital) Byte 03 Bit 6 [56] Radio (analog) Byte 03 Bit 7 [77] Telephone Byte 04 Bit 0 [17] Instrument Cluster Byte 04 Bit 1 [25] Immobilizer Byte 04 Bit 2 [19] CAN-Gateway Byte 04 Bit 3 [1C] Position Sensing Byte 04 Bit 4 [5D] Operations Byte 04 Bit 5 [14] Suspension Electronics Byte 04 Bit 6 [4C] Tire Pressure Monitoring II Byte 04 Bit 7 [11] Engine Electronics II Byte 05 Bit 0 [10] Park/Steering Assistant Byte 05 Bit 1 [63] Easy Entry Driver Side Byte 05 Bit 2 [73] Easy Entry Passenger Side Byte 06 Manufacturer/Model Byte 07 Options Coding (from Index L) Byte 00 Bit 0 [01] Engine Electronics Byte 00 Bit 1 [11] Engine Electronics II Byte 00 Bit 2 [02] Transmission Electronics Byte 00 Bit 3 [03] Brake Electronics (ABS) Byte 00 Bit 4 [53] Parking Brake Byte 00 Bit 5 [04] Steering Angle Sensor (G85) Byte 00 Bit 6 [44] Steering Assist Byte 00 Bit 7 [15] Airbags Byte 01 Bit 0 [55] Xenon Range Byte 01 Bit 1 [22] All Wheel Drive Byte 01 Bit 2 [13] Distance Regulation Byte 01 Bit 3 [14] Suspension Electronics Byte 01 Bit 4 [4C] Tire Pressure Monitoring II Byte 01 Bit 5 [10] Park/Steering Assist Byte 01 Bit 6 [32] Differential Locking Byte 01 Bit 7 [17] Instrument Cluster Byte 02 Bit 0 [25] Immobilizer Byte 02 Bit 1 [09] Central Electronics Byte 02 Bit 2 [46] Central Convenience Byte 02 Bit 3 [42] Door Electronics (Driver) Byte 02 Bit 4 [52] Door Electronics (Passenger) Byte 02 Bit 5 [62] Door Electronics (Rear Left) Byte 02 Bit 6 [72] Door Electronics (Rear Right) Byte 02 Bit 7 [36] Seat Memory (Driver) Byte 03 Bit 0 [65] Tire Pressure Monitoring Byte 03 Bit 1 [16] Steering Wheel Electronics Byte 03 Bit 2 [08] Climate Control Byte 03 Bit 3 [76] Park Assist Byte 03 Bit 4 [7D] Auxiliary Heating Byte 03 Bit 5 [26] Auto Roof Byte 03 Bit 6 [69] Trailer Byte 03 Bit 7 [06] Seat Memory (Passenger) Byte 03 Bit 0 [3D] Special Function Byte 04 Bit 1 [6D] Trunk Electronic Byte 04 Bit 2 [63] Easy Entry Driver Side Byte 04 Bit 3 [73] Easy Entry Passenger Side Byte 04 Bit 4 [47] Sound System Byte 04 Bit 5 [75] Telematic/Emergency Call Byte 04 Bit 6 [37] Navigation Byte 04 Bit 7 [57] TV-Tuner Byte 05 Bit 0 [0F] Radio (digital) Byte 05 Bit 1 [56] Radio (analog) Byte 05 Bit 2 [77] Telephone Byte 05 Bit 3 [18] Auxiliary Heater Byte 05 Bit 4 [1C] Position Sensing Byte 05 Bit 5 [5D] Operations Byte 05 Bit 6 [6C] Rear View Camera Byte 05 Bit 7 [59] Tow Protection Byte 06 Bit 0 [4F] Central Electronics II Byte 06 Bit 1 [19] CAN-Gateway (Standard) Byte 06 Bit 2 [3C] Lane Change Assist Byte 06 Bit 3 [5C] Lane Maintenance Assist Byte 07 Manufacturer/Model Byte 08 Options
Seguramente que es por la junta. Para borrar el error tendrás que pasar el vag-com. Un saludo -
Si es original el vag-con tiene que detectar el modulo. Un saludo
¿como va la cosa has conseguido algo?
Mi vínculo En ese punto es un 1 pero aparte Creo que lo que tienes que hacer es entrar en el modulo can wateway y poner que tienes navegador. un saludo
No enciende por falta de consumo. El led consume muy poco si lo conectas conjuntamente con la bombillaque trae se encenderá. Yo tube que poner dos tiras de led una a cada lado con un consumo aproximado al de la bombilla de origen. Un saludo
Tiene pinta de estar mal la bateria o alguna masa en mal estado. un saludo
mira en google y seguro que lo encuentras. El simbolo del motor si se ha quedado fijo no se quita hasta que no lo borres con el ordenador también podras ver el codigo de averia. un saludo
Tiene pinta de que el turbo no entra completamente. quizas hayan dejado mal regulada la geometria o el tubito que va de la caja de valvulas al turbo estrangulado en algún punto. Un saludo
Si puedes pasa el vag-com a ver si tienes alguna averia almacenada. Tiene pinta de algun fallo de corriente por alguna masa mal o bateria en mal estado. un saludo
No me habia fijado pero si tiene toda la pinta la fecha de los 655.355 km es de 2009. una pasada
Te he mandado un mensaje. un saludo
Por llevar el aviso de inspección no creo que te tiren, otra cosa seria una luz de airbag. ¿Has probado tirando dos veces del botoncito del cuentakilemetros parcial y manteniendolo tirado unos segundos a ver si se borra?. Si no se quita , si quieres quedamos una tarde. un saludo
ayuda no me suben las ventanillas con el mando
ferchir responde a victorgas de discusión en Vag-Com Audi A4 B6/B7
Ventanillas automaticas con un solo click en mando sin dejar pulsado el boton: - Modulo 46(Central Conv.) - Pinchar en Coding - Pinchar en Long Coding Helper - Ir al Byte 5 y activar el Bit6(Automaticaly Closed) - Transfer - Dot it Entra en el modulo 46 luego en codig y long codig helper ves revisando lo que tienes activado y lo que no. El procedimiento de arriba es para un a3 pero imagino que será parecido. un saludo -
Mi vínculo Como te he comentado con el vag-com puedes codificar el cierre y apertura de puertas facilmente. Pero para codificar el arranque debes de pasar por el concesionario para pedir el codigo cosa que no suelen hacer. En el manual del coche suele venir la forma de codificar la apertura y cierre sin tener que usar el vag-com te dejo el enlace de como hacerlo con el cable. un saludo
Climatizador ni no enfria ni calienta
ferchir responde a huse de discusión en Electricidad / Electrónica Audi
Prueba en aplications luego en clear all dtcs a ver si así te los borra y luego te deja entrar en el modulo. un saludo -
Mi vínculo Seguramente será de la mariposa. parece que hay una plaga. Un saludo
Lucecita encendida y.... Error 19558
ferchir responde a rlaurent de discusión en Mecánica Audi A3 8P
Mi vínculo creo que esta entre los 220 y 250 euros solo la pieza. Ademas estaras sin climatizador por que creo que va con el mismo fusible. Puedes desenchufarla y así no te fundirá el fusible. Un saludo -
puede codificar la apertura de puertas pero no el arranque eso solo lo puede hacer en el concesionario o con el vag-com si le facilitan el codigo. cosa que no suelen hacer. saludos
Entrando en panel de control y menu de inicio y tareas programdas o algo así. Hay que deshabilitar el programa para que no salga cada ved que arrancas. un saludo
01044 - Módulo de control codificado incorrectamente Posibles síntomas De funcionalidad reducida Posibles causas Módulo de control codificado incorrectamente Posibles soluciones Revise la lista de puerta de enlace de instalación Comprobar / corregir el módulo de control de codificación Ver vehículos procedimientos diagnósticos específicos para detalles Notas especiales Cuando se encuentra en la CAN-Gateway: En un módulo codificado largo, utilice la Lista de Instalación de puerta de enlace para comprobar si los módulos de control inalcanzables o no registrado. A continuación, actualice la puerta de enlace [Lista de instalación ] mediante la alteración de la puerta de enlace de codificación manual. En un corto codificados módulos, actualice la codificación original con el mismo valor. Por ejemplo, el código de 00006-a-00006 sin hacer un cambio real. Cuando se encuentra en el sistema de confort en el nuevo escarabajo de VW / Cabriolet (1C/1Y/9C) esto puede ser un error en el módulo que será resuelto por la actualización de la codificación con el mismo valor que se ha descrito anteriormente con el ejemplo de puerta de enlace de la CAN. 01044 - Módulo de control codificado incorrectamente: señal no plausible Posibles síntomas De funcionalidad reducida Luz indicadora de mal funcionamiento (MIL) activa Posibles causas Módulo de control codificado incorrectamente Posibles soluciones Comprobar / corregir el módulo de control de codificación Ver vehículos procedimientos diagnósticos específicos para detalles Notas especiales Algunos Passat (3B/B5) en torno a MY 2000 tiene un error de firmware que hace que este DTC que se fijará en la puerta de enlace puede (19) . Documentos de servicio para esos coches indican que este DTC debe ser ignorado en ese módulo, siempre y cuando la codificación coincida con el equipo del vehículo. 01044 - Módulo de control codificado incorrectamente: Si no mecánica Posibles causas Codificación Pin / Bridge no está de acuerdo con Módulo de control codificado incorrectamente Posibles soluciones Compruebe / Fix Codificación Pin / Puente de cableado Comprobar / corregir el módulo de control de codificación Ver vehículos procedimientos diagnósticos específicos para detalles 00888 - Interruptor del limpiaparabrisas para funcionamiento intermitente (E22) 00888 - Interruptor del limpiaparabrisas para funcionamiento intermitente (E22): Defectuoso Posibles causas Fusible (s) defectuosa Cableado / Conector (s) del / al interruptor del limpiaparabrisas para funcionamiento intermitente (E22) defectuosa Interruptor del limpiaparabrisas para funcionamiento intermitente (E22) defectuosa Posibles soluciones Revise el fusible (s) Compruebe el cableado / Conector (s) del / al interruptor del limpiaparabrisas para funcionamiento intermitente (E22) Verifique que el interruptor para funcionamiento intermitente limpiaparabrisas (E22) Ver medición de los bloques de valor (MVB) Notas especiales Cuando se encuentra en VW Golf / Jetta / Bora (1K/5M) (y similares): Volante , Check medición de los bloques de valor (MVB) 001,4 002,1 +. Este fallo no significa que el interruptor del limpiaparabrisas / palanca de sí mismo, esto significa que el pequeño interruptor para el intervalo en la parte superior de ella! un saludo
puedes desenchufarla y poner el fusible. Así no te lo volvera a fundir y te funcionara el clima. El piñon que te comento esta dentro de una carcasa al lado del conector y tu al quitar y poner la egr no lo puedes manipular. un saludo
